Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Cable Run for Subwoofer
Discuss Cable Run for Subwoofer in the Manufactured Speakers and Subwoofers forum; Cable Run for Subwoofer Ok I still need to select and buy a subwoofer for the room but more importantly at the moment I ...
Views: 2883 - Replies: 11
Old 05-09-06, 05:05 PM   #1
Alias: Tom
Tommy's Avatar
User: #51
  Tommy is offline
Ok I still need to select and buy a subwoofer for the room but more importantly at the moment I gotta worry about running the wires in the wall. The sub will not be in the wall just the wire.
As far as running the in-wall wire, should I terminated it at a wall plate or is there some type of wall plate & box I should be looking for to run the wire right thru?
Sonnie, I see in your construction pics the wires comming right thru a wall box but dont see how it was finished or what the face plate looks like.
Old 05-09-06, 05:53 PM   #2
Owner
Loc: L.A. (Lower Bama)
Re: Cable Run for Subwoofer
lol.... mine was jury rigged. I took a thick plastic drain cover from the hardware store and drilled a hole in the center, painted it and pulled the wires through. My cable wires are fed through a solid single gang plate with holes drilled the size of the wire. I suspect you could do the same. I'm not much on wall connections... I'd just rather eliminate as many connections as possible, but that doesn't mean you can't use them.
Old 05-09-06, 11:10 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
As far as running the in-wall wire, should I terminated it at a wall plate...
You can certainly do that. You might want to do that if the plate is on an outside wall, to make sure there are no air leaks for HVAC purposes.
You can do that, too. The nice thing about running your own wire is you can drop it out of the wall directly behind the sub, and no one will see it at all. So, it doesn’t make much sense to use a pretty (and expensive) wall panel terminated with an RCA connector.
I suggest just getting a blank cover for an electrical box, and drill a hole in it (you can actually by some with a hole pre-drilled, although it might not be the correct size for you). You can either attach the cover directly to the sheetrock, or to an electrical box.
In case you haven’t picked up on this, regular coaxial cable like they use for TV antennas or cable TV works great for this, and it’s cheap. You can get a cable pre-terminated with F connectors and bring it right out the wall, and use F-to RCA adapters to connect to the sub, and receiver on the other end. Same thing if you want to use wall plates: Get some with F terminals. Use another antenna cable between the wall and sub with F-to-RCA converters.
Old 05-12-06, 04:00 PM   #4
Alias: Russell
Loc: Cambridge, UK
User: #494
  russ.will is offline
Another good reason for keeping the cable run unbroken, is that the shielding on the cable will be effective over its entire length. Mains EMF induced sub hum is the most annoying thing in the world. Aside from the obvious, it tends to generate a sympathetic whining sound from the wife if she has the ears of a bat, like mine.
There's a thread here on a UK forum from a guy who really knows his stuff on all things long, round and sheathed.
Russell
Old 05-25-06, 06:05 AM   #5
overclockedpc
Inactive
Alias:
User: #
Posts: n/a
I will also agree and say that you should just run it right out to the sub with no wallplate...just adds an unnecessary connection point.
Old 05-25-06, 08:00 AM   #6
Alias: Tom
Tommy's Avatar
User: #51
  Tommy is offline
Thanks for the advice, terminating at the wall plate aside is there another way of running it through the wall that will look more professional then just drilling a hole in the sheet rock?
Old 05-25-06, 08:02 AM   #7
Alias: Tom
Tommy's Avatar
User: #51
  Tommy is offline
Ok so I have 2 runs to make, I'll put 2 subs in, one on the back wall in the opposite corner of my rack so that will be about 14' away. And the second will be in the front of the room, depending on how the wire is run but I'd say 34' away if ran down both the walls.
What exactly do I need to order as far as what type of wire and connections on it plus anything else that I may need?
Old 05-25-06, 03:15 PM   #8
Alias: Russell
Loc: Cambridge, UK
User: #494
For starters, good quality, solid performing cable does not need to be particularly expensive or charmed with snake oil. Get a cable that is acually made by a cable manufacturer, not packaged by a cable seller.
Google "Canare LV77S". This is a quality co-axial dual screened cable that is very popular in the UK and just happens to be made in the USofA. It's not even expensive over here, so it should be dirt cheap over there. This is broadcast quality stuff that is often run 10s of metres (100s of feet) in the pro world.
Just had a quick surf and it can be found here in the USA.
There is a post in the UK by a bloke who really understands what actually makes a cable work. Get yourself I a nice cup of tea and sit down for a very long and very informative read. It covers ALL AV/Hifi cables. Look here.
Russell
Old 05-27-06, 08:00 PM   #9
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Most of our pre-wired sub runs are simply QS RG6U. The down side to this is that you end up with extra connections if you terminate with a connector at the wall plates or that the cable is very stiff to work with if you make a continuous run out to the components. In terms of signal quality, it is fine.
Canare is great stuff.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 10-02-09, 12:32 PM   #10
Alias: monkeyboy
Loc: portland, OR
User: #42005
Since: Sep 2009
  bbieger is offline
Just like the old adage, if its worth doing, you might as well do it right. While I agree that creating a super clean set up by installing a rca jack at the plate itself, it is probably not necessary. But I would go through the "trouble" of installing a proper outlet box. Just grab a "old work" box from home depot. You cut a rectangle in the wall, rung the cable through the entrance of the box, slide it in the wall and use a screwdriver to snug it tight. Then you can make your own switch plate cover.
A much better solution than simply hogging a hole in your drywall. Also, you can more effectively seal the outlet box which helps A LOT in terms of energy efficiency. You would be quite surprised at how much cold air can blow through your outlet covers and switch plates.
If your fishing the wire through a tricky wall, you can use a magnet and steel chain (like a tub plunger chain) to help "find" the cable snake in the wall.
Old 10-08-09, 01:00 AM   #11
Alias: John
Loc: Central California Coast
User: #31
  fibreKid is offline
Wall plates and subwoofer cables don't have to be ugly.
Old 10-08-09, 02:13 AM   #12
Shack Moderator
Alias: John
recruit's Avatar
Loc: UK - Near London
User: #37302
Since: May 2009
  recruit is offline
Very tidy John I'll have to tidy my cables up one day
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
