Bass Effects on Downmixing DD to Stereo and Spectrum Labs information - Page 3 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Bass Effects on Downmixing DD to Stereo and Spectrum Labs information in the Manufactured Speakers and Subwoofers forum; Bass Effects on Downmixing DD to Stereo and Spectrum Labs information Thanks Edd. I'll take a tour round the dealers to see what appeals....
Old 09-17-06, 03:11 AM   #51 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Re: Bass Effects on Downmixing DD to Stereo and Spectrum Labs information
Old 09-18-06, 07:52 AM   #52 (Link)
Exterminated!
Alias: Bosso
Loc: Charlotte, NC
User: #1597
bossobass is offline
The HK chopped off the first 1 second of audio when changing tracks because it has a feature to mute output from a digital audio connection when the signal is dropped or has no output.
This is why it appeared to be 'dead silent'. Mute function.
Bosso
Old 09-18-06, 09:27 AM   #53 (Link)
Loc: Lower Alabama
SteveCallas wrote: View Post
I don't find this too bad though, as pressing the button twice on the remote takes me about 1 second.
I figured you for a Home Theater Master, Pronto or Harmony.... one of the learning ones anyway. A macro at turn on solves pressing that button twice. Something tells me you already know this.
Old 09-18-06, 06:31 PM   #54 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Are you referring to the analog outputs being dead silent?
Nah, I actually like having seperate remotes - no way am I going to spend the time to program all the minute little functions. Also, if I want to keep testing a track on a disc, I can easily adjust receiver settings and work the dvd player with two remotes whereas with a universal I would have to get out of ones functions and go into the other. The only functions I may want to combine are those of the tv and HD cable box, and the universal remote that came with the HD cable box should be able to do that with ease.
Old 09-18-06, 07:00 PM   #55 (Link)
Exterminated!
Alias: Bosso
Loc: Charlotte, NC
User: #1597
It doesn't matter, the mute when no signal function applies to the outputs, which are all analog.
Also, I agree with your seperate remotes logic, even a step further as I don't have cable or any sort of TV. Only wealthy bachelors can afford HD cable
Bosso
Old 09-18-06, 10:31 PM   #56 (Link)
Alias: Steve
User: #263
No TV or cable? No football? How many movies do you typically watch in a month?
As for the HK muting with no signal, I never considered that that might be why it was dead quiet. I'll try muting my Yamaha later tonight to see if I can replicate the dead silence in the tweeters.
Old 09-19-06, 11:30 AM   #57 (Link)
Alias: Palmer
User: #2589
Since: Sep 2006
J_Palmer_Cass is offline
Ilkka wrote: View Post
It did the testing also with this configuration and the result was exactly the same as when you disable the center. 4.1, 3.1, 2.1, 4.0, 3.0, 2.0 - same SPL loss compared to 5.1 or 5.0.
Just like he says, only the DTS part is incorrect. I tested it too and DTS doesn't behave the same. There is no loss if you disable the center or surrounds. DTS doesn't carry any DRC information. Surprisingly DD 5.1 was only around 2 dB behind DTS at the same MV setting (Master and Commander).
So do remember that this happens only when playing DD tracks, DTS doesn't have this problem.
Just as a folow up, I ran some DTS tests on my system.
When I turned the center channel OFF, then DTS sounded the same as the full 5.1 sound.
When I turned the surrounds OFF, then DTS lost 6 dB of peak volume.
I have my mains set to large, and all other speakers are set to small, plus a subwoofer. There is no compression, but there is some type of change in either bass redirection or mix levels (or both) when the surrounds are set to off. I suspect it is simply bass redirection. Not sure if you get the same results if your mains are set to small.
Anyhow, DTS does sound good when you downmix. The downmix of DD sounds bad due that DRC downmix override function!
Old 09-19-06, 11:38 AM   #58 (Link)
Alias: Palmer
User: #2589
Since: Sep 2006
I have Sony receiver, and from what I can figure out only the analog inputs do not use a mute function. The digital inputs are hard to "listen to" if there is no digital input due to the typical mute function.
Anyhow, if you listen to a passage recorded at a very low volume on any active digital input, you can get a good idea of how quiet your system is. I can't hear any background "hiss" at -5dB from Dolby Reference Level MV settings when I am 1-foot from my speakers, so I am a very happy camper.
WARNING: You must know what you are listening to so you don't get blasted by high volume when you least expect it!
Old 09-30-06, 12:04 PM   #59 (Link)
Alias: Jesse S
Loc: Toronto, On
User: #1701
Jman is offline
What about the output option? If you set it to 2/0 stereo or 3/2+sw 5.1 there is a big difference in Speclab
Old 10-01-06, 02:43 PM   #60 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
J_Palmer_Cass wrote: View Post
That is really strange. I alse tested the same and max peaks were always identical. I could turn off the center, surrounds or both - no change (and my mains are set to large too). AFAIK DTS doesn't contain any DRC info. Which movie (scene?) did you try and which receiver you have?
Old 10-01-06, 02:45 PM   #61 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Jman wrote: View Post
You should use 2/0 stereo. Spectrum Lab monitors only mains channels, so all the material should be in them. You should also turn off "auto gain control" and "bass redir".
Old 10-05-06, 04:43 PM   #62 (Link)
Alias: Palmer
User: #2589
Since: Sep 2006
It is just the bass management of my reciever (Sony STR-DA4ES).
In some modes LFE and redirected bass are sent to both the R & L mains as well as the subwoofer. When I set the surrounds to OFF, then redirected bass goes to the R & L mains only, and only LFE goes to the subwoofer.
It is just a subwoofer calibration issue. I have to set my subwoofer down by 5 dB when LFE and redirected bass are sent to both the mains as well as the subwoofer. Same calibration method you use for running dual subwoofers.
Same issue when I set all the speakers to small. When they are all set to small, I have to add the 5 dB of gain back into the subwoofer input to get my bass back into calibration. I never use the downmix mode, so I never documented the bass redirection of my receiver in those downmix modes.
Old 10-16-06, 07:59 AM   #63 (Link)
Alias: edd
User: #2120
Since: Aug 2006
eddthompson is offline
Just to dig this up, i was exploring through the menus in my denon reciver, and lo and be hold there was :
Dolby Digital Downmix Dynamic Range Compression : on/off
well who would have thought if you use less than 5.1, have a look into denons
edd
Old 10-16-06, 10:29 AM   #64 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Ayreonaut is offline
That's cool, what model do you have?
I don't see that menu option anywhere on my AVR-1905, but it's one of their lesser models.
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 10-16-06, 11:10 AM   #65 (Link)
Alias: edd
User: #2120
Since: Aug 2006
i have the K-AVC1-SE , i dont know the american model number, but its one of their $3000 amps. I got it used for $1200, the uk is so expensive sometimes, even for used gear.
edd
Old 10-19-06, 09:08 AM   #66 (Link)
Alias: Palmer
User: #2589
Since: Sep 2006
Here is a posting from the AVS forum by Rober Dressler (Dolby). This should help out with this issue. It seems like the vast majority of receivers use the DRC ON method when performing "speaker management". It seems like some here have the DRC OFF when downmixing option. My receiver does not have that!
Anyhow, you learn something new everyday!!!
Roger Dressler
Advanced Member
Posts: 916 Quote:
Originally Posted by SpectralD
Unfortunately, it is actually in the Dolby spec that DRC is engaged whenever downmixing occurs. Shockingly, this includes downmixing LCR -> LR. They refer to it as 'overload protection DRC' in the docs.
Go figure.
Allow me to clarify. Downmixing can take many forms. In a DVD player, a 2-ch downmix is always (I have not seen an exception, but who knows) done with DRC activated. This ensures the average level is maintained while preventing clipping.
In an AVR, 2-ch downmixes will probably be done the same way. However, if it is desired to downmix without DRC, every Dolby Digital decoder IC knows how to do it. The output level is scaled down 11 dB, then there's no way to cause clipping.
In the case of "speaker management" as descibed here, the AVR may allow the decoder to run in full 5.1 mode, no DRC, then downmix the C into L/R with the usual -3 dB mix level. With a little bit of scaling in the DSP, clipping can be prevented, and the gain is made up in the analog stage.
The AVR maker can use this method, or they can use the "downmix in the DD chip with DRC on" method. It's their choice.
The tests described by others will show which mode the AVR is using.
__________________
Roger
Old 10-19-06, 10:04 AM   #67 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
eddthompson wrote: View Post
edd
Many receivers do have DRC control (mine too), but it doesn't seem to affect while downmixing (ie. it's overruled). Could you check whether your Denos does this too? Just run a short dynamic scene with center on and off. Check the peak SPL with your SPL meter. Are they identical?
Old 10-19-06, 02:15 PM   #68 (Link)
Alias: Palmer
User: #2589
Since: Sep 2006
Ilkka,
That DRC control is not the same as our DRC control.
The optional control that Ed has is special (and optional). It refers to downmixing in particular. Not sure how many receivers in any price range have that option.
"Dolby Digital Downmix Dynamic Range Compression : on/off"
Anyhow I use a full 5.1 system, so this it does not even apply to me right now. I was considering not using a center speaker in a second system that I am putting together, but I gave that idea up a while back after I figured out this DD downmix mess. The funny thing is that many people still insist that you can live without a center channel. If you question them, they respond like it's like a personal insult.
Put down the Sony STR-DA4ES in the DRC is applied during DD downmixing pile!
Old 10-19-06, 02:56 PM   #69 (Link)
Alias: Steve
User: #263
Lol In regards to audio, some people can't handle the truth.
Old 10-19-06, 03:07 PM   #70 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Sorry, I thought Ed meant the "normal " DRC. Though I would still like to see him testing it.
Many people insist that you can live without a center channel speaker. I was one of them until I discovered the DRC thing. I don't need center channel speaker for sound stage etc. because I always sit at the sweet spot. But due this DRC thing I now have to consider buying it...
Old 10-19-06, 05:04 PM   #71 (Link)
Alias: Steve
User: #263
Well not only are you going to get better highs and lows, you are going to spread the workload out over more speakers. Assuming you buy a third identical speaker, aside from having to spend money, this is a good thing.
Forum Rules
