velodyne spl1000 in bigger box - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss velodyne spl1000 in bigger box in the Manufactured Speakers and Subwoofers forum; velodyne spl1000 in bigger box do u have some experience with giving any velodyne to bigger box? or know some thiel-smalle parameters of its drivers?...
Old 08-09-06, 07:10 AM   #1 (Link)
Alias: neophyte
User: #1939
Since: Aug 2006
neophyte is offline
Old 08-09-06, 07:19 AM   #2 (Link)
Shack City Slicker
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Re: velodyne spl1000 in bigger box
unfortunetaly, the T/S parameters of Velodyne drivers are unknown to the consumer. The only ways to go about finding it's T/S parameters would be to call Velodyne and ask them, or buy the Dayton woofer tester found here www.partsexpress.com and test the driver yourself. Something tells me the driver is designed for it's small enclosure and may very well run out of Xmax way too fast in a larger box powered by the same amp.
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 08-10-06, 03:01 AM   #3 (Link)
Alias: neophyte
User: #1939
Since: Aug 2006
neophyte is offline
any other ideas or experiences?
Old 08-10-06, 10:24 AM   #4 (Link)
Alias: sheldon
User: #13
bsheldon is offline
exocer I think is correct. I am sure velo specifically designs the the driver for the small enclosures they are put in.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Mach 5 Audio
