Home Audio Speakers
Where to put my rear surrounds?
Discuss Where to put my rear surrounds? in the Manufactured Speakers and Subwoofers forum; Where to put my rear surrounds? I just preordered my HTD towers and I need to decided / prepare to where I want my HTD bookshelves ...
Views: 470 - Replies: 5
Old 01-24-08, 01:20 PM   #1
Alias: Mike
Loc: Austin
User: #14610
Since: Dec 2007
  Picture_Shooter is offline
I just preordered my HTD towers and I need to decided / prepare to where I want my HTD bookshelves to be for my rear surround sound.
Either:
A) Keep them on stands put them behind the couch.
B) Mount up to the ceiling and face them down at an angle.
The look would be way cleaner if I mount to the ceiling (wires would be in the attic). What do you guys think?
The ceiling is 8' high
Thanks
Old 01-24-08, 02:41 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Where to put my rear surrounds?
Picture_Shooter wrote: View Post
Go with "B" Rear surrounds should be above listening hight by about 3 ft. The sounds that come from the rear channels are meant to "fill" a space not be directed at your listening area as the fronts do.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 01-24-08, 03:08 PM   #3
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Agree... I think they may be too directional if mounted on stands.
Old 01-24-08, 04:03 PM   #4
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
  Warpdrv is offline
Sonnie wrote: View Post
That is exactly right.... they just don't sound the same side fired at listening level.
Thats how I had mine setup until I got them mounted up to the ceiling, firing just above the head level... they sound fantastic now..
Old 01-24-08, 07:15 PM   #5
Alias: Mike
Loc: Austin
User: #14610
Since: Dec 2007
Thanks all for your opinions
Old 01-25-08, 10:17 PM   #6
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
The heretic raises his ugly head again... :raped:
I agree that I'd put them up on the walls, but I'm FOR directionality.
Back in the ProLogic days, diffuse sound made sense. But with the discrete signals of DD and DTS (pick a flavor), it makes sense to me to leave them pointed at the listener.
JCD
