Subwoofer Upgrade - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Subwoofer Upgrade
Discuss Subwoofer Upgrade in the Manufactured Speakers and Subwoofers forum; Subwoofer Upgrade Hi guys, I'm ready to replace my subwoofer or maybe just add a second sub. I have a 10x11x8 room ...
Old 04-18-08, 05:18 PM   #1 (Link)
Alias: Bozo
Loc: Florida
User: #7521
Since: Mar 2007
hallb76 is offline
Subwoofer Upgrade
Hi guys, I'm ready to replace my subwoofer or maybe just add a second sub. I have a 10x11x8 room with no openings. I'm looking for a sub to replace or run along side an stf-2 in a system for 50% home theater 50% music. I would like a sub that is at least as good as the stf-2 musically but has extension to ~15hz and more output for movies.
I am looking at the Rythmik DS15 sealed kit and the svs 16-46pci. Does anyone know how these subs would stack up against my current sub? I would appreciate any advice or opinions about a possible sub choice. I would also be open to any other suggestions in the $600 - $800 range.
Old 04-18-08, 07:11 PM   #2 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: Subwoofer Upgrade
I can't comment on the Rythmic kit as I've never actually heard them. Ikka did a test on the 12" version and seemed to be pretty positive about it.
And I don't think you can ever go wrong with an SVS. There entire line is generally considered to be some of the best at their respective price points.
Sorry I couldn't be more helpful.
JCD
Old 04-18-08, 07:42 PM   #3 (Link)
Alias: Bozo
Loc: Florida
User: #7521
Since: Mar 2007
hallb76 is offline
Thanks for the reply! Do you think the svs will perform as well as the hsu with music and still have more output in terms of spl?
Old 04-19-08, 05:26 PM   #4 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
With a native tune (and porting) for 16 Hz the SVS 16-46 PCi will deliver very low freq bass with no group delay for music bass frequencies (in other words "tight" bass). The drawback with the low tuning is a bit less max mid-bass output, but your room is small enough in volume that that should not matter. Very good choice if you do not want to DIY a subwoofer enclosure.
Old 04-19-08, 06:17 PM   #5 (Link)
Alias: Bozo
Loc: Florida
User: #7521
Since: Mar 2007
hallb76 is offline
Bob, thanks for the info. That's what I was hoping to find out. I run my sub 2ft directly behind my listening position to get rid of the boom. If need be I could corner load the svs t oget a little more mid bass output. I think the 16-46 is the sub for me but I still need to check out the rythmik DS15 kit. If there is little diferenct between the 2 subs I think I'll go with the svs.
Thanks again
Old 04-22-08, 07:20 PM   #6 (Link)
Alias: Bozo
Loc: Florida
User: #7521
Since: Mar 2007
hallb76 is offline
Thank's for the advise everyone, I just ordered a B-stock 20-39+ which sould hold me over for a few years now.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
To upgrade or not? MatrixDweller SVSound 5 12-04-07 09:03 PM
Need an upgrade tweeksound Video Displays and Processors 13 10-28-07 12:18 PM
upgrade jokers10 SoundSplinter 1 10-11-06 10:48 AM
Looking to upgrade Joshua Home Theater Equipment 3 05-18-06 11:16 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
