Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Klipsch Sub-12 / SVS PB-12 Plus Clone
Discuss Klipsch Sub-12 / SVS PB-12 Plus Clone in the Manufactured Speakers and Subwoofers forum; Klipsch Sub-12 / SVS PB-12 Plus Clone I like the looks of the SVS subs with integrated baseplate, but I can't afford to buy one anytime soon, ...
Views: 1100 - Replies: 4
Old 08-09-08, 05:09 AM   #1
Alias: Tom
tomscave's Avatar
Loc: Sunshine State
User: #14819
Since: Dec 2007
  tomscave is offline
I like the looks of the SVS subs with integrated baseplate, but I can't afford to buy one anytime soon, so I made a simple modification to my Klipsch sub. I used a piece of 3/4" birch plywood (cut the same width and depth as the enclosure) and some 1 1/4" diameter wood dowel cut 2" long, painted flat black. I used the existing screw holes on the bottom of the enclosure after removing the stock Klipsch feet. I like the look a lot better than with the stock feet and I haven't noticed any difference in bass.
Old 08-09-08, 01:18 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Klipsch Sub-12 / SVS PB-12 Plus Clone
tomscave wrote: View Post
I like the looks of the SVS subs with integrated baseplate, ....
Nice, looks good
IF you want you can remove the "name plate" to make others wonder what brand the sub is
Old 08-09-08, 01:23 PM   #3
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Nice modification, Tom. Looks good!
We're all in this together!
Members DIY Subwoofer Database
Old 08-10-08, 08:09 PM   #4
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Interestng, I like it and can't think of any downside.
Old 08-13-08, 10:29 PM   #5
Alias: Tom
tomscave's Avatar
Loc: Sunshine State
User: #14819
Since: Dec 2007
  tomscave is offline
Now that I've had a chance to play with the sub for the past few days, I like it setup this way. The bass sounds better and I can now "feel" the bass.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
clone, klipsch, pb-12, sub-12
