SVS Pb12+ vs HSU HO - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
SVS Pb12+ vs HSU HO
Discuss SVS Pb12+ vs HSU HO in the Manufactured Speakers and Subwoofers forum; SVS Pb12+ vs HSU HO Both products have similar price.... This is why I thought this would be an interesting comparison. Those who have heard/owned ...
Old 03-02-07, 09:19 AM   #1 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
SVS Pb12+ vs HSU HO
Those who have heard/owned both subs (in same room) are welcomed to post their opinion, measurements, advantages/disadvantages....
Thanks!
Old 04-05-07, 02:17 PM   #2 (Link)
Alias: Mazer
Loc: Melbourne, Florida
mazersteven's Avatar
User: #8008
Since: Apr 2007
mazersteven is offline
Re: SVS Pb12+ vs HSU HO
blaser wrote: View Post
Thanks!
On May 20th I will be putting the HSU VTF-3 HO Subwoofer with Turbocharger, up against the
SVS PB12-Plus/2.
Right now I can't tell you.
Old 04-05-07, 02:38 PM   #3 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Great, try to give us numbers, more than impressions (but they are also wellcome!!)
Old 04-16-07, 09:07 PM   #4 (Link)
Alias: doreytp
Loc: Bridgewater, NS
User: #8302
Since: Apr 2007
doreytp is offline
ahh,
if the HS VFT3-MK2 is half the cost of a SVS Ultra/2 whynot buy two HSU's.
you'll have dbl the wattage, two 12" drivers, more enclosure total etc
Old 04-17-07, 07:47 AM   #5 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
doreytp wrote: View Post
ahh,
if the HS VTF3-MK2 is half the cost of a SVS Ultra/2 why not buy two HSU's.
I thought the comparison was to the SVS Plus/2 not the Ultra/2. The HSU VTF3-MK2 is discontinued. Are you comparing used prices or new? The SVS Plus/2's price is $1,299 new. A new VTF-3 MK3 shows a price of $699 at the HSU website (but $999 list?). With Turbocharger it is $799. A VTF-HO is $899, with Turbocharger it is $999.
Old 04-17-07, 08:06 AM   #6 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Warpdrv is offline
The comparison was between the PB12-PLUS and the HSU HO...
From what I have read, the PB12-Ultra was listed a couple of points lower then the HO... so even the Plus would be lower then that... but thats the Ultra 12.. not the upcoming Ultra 13....
I think the Pretty factor would go to the Plus,(but thats me) in build quality... and performance would be good, but the HSU is likely to be a bit more accurate...
Now if you were comparing the HO to the Plus/2 I would say the lower extension might be a bit better with the HO but the sheer output would go to the Plus/2 with dual 12" drivers...
I bought the Plus/2 for my really large room, and LOVE IT!!
Old 04-17-07, 08:44 AM   #7 (Link)
Alias: doreytp
User: #8302
Since: Apr 2007
doreytp is offline
sorry posted in wrong post, it was an issue a few posted down, guess I hit the back button to many times.
It was the SVS Ultra/2 and a HSU vft3-mk2. Yeh, I know they are disconntinued but, still can be bought at $700 and not quite half the cost of the SVS but really close.
Just they are close in comparison in performance and two are better than one. I feel two HSU's at a couple hundred more maybe the best bang. I am not in no way saying SVS is not as good, but it really all depends on ,when it comes down to it....the reviewer and really how many reviews have you heard that came out when the magazine or reviewer said do not buy or not worth the money.
Yes, that issue of 20hz at 109db in his room, they sould also do measurements like Axiom does out side up in the air and then take thier readings.
Old 04-17-07, 09:12 AM   #8 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Warpdrv is offline
I would probably agree that the HSU may be a better deal, as SVS is a bit more for the finish options... and rightly so... they are very nice looking.
Depending on room size and budget YMMV...
Old 04-17-07, 10:03 AM   #9 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Hi everybody,
I did not open this thread for impressions!! Pls read my first post here. If it is about impressions, pls read this thread where I have compared both based on laws of physics, and expectations..... http://www.hometheatershack.com/foru...other-one.html. If you still want to debate in this way, pls PM me (because Sonny has closed that thread ).
Do not forget the main requirements:
"Those who have heard/owned both subs (in same room) are welcomed to post their opinion, measurements, advantages/disadvantages...."
Thank you!
Blaser
Old 05-30-07, 09:10 AM   #10 (Link)
Alias: Bailman
Loc: Bridgeport, CT
User: #4294
Since: Nov 2006
Bailman is offline
mazersteven wrote: View Post
SVS PB12-Plus/2.
May 20th has come and gone. What were your subjective results?
Old 06-03-07, 09:24 PM   #11 (Link)
Alias: Bailman
Loc: Bridgeport, CT
User: #4294
Since: Nov 2006
Bailman is offline
Bailman wrote: View Post
Bump
Old 06-29-07, 09:45 PM   #12 (Link)
Alias: Mazer
User: #8008
Since: Apr 2007
I was surprised at how small the VTF-3 HO Subwoofer with Turbocharger was compared to the SVS PB12-Plus/2. I was also surprised at how well it performs for only having one driver.
Finish, Looks-SVS
Build Quality-SVS (The HSU just doesn't seem to be built like the SVS.)
Cost-HSU ($300 less) (But for only $300 more you get dual drivers, and better finish)
Size-HSU (The SVS is a Behemoth.)
I didn't do any official measurements, or anything. My room is 35x30 with openings to other areas. While performing a sub frequency test, both subs went down until you couldn't hear them anymore. Only subsonic rumble. Boy you sure did feel them. :holycow: I definitely found out what in my house wasn't securely fastened down. Any material we through at these subs they didn't even break a sweat. Tons of headroom. Tight, Clean, Accurate.
I don't know if this was the information you have been waiting for. Sorry it took so long to respond. Any other questions please feel free to ask.
Old 06-29-07, 11:05 PM   #13 (Link)
Loc: Lower Alabama
It would be interesting to see an REW measurement on both subs, as long as you could get them in the exact same location and keep the mic in the same location, then trace offset the response if needed.
Old 06-29-07, 11:14 PM   #14 (Link)
Alias: Mazer
User: #8008
Since: Apr 2007
Sonnie wrote: View Post
I can get the two subs in the same location. I don't have a mic, the software, or the knowledge to figure out what I would do with it all.
Old 06-29-07, 11:23 PM   #15 (Link)
Loc: Lower Alabama
Oh man... Mazer... you gotta be kiddin' me. How do you sleep at night...
Do you wanna learn?
Old 06-29-07, 11:39 PM   #16 (Link)
Alias: Mazer
User: #8008
Since: Apr 2007
Do you wanna learn?
Always looking to learn something new.
Old 06-30-07, 06:11 AM   #17 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Mazer,
Place them colocated...listen to each one.
switch their position...listen to each one.
Check if there is a considerable difference...if not listen to each one and tell: which one is more articulate, stronger, deeper....an overview.
If there is a considerable difference, then listen to one, then remove it aqnd put the other in its location...then tell us your impressions...
For measurmenents, We will be with you, but leave this as a future step.
Blaser
Old 06-30-07, 06:55 AM   #18 (Link)
Alias: Mazer
User: #8008
Since: Apr 2007
Mazer,
Blaser
Blazer,
Thank you for your "Fine Forensic Analysis". But I already now this. I was talking about learning about Room EQ Wizard.
Old 06-30-07, 12:16 PM   #19 (Link)
Loc: Lower Alabama
Do you have an SPL meter and have you downloaded REW yet?
Old 07-13-07, 10:10 PM   #20 (Link)
Alias: Mazer
User: #8008
Since: Apr 2007
Sorry it took so long to reply. Computer went down. Been off-line for 2 weeks.
Old 07-16-07, 11:49 AM   #21 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
So what's your reply?
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
