| Home Audio Subwoofers Custom RE XXX Subwoofer BuildDiscuss Custom RE XXX Subwoofer Build in the Manufactured Speakers and Subwoofers forum; Custom RE XXX Subwoofer Build Well I'll be darned . . . . there you are, deep inside the tuned portion of your project!... |
Views: 5315 - Replies: 103
| | #52 | ||||||
| Re: Custom RE XXX Subwoofer Build Quote:
ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||||
| | #53 | ||||
| Re: Custom RE XXX Subwoofer Build By the way this is what Unibox predicts for this sub...Not too bad . Also ignore the lowest port resonances. The special porting system used should not have these.![]() ![]() ![]() | ||||
| | #54 | ||||
| Re: Custom RE XXX Subwoofer Build Josh, how long until the sub is at your place? | ||||
| | #55 | ||||
| Re: Custom RE XXX Subwoofer Build I'm not real sure . Nathan is still working on the cab. I believe he's got the basic structure done and now he's doing the veneering and wrapping things up. I've sent him one of the 18's and it should arrive at his place on the 22nd. From there hopefully he'll be ready to mount it and do some listening tests before getting ready to ship it. The shipping is probably going to be at-least 10days. I guess I hope to have it by this time in June. ![]() | ||||
| | #56 | ||||
| Re: Custom RE XXX Subwoofer Build That thing is a monster, Ricci! I hope you have good relations with the local law enforcement agents! One thing if note, while the port is physically 10" in diameter, you are occupying the cross section width with another cylinder of wood. Typical 10" port rules no longer apply. It will model as a smaller diameter port with an enormous flare. Not a bad thing! Dr V | ||||
| | #57 | ||||
| Re: Custom RE XXX Subwoofer Build The port area left is equal to a 9.375"dia port. and if the tuneing is what has been predicted the overall length including the flow guides will still be less than a 9.375" port would need to be to tune to the same frequency. Nathan Funk Funky Waves Audio | ||||
| | #58 | ||||
| Re: Custom RE XXX Subwoofer Build The projected peak airspeed is right at 35ms at 10hz with the port area readjusted as a 9.375" unit. This is at full on peak output though. I doubt that there will be problems with chuffing or port compression. The huge flares and the flow guides should take care of buisiness. ![]() A regular 9.375" port would still need a straight pipe of 55.75", compared to 36.5" for this design. ![]() | ||||
| | #59 | ||||
| Re: Custom RE XXX Subwoofer Build Ricci, This is not to mention that typical program material will be better represented by RMS velocity as opposed to peak. ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #61 | ||||
| Re: Custom RE XXX Subwoofer Build That's one big beautiful sub ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #62 | ||||
| Re: Custom RE XXX Subwoofer Build Man that looks pretty good Nate! Not quite as dark as I thought it would be, but it looks nice. I bet it was easier to test mount that top assembly with out the motor on it. This is gonna be one big, professional looking, overbuilt, over-engineered, monstrosity of a sub. | ||||
| | #64 | ||||
| Re: Custom RE XXX Subwoofer Build I think I'm going to have to name this thing... | ||||
| | #66 | ||||
| Re: Custom RE XXX Subwoofer Build That looks really good. I can't wait to see...wait... experience it in person. If ever a gimongous subwoofer cab could look good, this is it. I'm still stunned by those spl readings down low too. | ||||
| | #67 | ||||
| Re: Custom RE XXX Subwoofer Build EXCELLENT! I would like to see an actual FR at LP ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #68 | ||||
| Re: Custom RE XXX Subwoofer Build Blaser, Look in the Battle of the Monsters thread located here in the FunkyWaves section. Nathan tested the max spl output before audible distortion and also took a frequency response measurement. It's at his place and not mine though. | ||||
| | #69 | ||||
| Re: Custom RE XXX Subwoofer Build It looks awesome... and man is it intimidating! I like the handle too, that just seems to take it to another level of saying "I mean business!". The enclosure makes the woofer look tiny, which is no small feat! | ||||
| | #70 | ||||
| Re: Custom RE XXX Subwoofer Build Looks like this Behemoth is going to be shipping out, with the Dual SDX15 sub that Nathan built for me for winning the giveaway contest, today. I'm stoked . It's going to be hard to wait the week or so that it's going to take to recieve them. Look for lots of listening impressions and pictures when I get them. I'll also do some testing down the road, but I have to get a new laptop first. Excuse me while I double up on my work-out regimen, in preparation for massive subwoofer wrestling sessions to come. ![]() | ||||
| | #71 | |||||
![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||||
| | #72 | ||||
| Re: Custom RE XXX Subwoofer Build The sub is sitting in my living room and it is beautiful. The packaging was stellar with nothing out of place what so ever. I can't fire it up until tomorrow. I have to get Speakon cables. It is gigantic and I only put one small ding in it getting it in the house(doorway. not a big deal), which is not bad considering the size and weight of it and the fact that it was just me and one other guy. | ||||
| | #73 | ||||
| Re: Custom RE XXX Subwoofer Build Congratulations Josh! It must be very exciting getting a new toy like that. You know we want to hear your impressions once you get it going, but we also want more pictures!! Do you have this monster in a corner, or is it out in the open? | ||||
| | #74 | ||||
| Re: Custom RE XXX Subwoofer Build I finally replaced my USB cable for my Olmypus and got time to post up some pics, so without further adeiu... Here's the crate with love from Canada... ![]() ![]() Here's some shots taken during the dismantling of the crate. The packaging was first rate. ![]() ![]() ![]() ![]() Here's a shot right after we got both of the subs into the house that illustrates the size and girth of the XXX subwoofer cab. I'm the darkly tanned guy on the left !![]() Here's a shot of the SDX sub shot during one of many recuperation periods. As you can see it's no lightweight mini-sub either! See that staircase...yes it was a PITA. Thats my sister in the picture. The one with orange hair. ![]() Last edited by Ricci; 08-05-08 at 02:32 PM.. | ||||
| | #75 | ||||
| Re: Custom RE XXX Subwoofer Build Wait... what!? Where did the SDX come from? It's beautiful! Why don't I remember anything about that one being built? What kind of wood is it? The grilles look awesome too, I love how Nathan does those. | ||||
