How much for Velodyne HGS? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss How much for Velodyne HGS? in the Manufactured Speakers and Subwoofers forum; How much for Velodyne HGS? I recently ran across a used HGS-18 or 15 (Not sure exactly) in gloss black. Provided it's in perfect working ...
Old 03-14-08, 12:32 AM   #1 (Link)
Alias: Kioko
kioko12's Avatar
User: #12692
Since: Oct 2007
kioko12 is offline
I recently ran across a used HGS-18 or 15 (Not sure exactly) in gloss black. Provided it's in perfect working order (cosmetically, it looks good), how much would it be worth?
Old 03-16-08, 01:01 AM   #2 (Link)
Loc: Lower Alabama
Re: How much for Velodyne HGS?
I sold a couple of NIB HGS-15's about three years ago for about $1500 each. I sold my used one for I believe $1100. There is a used 18 on Audiogon for $1250, but it is rated 7/10.
My guess... 15 - $900-1100 and 18 $1100-1400. Just a guess.
Old 04-06-08, 11:12 AM   #3 (Link)
Alias: Steve
Loc: Boston
User: #12794
Since: Oct 2007
Steve. is offline
Be careful with the HGS line, they had an extremely high mortality rate with their original amp design. I have an HGS 10 which I liked a lot but ultimately the amp failed. I had always thought Velodyne was one of the better subs out there but given the fact that Velodyne knew about the failures with these amps and didn't offer an exchange to early adopters I couldn't justify spending $400 to fix it and couldn't afford a DD 10 or 12. In all honesty their knowledge of high failure rates and lack of proactive response to the problem shook my confidence in them. I have a SMS-1 so the DD series wasn't a necessity so I ended up getting a REL R-305. It sounds much better than the HGS 10 it replaced.
Old 04-20-08, 07:33 AM   #4 (Link)
Alias: Bigdaddy
User: #4007
Since: Nov 2006
Bigdaddy999 is offline
I second the comments, but I will also say that you can readily determine if the amp has been upgraded. I bought two HGS-12's last year and worked with Velodyne service to confirm the seller's statements based on the Serial Numbers on the plate amps. Velodyne was GREAT to work with on this and keeps complete records of servicing.
I would suggest you verify the upgrade has been done this way and go for it! Great subs.
Old 06-02-08, 09:04 PM   #5 (Link)
New Member
Alias: swestbom
Loc: Newton MA
User: #20122
Since: Apr 2008
swestbom is online now
Bigdaddy999 wrote: View Post
How about an HGS-12 serial number from October 2000? Is this the upgraded amp (the remote sensor input is in the same place as in the X version, not inline like the earliest HGS subs).
Old 06-05-08, 08:29 AM   #6 (Link)
Alias: Jim
Loc: Wetumpka
User: #630
JimP is offline
A used HGS-15 in fairly decent shape should go for around $1K. Problem is that their drivers don't take to shipping very well and you may find yourself having to spend another $400 for repairs.
I have a HGS-15 in pretty good shape but due to the size of my room, I'm looking at upgrading to a BMF...if it ever comes out.
My advice.....if you can't arrange a local pickup with a seller, buy a new sub.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
Velodyne Thoughts kioko12 Home Audio Subwoofers 6 03-31-08 10:52 PM
Any experience with Velodyne CT-150 jhk Home Audio Subwoofers 2 11-27-07 09:22 AM
Velodyne lcaillo Manufacturer and Vendor Reference Information 0 04-30-07 10:54 PM
FS: Velodyne SMS-1 Josuah Classifieds - Equalization and Calibration Equipment 0 12-01-06 11:04 PM
Velodyne DPS-10 Exocer Home Audio Subwoofers 0 06-08-06 06:35 PM
Mach 5 Audio
