| Home Audio Speakers Sensitivity QuestionDiscuss Sensitivity Question in the Manufactured Speakers and Subwoofers forum; Sensitivity Question Though I've been an audioholic for years, there are many little things I've never really looked into very deep. Therefore ... |
Views: 658 - Replies: 24
| Sensitivity Question Though I've been an audioholic for years, there are many little things I've never really looked into very deep. Therefore I just want to make sure I am understanding this concept. My old pair of speakers was was rated at 93 db / 1w / 1m. My new pair of speakers are rated at at 84 db / 1w / 1m. Therefore to get the same volume out of this pair I will need to crank up the adjustment on them 9 db? After tweaking with the speakers for some time now, I had basically discovered that turning it up 9 db did actually give the sound volume that I am used to... but until I really sat and thought why I didn't realize this simple explanation. And reading in to it even deeper that means I am actually having to send them 8 times the wattage that I had to give my old ones? (Double wattage for every 3 db- 2x2x2) Also, on my receiver: when I turn the volume up 3 db notches, am I actually sending twice the wattage out to my speakers? I am sure it is a bit more complicated than that in actuality, but is that the jist of it? And if so, does that mean on my 100 watt per channel rated amp, at -30 db I am giving the speakers like basically no wattage? That one kinda throws me off? | ||||
| | #2 | ||||
| Re: Sensitivity Question Sensitivity calculation is really straight forward. See the following table dB Watt/ch 84 1 87 2 90 4 93 8 96 16 99 32 102 64 105 128 108 256 111 512 114 1,024 117 2,048 120 4,096 123 8,192 126 16,384 What you have been suspecting and what the above table confirms, is that you created a problem for yourself in selecting such low efficiency speakers. You really need an external amplifier to drive these speakers and a massive one at that, especially if you also use these in a home theater. THX reference level is 105 dB, which requires 128 watt/ch amp to reach. Your receiver just cant get there. Further, dynamic peak content in films and certain music require another 20 to 30 dB. Thus for 125 dB peak to be reproduced without amplifier clipping, your speakers would require about 16,000 watt/ch. Obviously you have a problem. First of all I do not know of any consumer amps delivering this type of power. And second, even if there was one, at that power level it would melt your speakers. I feel sorry for you and others that insist on making the mistake of buying these low sensitivity speakers. If anyone want true music and theater reproduction, they really need to focus on speakers with high sensitivity. Your old speakers with 93 dB/watt would be the lowest efficiency speakers I would even consider. I have Klipsch RF-83 with 100 sensitivity which I am driving with a Onkyo 905, which is 140 watts/channel. Even with this high sensitivity, I will be upgrading to an external amp with 500 watts/ch to get the most realistic home theater reproduction (with no clipping). The Onkyo can get the RF-83s to reasonable loudness. However, these spekers love power. The more you give them, the better they sound - not just louder, but bass and percussion gets tighter and more controlled. | ||||
| | #3 | ||||
| Re: Sensitivity Question First, BleedingStar only selected these speakers because he got a deal he could not pass up. Second, if I were to listen to music or movies in my space at 105 dB with peaks of 125 dB I would likely go deaf, my wife would leave me, and the cops would be knocking at the door. I don't know how large his listening area is, but I doubt it is large enough to require 16,000 watts for satisfying audio levels. I typically listen to music at 85 dB (perhaps rare 105 dB peaks) and it is plenty loud as two people next to each other would have to raise their voices significantly to have a conversation. And remember there are two speakers not one. Then there is room gain. Finally, I think BleedingStar will find satisfaction with his new electrostats when paired with a power amplifier such as the Tapco Juice J-2500 for $400. I agree it is unfortunate he has such inefficient loudspeakers but it is not the end of the world. With two speakers and room gain it is going to look more like: dB Watt/ch 91 1 94 2 97 4 100 8 103 16 106 32 109 64 112 128 115 256 118 512 121 1,024 Of course no one would be sitting one meter from the speakers either. So, 32 watts/channel for THX standard (who actually listens at this level) and 1,024 watts/channel for peaks of 15 dB. Even if there is brief clipping at these peaks I contend few people listen at home to THX reference levels. Brian Florian says, "Simply stated, Reference Level is a standard, known, predictable and reproducible playback volume level. When movie sound tracks are crafted, they are done so on systems which are locked at this level. The sound artist does not play around with a big volume knob when doing his/her work. If the sound artist wants something to be loud, they make that sound loud within the sound track. When they want something to be soft, they make that element soft within the sound track. Movie theaters set their playback level by the exact same rules, so when the movie is shown, you hear EXACTLY what the sound artist heard when they were making the piece. Loud, soft, in-between, it's all there, and no one touches the master volume knob over the course of a two-hour movie. To achieve THX certification, components must play at this reference level without breaking, distorting, buzzing, rattling or any other distracting effects. Reference level is by any definition, objective or subjective, quite loud. It basically mirrors the dynamic range of the studio system, which in the case of all movie sound tracks, is 105 dB. Any single channel of the system is calibrated to play 0 dB FSD (the loudest sound the sound track can contain) at 105 dB (115 dB for the LFE channel). While that is really, REALLY loud, its important to remember that there is 105 dB of dynamic range and the artist can put a sound at any level they want. So while a system's volume may be set to reference level, dialogue within the sound track can, and most often is, at a normal, natural level. Reference level, with the dynamic range available, permits a movie to have that normal, natural dialogue, and then suddenly a spectacular, loud car chase without anyone touching the volume control. Every element in the sound track comes out as it should." So, my current understanding of the THX reference is that the peaks are likely to be 105 dB, not 125 or 135 dB. So, at BleedingStar's hypothetical listening position 12 feet from the loudspeakers here is how it might look: dB Watt/ch 79 1 82 2 85 4 88 8 91 16 94 32 97 64 100 128 103 256 106 512 So, with a 500+ wpc power amp it is likely that THX reference levels indeed can be approximated. Sorry for all the edits, stream of polemics I guess. Last edited by jackfish; 02-07-08 at 11:41 AM.. | ||||
| | #4 | ||||
| Re: Sensitivity Question I believe it is common for most speakers to have an efficiency in the high 80s or low 90s. While the Kipsch may have a very high sensitivity, I believe that they are uncommonly high and far from the norm. Correct me if I'm wrong. Bob I would also second Jay's comments. "There is always hope, even if it is just a fool's hope." | ||||
| | #5 | |||||||
| Re: Sensitivity Question Quote:
As far as realistic production goes there are far more important things than sensitivity such as on/off-axis response, cabinet resonance, etc...This is of course assuming sound reproduction without any degradation at all and maximum pleasure as shown by perceptual research - something few to no commercial speakers are capable of. Quote:
Andrew | |||||||
| | #6 | |||||||||
Since I doubt you have the hardware to analyze your amplifier wave forms under the conditions you play music; I recommend that you play some music that you find important to play at 'louder' volumes when you do listen to it.Now, play it at low volume, then turn it up to your 'reference' level. Do you hear any changes that could be defined as 'brittle/harsh/squashed' sound when you go from soft to loud volume? ([I]Do not count simple treble/bass tonal difference; the human hearing system is more sensitive to high and low frequencies as the SPLs increase, as a natural function of how our brains are wired.) If you do hear a difference fitting that rough description, it is likely you are clipping the amplifier output, as that is the typical sound signature that starts to occur when running a common solid state amplifier just over the edge of clipping. The solution would be to add on a high power amplifier; a pro sound amp would be the most cost effective solution if this is needed. -Chris | |||||||||
| | #7 | ||||
| Re: Sensitivity Question To a certain degree you are all correct. A lot will come down to the normal listening level in the home and the degree of clipping (inaccurate reproduction) you are willing to accept. 1 - I would be extremely unsatisfied with 84 sensitivity speaker output in my home theater. These just have no way of performing satisfactorily in my home theater, especially with a 100 w/ch receiver. 2 - The Klipsch RF-83s, despite their very high sensitivity, have impedance dips to around 3 ohms in certain frequencies. As I said these speakers love power. When watching movies with the Onkyo 905, I have the volume at around -3 to 0 dB. I do not turn it up more as I do not want any clipping during the peaks. And this is in a temporary location with no sound treatment. When I move my system into my HT with sound treatment, when it is finished, the Onkyo will not have sufficient power. 3 - Dynamic peaks are what drive the need for power, not average loudness. The 20 dB dynamic peak is an average. Certain sounds require well above this level, pushing 40 and up to 60 dB. If you don't care about clipping and the associated distortion and missing reproduction, then you may well be satisfied with low efficiency speakers with an average receiver. However, if you care about faithful, undistorted sound reproduction - if you know what it sounds like with high quality and efficient speakers, then you want the most power you can afford. That is why even the RF-83 speakers NEED more than 140 watts/channel for pure and unclipped dynamic peak reproduction. Bottom line is that it all depends on what your listening habits are, combined with your expectations. YOU, not I, or anyone else should be the judge. I only offer my OPINION and attempting to raise awareness. I am definitely not telling what others should do. | ||||
| | #8 | ||||
| Re: Sensitivity Question I agree with Andrew, Just an added point: You have to remember that actual db readings will vary from space to space. In a dead room with lots of absorbing surfaces a speaker will need to output higher levels to "fill" the space with a certain db level where as a bright room with bare walls will require less. If you place your speakers in a large living room they simply wont get the db out of them to fill the space compared to a small room. Also with the new digital surround systems you have all 7 channels outputting volume levels that will add to the db levels in the space meaning that your main speakers don't work as hard. If I was to run my system at a constant 105db (and it would have no problem doing so) my whole family would leave as thats way louder than any movie theater runs at. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #9 | ||||
| Re: Sensitivity Question Yeah, I don't think i've ever watched a movie at 105 db, that sounds like a little much to me. I don't have the proper tools to measure what I actually do listen to it at, but its nothing extreme. Considering I live in a apt complex, I would most definitely be kicked out if i listened out 105 db, not to mention probably be deaf within 5 years since i watch movies every night. I've never watched a THX certified Dolby Digital movie with volume on my receiver higher than -20 db. So i'm not too concerned about any clipping effects just at this point. Thank you a ton for all the answers, great things to know. | ||||
| | #10 | ||||
| Re: Sensitivity Question My curent main speakers have similar ratings as your old ones did: 2 way reflex 38-20,000hz 4ohm sensitivity 93db Max SPL 113db continuous 200watts crossover 2.3khz Efective volume 57 litres But in my room they really need to work when in two channel Pure mode as the room is fairly dead so I know where your coming from. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #11 | ||||||
-Chris | ||||||
| | #12 | ||||||
| Re: Sensitivity Question [quote=WmAx;79651] Quote:
-Chris | ||||||
| | #13 | ||||
| Re: Sensitivity Question I am sorry Dionyz, I think I must have used an incorrect button intended for moderation( I suspect I accidentally clicked 'EDIT' instead of 'QUOTE' since they are side by side.). ![]() Please edit your post to restore the original (as close as you remember) statements. I don't know how to restore it, as I did not quote all of your text - so only part is left. I was just made a moderator, so I'm afraid I am not yet familiar with all of the functions. -Chris | ||||
| | #14 | |||||
:raped:, things happen!hyghwayman - Thanks for the edit ![]() Last edited by hyghwayman; 02-13-08 at 10:26 AM.. Reason: Thanks | |||||
| | #15 | ||||
| Re: Sensitivity Question I am getting ready to buy the SBS-01 5.1 speaker system from SVSound.com which have these specs.. Specifications Model NameSBS-01SCS-01 Frequency Response (Anechoic)68Hz - 20kHz ± 3dB - mains, rears and center Nominal Impedance - 8 ohms Sensitivity - 85dB fronts and rears, 87dB center Power Handling - 20w to 120w Sub - +/- 3dB from 20-100 Hz I will be using my Pioneer VSX-816 to push these speakers, which is rated @ 110w (20 to 20k Hz, THD 0.7%, 8ohms) stereo Will my receiver work ok with the SVS speaker ?Also should I worry about the sensitivity of these speaker? Thanks, hyghwayman Last edited by hyghwayman; 02-14-08 at 12:00 AM.. Reason: add ? | ||||
| | #17 | ||||
| Re: Sensitivity Question It was my understanding that the THX certified peak level is 105dB. That would be the loudest anything will go in a THX certified theater. Maybe dialog and normal volume scenes might be at 85dB as people have stated. Also most good amplifiers (including integrated A/V receivers) have some dynamic headroom. The watt rating given is usually for 2 channel continuous at a given distortion level. Most reputable manufacturers rate their amps at a non-clipped distortion level and the better ones try to rate the lowest THDs. A cheap HTIB however (like many Sony's) may rate their watts at super high or peak levels with high THDs of 10%. 140W/channel at 10% THD would probably be more like 15W/channel at 1% THD. Likewise a receiver rated at 120W/channel at .05% THD may have a dynamic output of over 380W at 1% THD. Good receivers may even alter a clipped output to protect your speakers during periods of high dynamic output (soft clipping). Highwayman your Pioneer rated at 110W @ .7% THD would probably start clipping at higher volumes. It probably won't sound great much past -40dB on it's volume scale. Q: Have you gone deaf yet Dionyz? I think your assumption of 105dB +20-30dB headroom is a little high. 130dB will cause your ears to hurt (damage), 135dB will make you go deaf in no time flat even if just in short peaks. Last edited by MatrixDweller; 02-14-08 at 10:01 AM.. | ||||
| | #18 | |||||
I hit peaks of around 130db in most movies, with the average/delta db of 85db, A-weighted, with A-weighted peaks around the 105-115db, at listening position. | |||||
| | #19 | ||||
| Re: Sensitivity Question True ultra low frequencies below 30Hz take a lot more sound pressure to be heard and to damage your ears but the sub and speakers are going to produce a lot of low-mid and mid bass also. The hair cells in your ear do not have the capacity to heal themselves. 80dB or higher over prolonged periods will cause hearing damage. So even though each time you watch a movie you only loose 1/10,000 of your hearing capacity, do it enough times over your life span you'll be hard of hearing. http://www.nidcd.nih.gov/health/hearing/noise.asp Who knows though with medical technology they might be able to grow you a new ear or use nanotechnology to repair it in the future. | ||||
| | #21 | |||||
MatrixDweller is correct about the max spl in films. Unless you deliberately set your volume higher than 0db, 105 will be the max peak level to come out of your main speakers. OP - With your relatively low sensitivity speakers, you'd need approx 128 watts to reach max playback in movie material, which is quite rare and only usually lasts for brief moments in time. Most quality amps will have a dynamic headroom above their rated power for such instances | |||||
| | #22 | |||||
To add to your point thxgoon: In the case of even order distortion, that is usually found in tube amps, 10% THD might sound good. Even order distortion happens on the octaves (sounds like a chord) and can make music sound warmer. 10% in a solid state amp is normally odd order distortion which typically sounds pretty bad. Hense why you'll see a $5000 tube amp with a THD of 1% and a $5000 solid state amp with a THD of .002%. So 0.7% might not be bad depending on how that distortion manifests itself. | |||||
| | #23 | |||||
![]() -Chris | |||||
| | #24 | |||||
-Chris | |||||
| | #25 | ||||
| Re: Sensitivity Question Good points, thanks Chris ![]() | ||||
