Home Audio SubwoofersDiscuss Dual good subs vs one great one? in the Manufactured Speakers | Subwoofers forum; Dual good subs vs one great one? I have been going round and round on this for months now. I currently have a PB10NSD. Since my room ... |
Views: 589 - Replies: 4
| Dual good subs vs one great one? I have been going round and round on this for months now. I currently have a PB10NSD. Since my room is pretty small (1450 cubic feet) and sealed, it performs well. I can get to about -15dB below reference before any sort of compression sets in. I normally listen at -17dB or -16dB below reference...sometimes pushing it to -15dB, so I am real close to this subs limits, but still within reason. Because of room gain, I get a pretty flat response to 18hz, and 16hz is not far off. Overall, I am pleased with the sound quality. I have owned some pretty expensive subs in the past, and the PB10 sounds great. I am debating selling the PB10, and getting something bigger, like the AV123 MFW, or maybe the PB12+ from SVS (although more expensive than I want to go), or maybe something form Epik or eD. I am also seriously considering adding another PB10. I like the idea of two subs, but if I did that, I would not co-locate them, so I am not expecting the full 6dB increase in headroom...maybe 3dB. Any thoughts? | ||||
| | #2 | ||||
| Re: Dual good subs vs one great one? The PB10 is a nice sub and two of them would preform very well in your space and in my opinion wold be the best choice. You would smooth out the response and gain more than 3db if you place them in corners. Obviously going with one larger sub wold give you deeper lows and more headroom but you will loose the smoothing of two. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | |||||
| Re: Dual good subs vs one great one? Quote:
| | #4 | ||||
| Re: Dual good subs vs one great one? Thats my thoughts, 1450 cubic feet is fairly small so two of the PB10s should do wonders. Home theater: Onkyo TXSR805, Samson Servo 300 amp Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | ||||
| Re: Dual good subs vs one great one? Ditto on two subs. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
