Home Audio Speakers
Where to buy replacement speakers
Discuss Where to buy replacement speakers in the Manufactured Speakers and Subwoofers forum; Where to buy replacement speakers I have two large speaker cabinets, 36" wide X 24" deep X 24" high that I inherited from my father. ...
Views: 2118 - Replies: 4
Old 02-08-08, 10:56 PM   #1
yellownslow
Inactive
Alias:
User: #
Posts: n/a
I have two large speaker cabinets, 36" wide X 24" deep X 24" high that I inherited from my father. He purchased them in 1958 as part of his "component stereo system" and the speakers as you can imagine are pretty much gone. I would like to restore the solid wood cabinets and replace the speakers but I'm not sure where to go for speakers large enough to fill them.
Old 02-08-08, 11:10 PM   #2
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
  yourgrandma is offline
Re: Where to buy replacement speakers
Hello and welcome to the 'Shack.
I think a good place to look would be www.partsexpress.com . They have tones of drivers.
You would first want to determine what yu need though. What kind o speakers are they? How many drivers per cabinet? Do you know the crossover specs? Cabinet volume? These are important to choosing the right drivers. Intended use playe a big roll, too. What are you going to use them for?
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 02-08-08, 11:10 PM   #3
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
Parts Express
Madisound
http://audiotools.com/drivers.html
You will have to do an evaluation of the cabinets to determine the best drivers to use with them. Particularly the internal volume. Then you can match a low frequency driver to the cabinet and then other drivers that are complementary.
Old 02-08-08, 11:15 PM   #4
yellownslow
Inactive
Alias:
User: #
Posts: n/a
yourgrandma wrote: View Post
Thanks for the info. Sounds like I have some work to do. I'll have to get back to you...
Old 02-09-08, 10:05 AM   #5
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
  jackfish is offline
I forgot to add you will likely have to use a new crossover system as well that is matched to the drivers you choose.
