Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Manufactured Speakers | DIY Subwoofers > Home Audio Subwoofers
  Discuss JL Audio Fathom subwoofer advice needed in the Manufactured Speakers | DIY Subwoofers forum; JL Audio Fathom subwoofer advice needed Hi, I have ordered a Sunfire CRM-2 5-channel set and I want to add 1 or 2 subwoofers to it. ...
Views: 799 - Replies: 2
Old 03-15-08, 12:55 PM   #1
New Member
Alias: Flavio
Loc: The Netherlands
User: #18230
Since: Mar 2008
  Flavio is offline
Hi,
I have ordered a Sunfire CRM-2 5-channel set and I want to add 1 or 2 subwoofers to it. I have pretty much decided to get the JL Audio Fathom series (mainly because of WAF) but am undecided which one(s)?
What would better integrate with the Sunfire's, a single f112, a single f113 or dual f112's? Dual f113 might strethc my budget too much. I have a large room (7500 cu.ft) and I like to play at reference levels. Specs on the f113 show the -1.5dB point is at 87Hz so I am a little worried there will be a gap because the Sunfire's only play from 100Hz up.
Old 03-16-08, 12:48 AM   #2
Owner
Loc: L.A. (Lower Bama)
Re: JL Audio Fathom subwoofer advice needed
Welcome to the Shack Flavio!
This is hard to say... I do not know of anyone posting regular here that owns the Sunfire speakers. With that much room I would suggest a pair of either... if you have the budget, go for a pair of the f113's. My room is much smaller at 1800ft^3 and I have a pair of PC-Ultras and dual 15" Soundsplinters in the back... the Behemoth. All I can say is awesome!
Old 03-18-08, 02:37 PM   #3
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
  ccdoggy is offline
From my experience with the Fathom 113 it matches really well with just about any speakers and with its "EQ" placement is not as critical.
I would say it all depends on how big your room is and how much bass you want. a single 113 is very impressive, dual would be awesome.
You may not want/need that much as the speakers you listed are rated for a max output of 115db, i would think depending on the room a single 113 might be able to keep up with it. Although dual is always better.
« Home Theater Shack > Manufactured Speakers | DIY Subwoofers > Home Audio Subwoofers »
Bookmark and Share
Dish Network
