| Home Audio Subwoofers Options for remote controlling your subwooferDiscuss Options for remote controlling your subwoofer in the Manufactured Speakers and Subwoofers forum; Options for remote controlling your subwoofer From the posts I’m seeing on the New BFD Poll thread , it looks like a lot of people are ... |
Views: 3312 - Replies: 3
| Options for remote controlling your subwoofer From the posts I’m seeing on the New BFD Poll thread, it looks like a lot of people are interested in remote control for their subs. Rather than sidetrack that thread, I thought I’d open a new one here on the topic. The cheap and easy solution: A gizmo called the Chase Technologies RLC-1. It connects between the receiver and the subwoofer. Sure, most receivers these days can control sub levels through the remote, but you usually have to shift through a lot of on-screen menus to do it. The RLC-1 makes sub levels readily accessible - like the main volume control - which to me is the way it should be. ![]() Photo courtesy of Otto A brief background on the RLC-1: Back in the mid 90s a maverick company called Chase Technologies came out with the RLC-1 (for remote line controller). It was designed to upgrade older two-channel receivers for remote control capability, accomplished by connecting across the tape monitor loop. All of your components would plug into the RLC-1, which would then allow input selections and basic functions like volume, balance, bass and treble to be remote controlled. The RLC-1 was tested in Stereo Review and got good marks for its excellent specs and sonics. List price was $150, but Best Buy sold them for $100. Chase Technologies is long out of business, but occasionally a RLC-1 will show up on eBay (search “chase rlc-1” or “chase technologies” from the home-page search engine). When you find them, they will typically sell under $50. Eleven years later I’m still using my RLC-1, and it works very well for this application. It does have a few minor problems, but they have easy solutions.
It’s interesting how times have changed. When I first started on the home theater forums back in ’99, I mentioned remote controlled subs in general and the Chase specifically a few times, and generated near zero interest. Maybe it’s an idea whose time has come. I for one think the concept is very cool. I wouldn’t dream of having a system without it. It's also a quick and easy way to turn of the subs for late night viewing when others in the house are sleeping. Since it’s possible this thread will generate a run on the RLC-1s that appear on eBay in the near future, another viable option is an old stereo pre amp with remote control. I looked through my old Audio Equiment Directories from the mid-to-late 90s and came up with a few that listed for under $1000. If you can find them on eBay or some other auction site, they should be selling pretty cheap by now, although they’ll probably be higher than the Chase:
Pre-amp/tuner combos are also an option. Here are the ones I could find that listed under $1000:
Good luck and happy remoting! Regards, Wayne | ||||
| | #3 | ||||
| Re: Options for remote controlling your subwoofer Hi Wayne, I don't suppose the RLC-1 supports balanced connections? Thanks! -- Otto | ||||
