| Home Audio Subwoofers My sealed 12" nearfield measurements.Discuss My sealed 12" nearfield measurements. in the Manufactured Speakers and Subwoofers forum; My sealed 12" nearfield measurements. Bored, thought I'd share some nearfield measurements of my 12" sealed sub
~2.0Ft^3 enclosure with about 3/4lb acousta-stuff
Rythmik Direcservo ... |
| | #1 (Link) | |||
| My sealed 12" nearfield measurements. Bored, thought I'd share some nearfield measurements of my 12" sealed sub ~2.0Ft^3 enclosure with about 3/4lb acousta-stuff Rythmik Direcservo (Rythmik Ds12tc driver w/ 350watt amp) Here is a shot of how I took my measurements. ![]() Results are below ![]() Red 28hz Setting Green 20hz Setting Blue 14hz Setting All tests were done in High Damping mode. My findings were about what I would've expected, nothing shocking here. X-over still set to 80hz on AVR for these tests. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #2 (Link) | |||
| Re: My sealed 12" nearfield measurements. More measurements to come friday. I've since removed ~ 1/4th pound of fill and things sound a heckuvalot better than they did when I took the above measurements. I take back my previous non-shocked comments from the previous post. I've looked around at other typical numbers from sealed subs and most of them roll off a lot faster than my little 12"er. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
