Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Rythmik F12 distortion chart
Discuss Rythmik F12 distortion chart in the Manufactured Speakers and Subwoofers forum; Rythmik F12 distortion chart Everything I hear about the Rythmik subs sounds great. However, I am troubled by the THD chart as measured by ...
Views: 176 - Replies: 3
Old 10-27-09, 04:47 PM   #1
Alias: Q
Loc: NW Ga
User: #41549
Since: Sep 2009
  FidelitySeeker is offline
Everything I hear about the Rythmik subs sounds great. However, I am troubled by the THD chart as measured by Ilkka (4th chart in the link below). Am I interpreting it wrong?
PS- I am actually looking at the F12G, but this is the closest I can find. Would there be differences (aside from the GR driver extending into higher frequencies)?
http://www.hometheatershack.com/foru...ealed-56l.html
Old 10-27-09, 06:47 PM   #2
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is offline
Re: Rythmik F12 distortion chart
I am not sure what the difference between the F12 and the F12G drivers are exactly, but I might assume that the F12G improves on more than just the higher frequencies.
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
Old 10-28-09, 09:51 AM   #3
Alias: Q
Loc: NW Ga
User: #41549
Since: Sep 2009
Thanks Jon.
Different manufacturers and different materials - you're probably right about that. I guess the only real commonalities are the servo system and cabinet.
Old 10-28-09, 10:55 PM   #4
Alias: Ryan
Loc: Eastern Minnesota
User: #36661
Since: Apr 2009
  NegativeEntropy is offline
Note Ilkka's comments in this post regarding the THD performance of this sub:
http://www.hometheatershack.com/foru...html#post48248
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
chart, distortion, rythmik
