Best Sub under $700 for big room? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Best Sub under $700 for big room? in the Manufactured Speakers and Subwoofers forum; Best Sub under $700 for big room? I just started on a AV system, do not have a dedicated HT room and I am not looking to ...
Old 01-13-07, 08:52 PM   #1 (Link)
Alias: cloudmine
Loc: Tucson, AZ
User: #5616
Since: Jan 2007
  cloudmine is offline
I just started on a AV system, do not have a dedicated HT room and I am not looking to go crazy. My current AV setup is in the living room which is attached to the kitchen and dining room, in an open format. The room (incl. kitchen and dining area) is approx. 18'x22' and the ceiling slopes from 8' to 11.5'. I have large furnature, so space is tight. I have no sub right now, so that has to be first. I plan to purchase the front/surround speakers thereafter, but due to space limitations, they will have to all be "book shelf" sized. Usage is 50% TV, 30% DVDs and 20% CD/SACD/MP3.
Sub budget less than $700 (unless room specs force higher). Need a small footprint, best location is corner behind TV (51" projection), so a tall speaker is fine. I have heard great things about SVS and was thinking of either the 20-39 PCi or SB12-Plus given their small footprint. However, I am open to ANY suggestions since I have a large room and a small budget.
Thanks, Marc.
Old 01-13-07, 11:28 PM   #2 (Link)
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Best Sub under $700 for big room?
Welcome to the Forum, Mark!
The SB12-Plus will work well in your room, which I calculate to be about 3800 cu. ft total. I used one briefly a few months ago, and I was very impressed with its performance, and my living room (including other open areas) is over 9000 cu. ft.
That said, it looks like the 20-39 will get your more “bang for the buck” – lower extension and SPL, at a lower price. So if you don’t mind the extra size, that’s probably the way to go. The SB12 is basically for folks who need a really tiny sub, and if works great for its size. However, if you can spare the space, a bigger sub will most always perform better.
Old 01-14-07, 11:33 PM   #3 (Link)
Alias: Steve
SteveB's Avatar
Loc: Atlanta, GA
User: #3208
Since: Oct 2006
  SteveB is offline
I happen to be a big fan of Hsu subs and speakers in general. They always get good reviews. Check this out :
http://www.hsuresearch.com/products/vtf-3.html
Old 01-15-07, 12:19 PM   #4 (Link)
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
SVS or Hsu are generally regarded as the two best value sub manufacturers. If there was a gun against my head, I'd say SVS gets the more kudos among the various forums I've frequented.
Either company will give you a product that can not be beat in your price range. The only alternative that might be better would be to build your own sub.
JCD
Old 01-15-07, 03:20 PM   #5 (Link)
Moderator Emeritus
Alias: Naut
Ayreonaut's Avatar
Loc: Richmond, VA
User: #203
  Ayreonaut is offline
DIY rules. You can do a sub with four Mach5 MJ-18 drivers and a pro amp for less than $700 that will blow away the commercial options.
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 01-15-07, 03:37 PM   #6 (Link)
Alias: brandon
brandonnash's Avatar
Loc: Murfreesboro, Tn
User: #2533
Since: Sep 2006
  brandonnash is offline
Always agreed with going they DIY route. Can get a much better sub for that price if you make it yourself. $700 in the DIY world would get you in the $!000's range in the commercial sub world easily.
Old 01-15-07, 04:25 PM   #7 (Link)
Alias: Derek
Vader's Avatar
Loc: Colorado
User: #1439
  Vader is online now
...Can get a much better sub for that price if you make it yourself.
... no argument there, but that assertation is assuming that you have the skill, know-how, and desire to do so (which I don't; I salute those who do). I also will throw in my hat into the "Unless you go DIY, no commercial sub will touch an SVS or HSU, even at twice the price" camp (or, at any price at a B&M store)
Peace... Vader
Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors!
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
The Overlook Theater - Not liable for injuries sustained while laughing.
Old 01-15-07, 09:33 PM   #8 (Link)
Alias: cloudmine
Loc: Tucson, AZ
User: #5616
Since: Jan 2007
I, like Vader, salute those with the knowledge, time and guts to DIY... however I certainly don't. Especially since I am pushed for space and I am fairly sure that its even tougher to deisgn an enclosure with a small foot print. Appreciate the idea, but I think I will be going commerical off the shelf.
Old 01-15-07, 10:09 PM   #9 (Link)
GPM
Alias: GM
GPM's Avatar
Loc: Chamblee, Ga.
User: #5626
Since: Jan 2007
  GPM is offline
Greets!
Bummer, this simple folded pipe already has what I consider a small footprint and at ~$230 + amp + some sweat equity it's a great bang/buck project, so I'll go ahead and post it in case someone else wants to try it: http://www.decware.com/cgi-bin/yabb/...num=1168330259
GM
Loud is Beautiful if it's Clean!
Old 01-18-07, 12:25 AM   #10 (Link)
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Right now the VTF-3 MK3 seems to be the top sub under $700 on the various forums. I have a VTF-3 MK2, which was originally $700 and was replaced by the VTF-2 MK3 and now sells for about $470. Either of those would give you tight, detailed bass for your room.
How much space do you have behind your TV? A SVS tube sub may be your only option, but if you can measure and see if one of the box subs will fit there, you'll have many more options.
Old 01-18-07, 12:49 PM   #11 (Link)
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Here is some good reading:
http://www.avsforum.com/avs-vb/showt...0&page=1&pp=30
Latest results for the PB12NSD and VTF-3 MK3 (latter being the leader in sub-$800 subs) :
http://www.avsforum.com/avs-vb/showt...&&#post9506551
Old 01-18-07, 05:19 PM   #12 (Link)
Alias: Eddie
Eddie Horton's Avatar
Loc: Hayden, Alabama
User: #3894
Since: Nov 2006
  Eddie Horton is offline
I was happy to see the new offerings from HSU, and I'm really looking forward to the new line from SVS. That's good ole' American competition for you. We all win. A good friend of mine's brother-in-law has twin PC Ultras in a large room. I know they are over the $700 mark, but WOW, can they get down.
Old 01-24-07, 08:48 PM   #13 (Link)
Alias: tmack
tbase1's Avatar
Loc: medina ohio
User: #3961
Since: Nov 2006
  tbase1 is offline
I own a M&K MX-200. It's not under $700.00 retail ,but I paid under 7 for it. It's a dual 12" push pull.
Old 01-25-07, 07:54 AM   #14 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
4 x 15" PE IB15s in an opposed manifold IB with a Behringer amp.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94
