| Home Audio Speakers Speaker Stands & FurnitureDiscuss Speaker Stands & Furniture in the Manufactured Speakers and Subwoofers forum; Speaker Stands & Furniture Sorry if this is in the wrong thread, I'm a newbie to these boards. I'm picking up a pair of ... |
| | #1 (Link) | |||
| Speaker Stands & Furniture Sorry if this is in the wrong thread, I'm a newbie to these boards. I'm picking up a pair of bookshelf speakers and could use some advice regarding a search for some appropriate stands. If you don't mind, could I get some recommendations regarding particular manufacturers? We're also looking for some new furniture to place a new plasma tv. Most likely, we will not wall mount because of our location and the need for some storage space for accompanying equipment. I've looked at salamander designs and liked their items. Anyone have some other suggestions? thanks in advance! | |||
| | #5 (Link) | |||
| | Re: Speaker Stands & Furniture I agree with Brent on this one. DIY stands wouldn't be to hard and would be far cheaper then buying if you are up for it. As far as resonance goes I would suggest using a dense foam to decouple the speakers from the stand rather than getting a stand that can be filled with a material. Proper decoupling leaves you with a lighter stand (they can still weigh quite a bit) and will remove all possibility of resonance while using a filled stand might just change the audible resonant frequencies emitted by the stand. Also, some pre-made decoupling units such as the Auralex Gramma allows for adjustable angled placement of the bookshelves which can also be a plus. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Easy Inexpensive DIY Speaker Stands | rumonkey2 | DIY Speakers | 23 | 12-09-07 09:59 PM |
| new speaker stands for cheap | wig | DIY Speakers | 13 | 11-28-07 11:51 AM |
| Importance of Speaker Stands | trainCatcher | Home Audio Speakers | 16 | 11-08-07 10:16 PM |
| Speaker wire & conduit | Dain Bramaged | Home Theater Design and Construction | 16 | 10-20-07 09:21 AM |
| Omnimount unleashes stylish new AV furniture designed to handle up to 18 stones worth of kit - including 60in screens | Roger | Home Theater, Audio and Video News | 0 | 05-15-06 08:12 AM |
