Are these speakers any good? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Audio Speakers
Discuss Are these speakers any good? in the Manufactured Speakers and Subwoofers forum; Are these speakers any good? I was looking at buying some new speakers for my future home theatre project. I almost bought some of the ...
Old 02-25-08, 08:27 PM   #1 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
I was looking at buying some new speakers for my future home theatre project. I almost bought some of the best buy klipsh they had...cant remember model.
Then i found a for sale add on a forum im always on and ended up with some jbl speakers.
I think he said they were about 7 years old. Not sure if newer ones are any better or what.
Heres what i got
2 HLS620's
1 Northridge Series center
2 HLS410's
They sound way better than my old KLH system but thats probrably not saying much.
When i found these i was looking to spend $1000 or less and bought these for $200. I found the suggested price for the HLS620's back in the day was $600 each.
Did i waste my money?
Old 02-25-08, 10:14 PM   #2 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Re: Are these speakers any good?
Jodean wrote: View Post
...They sound way better than my old KLH system but thats probrably not saying much.
When i found these i was looking to spend $1000 or less and bought these for $200. Did i waste my money?
I don't think you wasted your money ... you admit that they sound better than your KLH
In the other hand, you saved $800 for your next big upgrade ... just take your time, audition as many as you can and save more money to get some nicer speakers
I own a pair of JBL Venue Stadium ... they sound really good, but I read that there are better choices within JBL and other brands like Paradigm, Martin Logan, Definitive Technologie, etc.
Old 02-26-08, 08:25 AM   #3 (Link)
Alias: Jay
Loc: Western Wisconsin
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
If you didn't get the owner's manual here you go: http://manuals.harman.com/JBL/HOM/Ow...LS620%20om.pdf http://manuals.harman.com/JBL/HOM/Ow...N24AW%20om.pdf
What are you thinking about for a subwoofer?
Old 02-26-08, 09:53 AM   #4 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
jackfish wrote: View Post
Cool.....does that recommended watts mean i should have 200 per speaker? This old hk avr 35 is giving me problems with DD and doesnt sound that great for some reason.
What is a good reciever to push these speakers for under $450?
That is my next question......should i find a matching jbl or go other brand....agian would like to stay in the $450 range or less.
Thanks guys!!!
Old 02-26-08, 12:02 PM   #5 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
No, that 200watts is the max power the speakers can handle before being damaged.
I'm not a big believer in speaker/receiver "synergy". I also don't think there is a huge difference in sound between name brand receivers in the same price range. Therefore, what I'd look for are the features/remote/reliability that you like in a receiver. I think right now, the value leader is Onkyo. For that kind of coin, you could get the TX SR-605, and MAYBE the TX SR-705.
For the "regular" speakers, I'm a proponent of getting the SAME speaker all around. Barring that, I'd get the speakers in the same model line all around. However, the sub is a different creature. For that, I'd just buy the best sub that you can with your budget. In the $450 range, I'd get the PB10-NSD from SVS. It sells for $429 before shipping.. with shipping, you'll break your range a little, but trust me, it'll be WAY worth it as these subs are WAY WAY WAY better than anything you'll get in a big box store for anything remotely close to this price. The other alternative would be a sub from Hsu. Their VTF-1 would be the sub in your price range. Another very capable sub. Between the two, I'd splurge and go for the SVS as I think it'll offer slightly better performance.
Anyway, that's the world according to me..
Good luck and happy listening.
JCD
Old 02-26-08, 01:41 PM   #6 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
JCD wrote: View Post
Oh.....i always thought when it said "recommended" you should have almost or equal to that much power to them.......They way i interperet it was if you only had 100 watts you went doing the speakers any justice.....
and if they stated a max wattage to just ignore that and only look at the rms wattage......now after knowing that....what is recommended wattage mean then?
Old 02-26-08, 04:10 PM   #7 (Link)
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
User: #53
JCD is offline
I think you lost me.
I looked at the PDF's for the two JBL speakers referenced above and only saw "recommended maximum amplifier power". Is this the recommended wattage you're referring to?
JCD
Old 02-26-08, 04:20 PM   #8 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
JCD
I guess i read that wrong....should have one of those turn sideways monitors!!!
Old 02-27-08, 11:14 AM   #9 (Link)
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
For subs SVS and Hsu are hard to beat.
Unfortunately, the cheapest I've seen the Onkyo TX SR-705 for is $600. The TX SR-605 for $400. But even the TX SR-605 has enough power for those speakers unless you have a cavernous room.
Old 02-28-08, 11:12 AM   #10 (Link)
Alias: John
Loc: Nevada
PT800's Avatar
User: #17108
Since: Feb 2008
PT800 is offline
The manual said "max recommended power", not peak power. So I would take that to mean continous or RMS power. So for the 620s that would be an amp rated at 200w or there about.
When my HT consisted of 7 L212s that are only rated at 100w, I was using a Parasound 220wpc amp, never hurt a single one of those 30 year old speakers.
As for your HK receiver, get one that has L7 processing, like a 635 or newer model. The L7 sounds much better than DD.
Similar Threads
Good Bookshelf Speakers? kioko12 Home Audio Speakers 4 02-11-08 12:56 AM
Good places to audition Speakers in LA Funkmonkey Home Audio Speakers 7 01-24-08 03:04 PM
Can anyone tell me if this sub is good? tonyvdb Home Audio Subwoofers 7 12-11-07 09:07 PM
Where to find/buy good deals for Speakers Stands? tchelo Home Audio Speakers 1 11-24-07 10:36 PM
Revel F52 Floor-Standing Speakers, C52 Center Channel Speaker, S30 Bookshelf Speakers Sonnie Home Theater, Audio and Video News 0 06-02-06 08:33 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
