Home Audio Speakers
Hearing Damage
Discuss Hearing Damage in the Manufactured Speakers and Subwoofers forum; Hearing Damage I saw mention of the threshold for hearing damage in another thread and remembered seeing this. It is good visual ...
Views: 732 - Replies: 6
Old 03-12-08, 05:25 PM   #1
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is online now
Hearing Damage
I saw mention of the threshold for hearing damage in another thread and remembered seeing this. It is good visual reference for anyone concerned with hearing damage. Most of us are probably fine, but I have a couple of clients that should look hard at it. The big concern these days is the level on headphones.
http://www.cdc.gov/niosh/topics/nois...okatnoise.html
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 03-13-08, 07:19 AM   #2
Alias: Don
hyghwayman's Avatar
Loc: Miamisburg, Ohio - USA
User: #15542
Since: Jan 2008
  hyghwayman is offline
Re: Hearing Damage
Thanks for the link LC
Old 03-13-08, 08:47 AM   #3
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
Re: Hearing Damage
Thanks for bringing this up. I'm amazed when I read folks bragging about being able to get 100, 105 or even 120 db out of their system, especially their subwoofers.
I cranked my current system up to what I thought was loud, the very loudest I was likely to play it. It averaged around 80-82 db, with occasional peaks hitting 88db. This was much louder than I normally play it.
I also wear hearing protection when working with power tools. Sometimes it's a PITA, but Father Time is diminishing my hearing enough as it is without me helping!
Doug
Old 03-13-08, 09:49 AM   #4
Alias: Andrew
avaserfi's Avatar
Loc: College Station, TX
User: #9992
Since: Jul 2007
  avaserfi is offline
Re: Hearing Damage
DougMac wrote: View Post
There are differences between frequencies and how they effect hearing. For example: one can be in a room with a subwoofer playing a 30Hz tone at 120dB without any hearing loss due to their size, but put the same person in a room with a 500Hz signal at that level for an extended period of time and it will be very painful...This is why it is perfectly safe for one to have their subwoofer capable of 100+dB with no danger.
Just remember, this is a good, but simplified version of the situation.
Andrew
Old 03-13-08, 03:09 PM   #5
lcaillo's Avatar
User: #328
Re: Hearing Damage
Remember that with music and movie content, you don't have continuous levels all the time. The durations that they give are for noise at constant levels on a daily basis.
Old 03-13-08, 03:45 PM   #6
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
  superchad is offline
Re: Hearing Damage
I think its easy to get peaks over 100db but general audio level within those peaks is much less, but I do listen around 90-95db for extended periods. One may consider if their system is too much at higher volumes it can not only be their comfort level but also lack of amp power, lower performance speakers and associated gear or poorly placed speakers and bad accoustics.
I have had systems that couldnt crank because they didnt sound good....but a well performing system in a good room will surprise many as to how loud one can listen and still be pleased with its sound. A prime example, my dad went from Legacy speakers and Lexicon pre to Vandersteen speakers and Audio Research tube pre, his listening increased 10db instantly as it still sounded fantastic at higher levels, all along it wasnt the volume that was the problem,,,,,,,,,,,,,,it was the system.
Old 03-14-08, 05:24 AM   #7
Alias: jakewash
Loc: Calgary
User: #13879
Since: Nov 2007
  jakewash is offline
Re: Hearing Damage
As soon as you go above the rated db levels for your speakers the amp requirement go up significantly per channel in order to handle the momentary spikes cleanly. There area number calculators on the web that will show you the extent of this increase.
Listening at 80 db on speakers with a sensitivity of 91db, listening at 8ft away and music with a dynamic range of 10db, it now takes about 5W per channel to cover the dynamic range, increase that 80db at the listening position to 95 and it now takes about 150W to cover the range.
This makes it easy to see why it is hard to drive speakers to very loud levels cleanly.
