Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Confused - Passive Subs
Discuss Confused - Passive Subs in the Manufactured Speakers and Subwoofers forum; Confused - Passive Subs I currently have a chance at a used 16-46CS+, but I am confused about how I would go about hooking ...
Views: 414 - Replies: 1
Old 06-23-08, 08:43 PM   #1
Alias: John
John_Williams's Avatar
Loc: Richmond, IN
User: #742
  John_Williams is offline
I currently have a chance at a used 16-46CS+, but I am confused about how I would go about hooking it up. The manual gives the impression that you would need a traditional stereo amp, but a plate amp would be much more affordable. It appears to only have speaker terminals?
Could I pick up a plate amplifier from Parts Express or eD and be able to run it? If so, how exactly would I get this to work? Would I still be able to use my BFD?
Old 06-24-08, 06:38 AM   #2
Alias: Matt
hddummy's Avatar
Loc: ATL
User: #7380
Since: Mar 2007
  hddummy is offline
Re: Confused - Passive Subs
Yes, you can use a plate amp without a problem. Run the pre-out from your receiver through you BFD and into the plate amp input. The amp will have speaker terminals on the back. I have seen guys build small boxes or mounting plates to hold the amp since it is not actually built into the sub. I would suggest this from PE.
http://www.partsexpress.com/pe/showd...number=300-806
It has a back cover on it, so that should be good for you if you just build a little plate mounting stand. Also on a special price right now.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
