Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Older Phase Technology subwoofer help
Discuss Older Phase Technology subwoofer help in the Manufactured Speakers and Subwoofers forum; Older Phase Technology subwoofer help Hello everyone, I am currently using a 15 inch Phase Technology Octave 1.0 sub. I have a few questions. I ...
Views: 340 - Replies: 3
Old 07-26-09, 11:57 AM   #1
Alias: matt
Loc: texas
User: #33423
Since: Feb 2009
  splatee is offline
Hello everyone,
I have noticed that the amp runs extremely hot. I was watching a movie the other night and it was so hot i couldn't touch it with out getting burned. And the wall behind it was very warm as well. I have the sub volume set at the 8 oclock position and i had the sub output set to + 4.5. It seems that if i go lower that it shuts off during a long quiet passage of a movie. I have lowered it to + 3.0 and set it to 9 oclock and see if that helps. It also stays on the warmer side when it is just in standby mode and not in use, is this normal? I had a velodyne vx-10 and it was cool to the touch when not being used. Also the specs i found were 240 watts rms and frequency response 18Hz - 100Hz.
Thank you
Old 07-29-09, 10:00 AM   #2
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Re: Older Phase Technology subwoofer help
That kind of heat doesn't sound correct to me. You may have a defective amp. Staying warm without a signal is not a good sign either. It It could also be a damaged speaker. The voice coil may have overheated, causing some of the windings to short. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 07-29-09, 10:46 AM   #3
Alias: matt
Loc: texas
User: #33423
Since: Feb 2009
  splatee is offline
Yes it stays on the warmer side when im not using it when in standby mode. As for a damaged voicecoil the woofer moves freely with no rubbing or sounds that would indicate a damaged coil. It sounds perfect, i hear no distortion of any kind. I have also read that some amps stay a bit warm when in standby mode. What i think has happened is that i had a + 4 signal going to it and it being summer here in Texas and all that it got to hot. I am going to add a fan over next to it and see if that helps. I have also lowered the sub level a bit also.
Thank you
Old 07-29-09, 01:24 PM   #4
Shack Moderator
Alias: Dr Doan
User: #2314
Since: Aug 2006
  drdoan is offline
Is there any movement of the woofer when no signal is present. It is remotely possible that some stray infra or ultra frequency is riding on the input signal to the amp. Dennis
L Dennis Doan, DC
IT'S THE NERVE!
www.drdoan.com
Direct TV DVR HD
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
older, phase, subwoofer, technology
