comparing JL audio, Revel B12, Velo and SVS?? - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss comparing JL audio, Revel B12, Velo and SVS?? in the Manufactured Speakers and Subwoofers forum; comparing JL audio, Revel B12, Velo and SVS?? Rod, So what's happening? I just came on this thread. Did anyone suggest that he measure his room to see ...
Old 06-05-08, 02:01 PM   #26 (Link)
Alias: Jim
Loc: Wetumpka
User: #630
JimP is offline
Re: comparing JL audio, Revel B12, Velo and SVS??
Rod,
Did anyone suggest that he measure his room to see if its the sub or the room that's causing his problems?
Old 06-05-08, 02:19 PM   #27 (Link)
Alias: rodH, Rodney
User: #18985
Since: Mar 2008
rodH is offline
JimP wrote: View Post
Rod,
I have decided to build my own. I am in the finishing stages of my enclosure. Sealed design ~4.0 cu ft with 2 12" TC1000 drivers, using a velodyne Sc1250 (1250w RMS, 3000w peak) amp with a built in PEQ. It is taking longer than I thought it would, about a week left.
Old 06-06-08, 03:49 PM   #28 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
Hey RodH,
The SC1250 got tested over at AVS and it acquitted itself pretty well. It put out a solid 1000watts.
Old 06-06-08, 04:17 PM   #29 (Link)
Alias: rodH, Rodney
User: #18985
Since: Mar 2008
rodH is offline
Ricci wrote: View Post
Hey RodH,
is that a surprise that is actually produces what it claims? Why does one channel produce 2X the power of the other?
Old 06-07-08, 01:04 AM   #30 (Link)
Alias: doubeleive
Loc: stockton, ca. 95219
User: #12968
Since: Oct 2007
doubeleive is offline
i just want my sub's to sound like it does when I go to a concert, atleast at the arco arena the bass is litterally earth shattering, totaly and utterly amazing, now what...
Old 06-07-08, 11:28 AM   #31 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
rodH wrote: View Post
I was just trying to be helpful.
Old 06-07-08, 06:04 PM   #32 (Link)
Alias: rodH, Rodney
User: #18985
Since: Mar 2008
rodH is offline
no, no, no. I wasn't trying to be a jerk, it was a sincere question. I didn't know that a lot of these amps are overrated. I know you were trying to be helpful, and you were, and thats why I have jumped on that thread. I am sorry if you took it wrong. Thanks for the info.
Old 06-10-08, 01:40 PM   #33 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
It's all good man. I thought you were kind of shooting the messenger or something. To answer your question. Yes it is. It seems like most of the amps tested put out nowhere near what they are rated at under the admittedly harsh test proceddures..
Old 06-10-08, 08:01 PM   #34 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
the test on the left side is the 8ohm test, the one on the right is the 4ohm test which is why the one on the right is almost twice that of the left "channel"
though in reality, there are no channels it's a mono amp.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
svs B12-Plus/4 specs matt98svt SVSound 12 02-21-08 01:45 PM
Re-creating Revel F50a speakers erpiii DIY Speakers 7 01-10-08 08:35 AM
Two Velo 12's or a single 15"? Bigdaddy999 Home Audio Subwoofers 19 09-27-07 06:38 PM
Comparing SPL Meters apbcom REW Forum 3 03-16-07 08:28 PM
What SV box sub comparable to Velo DD-12? Huck SVSound 14 03-09-07 11:01 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
