NHT 12inch sub now... considering HSU VTF-3 HO Turbo upgrade - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss NHT 12inch sub now... considering HSU VTF-3 HO Turbo upgrade in the Manufactured Speakers and Subwoofers forum; NHT 12inch sub now... considering HSU VTF-3 HO Turbo upgrade I currently have a nht 12 inch sub in my living room which is an open floor plan into my ...
Old 02-05-07, 01:48 AM   #1 (Link)
Alias: craig
Loc: saint louis
User: #5752
Since: Jan 2007
frockc is offline
I currently have a nht 12 inch sub in my living room which is an open floor plan into my dinning room and kitchen... I had my sub bottom out on a movie recently and it was quite annoying when ur watching a movie with friends and u have to turn down the sub cause it can't handle the track... It also seems that it is not powerful enough for this large room...
nht sounds nice and i got a good deal but i'm thinking of upgrading to the HSU VTF-3 HO to get a real sub especially for home theater which is what i watch most of the time....
how much of an upgrade is it over the nht 12 both home theater wise and musically... after reading a recent post about how good this sub is it got me excited especially when i saw how reasonable priced it was...
i have learned alot about REW so i'm ready to eq this sub if i get it...
Old 02-05-07, 10:51 AM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: NHT 12inch sub now... considering HSU VTF-3 HO Turbo upgrade
Big open floor plans are a problem. Best solution would be multiple drivers. Two of the HSU VTF-3's or maybe a dual driver SVS PB12-Plus/2. Sonnie seems to feel that he even needs two of them. http://www.hometheatershack.com/forums/5386-post1.html
Old 02-05-07, 11:25 AM   #3 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
What Bob said – a single 12” in driver will have a hard time with a large open floor plan like that (voice of experience here). You could add a second NHT, or two of another brand, or a dual-driver sub. If you don’t like the visual prospect of two subs, or a single huge one, try something like the SVS PB12-NSD. It has a built-in limiter to prevent bottoming out. I most cases, you won’t even notice that it’s working.
Old 02-05-07, 01:41 PM   #4 (Link)
Alias: craig
Loc: saint louis
User: #5752
Since: Jan 2007
frockc is offline
I figured the sub was bottoming out from it not being able to go deep enough not because of the size of the room???
Isn't 1 HSU VTF-3 HO a big upgrade over the nht 12???
I figured the HSU since it has a 500 watt amp it would be better then two nht 12 and the maybe i could add another nht or mbm12 later...
Old 02-05-07, 02:57 PM   #5 (Link)
Loc: Lower Alabama
I would say the HSU would be a definite upgrade and you would probably be very satisfied with it. Obviously being a SVS owner, I'm a little bias to SVS subs, not that HSU subs are not good subs, I'm sure they are very good, although I've never heard them.
You can compare the PB12-NSD/2 price wise to the HSU VTF-3 HO... both at $899. The NSB/2 has a pair of 12" drivers and a 600 watt BASH amp, which may be a little better for your large room. The NSD is slightly bigger and weighs about 30lbs more... a little bit beefier.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
HSU VTF-3 MK2 (maximum extension) Ilkka Subwoofer Tests 4 03-30-07 06:14 PM
My Hsu VTF-2 graphs privateradio REW Forum 32 01-25-07 07:35 AM
Hsu VTF-3 HO REQ results....suggestions? bbgsdad REW Forum 18 11-08-06 10:13 PM
My Final Hsu VTF-2 Subwoofer Settings Thanks to REW geekwithfamily Home Theater, Audio and Video News 0 09-18-06 11:00 AM
HSU VTF-3 MK2 (maximum output) Ilkka Subwoofer Tests 3 07-17-06 02:23 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
