| Home Audio Speakers Are these speakers any good?Discuss Are these speakers any good? in the Manufactured Speakers and Subwoofers forum; Are these speakers any good? I was looking at buying some new speakers for my future home theatre project. I almost bought some of the ... |
Views: 947 - Replies: 9
| Are these speakers any good? I was looking at buying some new speakers for my future home theatre project. I almost bought some of the best buy klipsh they had...cant remember model. Then i found a for sale add on a forum im always on and ended up with some jbl speakers. I think he said they were about 7 years old. Not sure if newer ones are any better or what. Heres what i got 2 HLS620's 1 Northridge Series center 2 HLS410's They sound way better than my old KLH system but thats probrably not saying much. When i found these i was looking to spend $1000 or less and bought these for $200. I found the suggested price for the HLS620's back in the day was $600 each. Did i waste my money? | ||||
| | #2 | |||||
| Re: Are these speakers any good? Quote:
![]() In the other hand, you saved $800 for your next big upgrade ... just take your time, audition as many as you can and save more money to get some nicer speakers ![]() I own a pair of JBL Venue Stadium ... they sound really good, but I read that there are better choices within JBL and other brands like Paradigm, Martin Logan, Definitive Technologie, etc. ![]() | |||||
| | #3 | ||||
| Re: Are these speakers any good? If you didn't get the owner's manual here you go: http://manuals.harman.com/JBL/HOM/Ow...LS620%20om.pdf http://manuals.harman.com/JBL/HOM/Ow...N24AW%20om.pdf What are you thinking about for a subwoofer? | ||||
| | #4 | |||||
What is a good reciever to push these speakers for under $450? That is my next question......should i find a matching jbl or go other brand....agian would like to stay in the $450 range or less. Thanks guys!!! | |||||
| | #5 | ||||||
I'm not a big believer in speaker/receiver "synergy". I also don't think there is a huge difference in sound between name brand receivers in the same price range. Therefore, what I'd look for are the features/remote/reliability that you like in a receiver. I think right now, the value leader is Onkyo. For that kind of coin, you could get the TX SR-605, and MAYBE the TX SR-705. Quote:
Anyway, that's the world according to me.. Good luck and happy listening. JCD | ||||||
| | #6 | ||||
| Re: Are these speakers any good? Oh.....i always thought when it said "recommended" you should have almost or equal to that much power to them.......They way i interperet it was if you only had 100 watts you went doing the speakers any justice..... and if they stated a max wattage to just ignore that and only look at the rms wattage......now after knowing that....what is recommended wattage mean then? | ||||
| | #7 | |||||
I looked at the PDF's for the two JBL speakers referenced above and only saw "recommended maximum amplifier power". Is this the recommended wattage you're referring to? JCD | |||||
| | #8 | ||||
| Re: Are these speakers any good? I guess i read that wrong....should have one of those turn sideways monitors!!! | ||||
| | #9 | ||||
| Re: Are these speakers any good? For subs SVS and Hsu are hard to beat. Unfortunately, the cheapest I've seen the Onkyo TX SR-705 for is $600. The TX SR-605 for $400. But even the TX SR-605 has enough power for those speakers unless you have a cavernous room. | ||||
| | #10 | ||||
| Re: Are these speakers any good? The manual said "max recommended power", not peak power. So I would take that to mean continous or RMS power. So for the 620s that would be an amp rated at 200w or there about. When my HT consisted of 7 L212s that are only rated at 100w, I was using a Parasound 220wpc amp, never hurt a single one of those 30 year old speakers. As for your HK receiver, get one that has L7 processing, like a 635 or newer model. The L7 sounds much better than DD. | ||||
