Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Yet another... how much sub do I need thread.
Discuss Yet another... how much sub do I need thread. in the Manufactured Speakers and Subwoofers forum; Yet another... how much sub do I need thread. Ok,so I have a pair of Polk RTI 8's, axiom surrounds, and currently no subwoofer as every sub I bought ...
Views: 554 - Replies: 25
Old 09-15-09, 01:19 PM   #1
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
Ok,so I have a pair of Polk RTI 8's, axiom surrounds, and currently no subwoofer as every sub I bought at the local stores sounded horrible when I got it home. On a whim I purchased a samsung blu-ray player and I bought an Onkyo 607 as well, mostly so I could just run everything in and out on HDMI cables and tame the cable nightmare.
WOW!! the blue ray and new receiver made things really come to life. Now I NEED a subwoofer. (ok, so I'm obsessing at this point, but at least I am in the right place). So here is the deal, my listening room is 14 x 19 with 8 foot ceilings. However, this room is open to the dining room (12 x 14) on the long side. Will a SVS PC12-NSD provide decent bass in this large of a room or am I going to need something massive?
I've got mad woodworking skills and could build a nice sub but I essentially no next to nothing about all the tuning and measuring, etc. So somthing off the shelf for <$700 is really what I am after.
Thanks a bunch!!!!!
Old 09-15-09, 01:46 PM   #2
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is online now
Re: Yet another... how much sub do I need thread.
bbieger, I think the problem is that anything off the shelf is going to be a disappointment in general. You can find a much better quality sub in the price range you're talking about from an internet direct company. Some subwoofer makers to look at are SVS (as you've already found), Hsu Research, Elemental Designs, Epik, and Rythmik. Most of those will have a sub that is in your specific price range and will outperform what you've experienced in spades.
Regarding the PC12-NSD, I think it will be sufficient for what you need right now. It certainly ought to blow the pants off of what you've heard in your room already. I'm a believer that you can't really have too much. More subwoofer(s) will just provide extra headroom, less distortion at higher volumes, and a more pleasing sound overall.
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
Old 09-15-09, 01:53 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Jon has hit the nail on the head. You will get a much better sub for the money going with the above mentioned. SVS builds a great sub as I have one and it is fantastic. Your room is on the smaller size so the PC12 would do wonders.
DIY is also a great idea and you could very well build a sub that is even better for around $700. Mike is our resident DIY guy (others as well) and would be the guy to ask about that side .
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-15-09, 02:37 PM   #4
Shack Moderator
Alias: David
dyohn's Avatar
Loc: N. Cali
User: #19722
Since: Apr 2008
  dyohn is offline
What's your budget?
Old 09-15-09, 02:53 PM   #5
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
He stated less than $700 is his budget. Very doable, I might say.
Old 09-15-09, 02:57 PM   #6
Shack Moderator
Alias: David
dyohn's Avatar
Loc: N. Cali
User: #19722
Since: Apr 2008
  dyohn is offline
Yes, easily doable. Indeed, if the OP is not experienced with DIY one of the Parts Express kits might be right up his alley.
Old 09-15-09, 04:43 PM   #7
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
It seems that with any decent DIY effort I'll be in the $600 range. (500 watt plate amp, decent 12 or 15" sub and materials). How would a titanic mk 15" powered with a 500 wt. Dayton amp compare to the svs 12 referanced above? Mostly movies some music, vocal wife
Posted via Mobile Device
Old 09-15-09, 06:04 PM   #8
Alias: Greg
Loc: Denver, CO
User: #55
  GregBe is offline
As with anything else, you will get more bang for you buck DIY. Since you say you have solid woodworking skills, I would definitely go that route. Since I don't, I went with SVS, which as stated above (along with the other direct sub companies), is a way better than store bought for the money, but DIY does better than them both.
Old 09-15-09, 06:15 PM   #9
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
The Titanic 15" would play louder ans lower then a PC12-NSD, as long as cabinet size isn't an issue.
We're all in this together!
Members DIY Subwoofer Database
Old 09-15-09, 06:29 PM   #10
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
hmmmm. Decisions decisions. Would be pretty fun to crank out a cool sub but nice veneer gets expensive very quickly. I have a line on a PC12-NSD for $470 shipped to my door. Would be cool to have a massive 15" woofer in a really tall and narrow enclosure but I'm wondering if I really NEED that much sub. Is that blasphemous on this forum? LOL I generally get yelled at if I'm shaking the walls.
Someone remarked that I have a small room but since the two adjacent rooms are connected by a 6' tall, 12' wide pass through, Isn't my room essentially 443 sq. ft. with a volume of 3,544 cubic feet. Seems large to me?
Old 09-15-09, 06:37 PM   #11
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is online now
Yeah, that's a sweet deal on that pc12-
Old 09-15-09, 06:41 PM   #12
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
ironglen wrote: View Post
Hey now, your not supposed to be able to see my indecision. It is a sweet deal and in all honesty, it seems like a whole lot less work (and money for that matter) to just go to the bank and get a cashiers check rather then start making sawdust.
Just wondering if given the size of my room if I am going to "feel" that SVS.
Old 09-15-09, 06:54 PM   #13
Alias: Greg
Loc: Denver, CO
User: #55
  GregBe is offline
That is a pretty big room. The PC12 would do well, but it really depends on placement and how loud you intend to listen. It won't get you to reference level, but most of us don't listen close to that loud anyway. If you can place it close to your seating in a corner, depending on room response, might be your best bet for maximum output at the seats.
Old 09-15-09, 06:58 PM   #14
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
bbieger wrote: View Post
I got you. I certainly don't want to talk you out of my sale, I do advise you to think it over and shoot you questions to members for feedback. At times I have had mixed emotions about going BIG- it is a topic of conversation, produces the deepest lows...on the other hand, I've now spent more time and money, and I think my electric bill is feeling that pro-amp...I might shoulda, coulda bought another svs sub for my difficult space. Surely there will be someone with a similar environ as yours that will chime in, someone more knowledgeable, or maybe ask the svs rep?
Old 09-15-09, 08:31 PM   #15
Alias: DerekG
Loc: Conway
User: #35966
Since: Apr 2009
  dgilme is offline
What about two of the shiva-x that are on clearance right now and an ep2500 that comes in at around 500. Leaving room for a good eq/high pass filter and cabinet materials.
Or one of the shiva-x + pr kits Kevin has posted right now, those are pretty sweet deals. http://www.diycable.com/main/product...7908b82158cd8c
Old 09-16-09, 05:05 PM   #16
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
Well I spoke with SVS today and gave them the lowdown on my room dimensions and what not. They advised me that the NSD would do "fine" but if I wanted to listen at higher volumes than I would be better off with the plus. Given the cost of the plus however, seems like the best move would be to get the NSD and see how it plays. I could always get another NSD unit and be out the same amount of cash as buying a single plus. From what I have read on the forum, two smaller subs are typically better than one large one. No?
Old 09-16-09, 06:44 PM   #17
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
In a matter of sheer output, yes. But that's a generalization. NSD drivers versus the Plus drivers versus even the Ultra drivers are different sounds all together. While output might be higher with two NSD, but the sound quality of the Plus is likely better, so it's a trade-off.
And also, getting a single NSD right now is a pretty good way to go and I think you might find that will be sufficient enough for your needs.
Old 09-18-09, 01:40 PM   #18
Alias: Dylan
Loc: Las Vegas, Nevada
User: #36413
Since: Apr 2009
  sub_junkie is online now
If your willing to spend around $80-$100 over your listed budget, you could go with a Maelstrom-X and a EP2500.
The Mal-X was $430 shipped to me, and you can get an EP2500 at Guitar Center for $350. But, there are Ebay listings for the EP2500 that are at $320 shipped or close to that.
The Mal-X is found Here
But, that's if you haven't already bought anything, or if you want to go with the DIY route. You could also go with the Mach 5 Audio IXL 18 ($265) found here and a EP1500 ($239 buy it now on Ebay) for a total around $504 excluding building costs which would be around $50 or so.
I went with the Mal-X and am very happy with it, and I only have 150w going through and it can handle 1800w easily. Got an EP2500 on the way...
Old 10-02-09, 12:47 PM   #19
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
SO I purchased IronGlen's SVS PC12 NSD and plugged it in last night. What was even more frightening to me than the sheer size of the unit (is that a kegerator? my wife says when I hauled the box in) was the sounds this thing could put out. I played dirt 2 on my 360 and when I first crashed into a concrete wall I scared the hell out of myself because as the controller shook, so did my chest from the booms coming out of the sub.
Hopping around like some kind of drug addict that just found a bale of coke washed up on a remote beach, I threw T2in the blue ray and skipped forward to the nuclear attack flashback scene. DUDE!! To my wifes credit, she paused from watching true blood on her laptop in bed to come downstairs to calmly tell me that the bedroom windows were rattling. Then it was on to black hawk down's "Irene" scene..impressive but not fear inducing. Finally, (after all it was 12:30) I watched the "broken arrow" sequence on we were soldiers. This track is one of the best surround sound scenes I know of. Planes whizzing left to right, m16's and hand guns going off and my favorite..coffee table shaking napalm explosions
What is so cool about we were soldiers is that there are many "quiet" scenes int he middle of the fighting (like slow motion stuff) and often these scenes end with a big explosion or something that really does scare the out of you even if you know it is coming.
Thanks Glen!!
(dude, buy a blue ray!!)
Old 10-02-09, 01:40 PM   #20
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
If you think the PC12 NSD is big, you should see the PC-Ultra or the PB13-Ultra. Or better yet, the old-school B4+ that SVS made. Just imagine a box big enough for 4 twelve inch drivers and enclosure space to accomodate the pressure!
Oh and congrats on the purchase!
Old 10-02-09, 02:37 PM   #21
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
Glad you like it! (hope it meets waf too) After you have it awhile in a corner, you'll forget about the size. Makes you wonder how you did without a good sub for so long, eh?
Old 10-02-09, 04:01 PM   #22
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
I am going to try putting it behind a chair in the front corner and see how it sounds. Because it now sits directly adjacent to the listening position, you can tell where the bass is coming from in many instances. I can't quite stop thinking that a corner behind a chair will make it sound muffled.
Old 10-02-09, 06:25 PM   #23
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
I would try multiple locations, too. I always got annoyed when I could localize the bass signal. Even though the lower frequencies are much less directional, I still could tell and it always bothered me. So I always took a long time calibrating a sub, relocating calibrating, relocating, calibrating, etc. until I found the best spot. It may feel like a lengthy process, but it is well worth it in the long run.
Old 10-02-09, 06:55 PM   #24
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
It might work well, being downfiring, plus it is ported out the top Get it set soon, and enjoy your movie-filled weekend!
Old 10-02-09, 07:44 PM   #25
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
DId you re-calibrate the system after you added the sub???.....I agree with Jon Liu, you need to play to find the best spot
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
another..., thread.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
