Thinking about a HSU VTF-2 MK4, but would like some input... - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 16 Old 06-19-12, 08:27 AM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson's Avatar
Todd Anderson
So.
I'm considering buying a HSU VTF-2 MK4. I currently run an Energy S10.3. Here's a quick run down on the Energy:
Original Msrp was $529 (I paid, from Vanns, about $249):
Product Features of s10.3 include the following:
10-inch injection-molded woofer with patented ribbed elliptical surround suspension for greater output and lower distortion
800-watt dynamic / 200-watt RMS custom matched amplifier for clean and deep bass down to 21Hz
Rigid, low-distortion MDF enclosure with black ash finish and integrated front level control
Variable crossover and phase control to blend with any speakers, low-level and speaker level inputs for connection to any receiver, amplifier or TV
Front-firing, down-ported design for maximum impact and reduced port turbulence and distortion
My room is 13x17x8, Theater use only.
I generally like my energy. It never bottoms out, has some good boom. Can rumble.
I have noticed a few specific things about it:
1) my primary frustration is how it sounds when there is loud bass heavy music in a movie. I watched the chipmunks movie with my kids the other day and the bass (during some songs... Especially rap music) was very loose and not aligned with the song (so loose it sounded out of sync). But for things like explosions, etc, it's spot on.
2) I've had issues with boominess. I've used REW... Have a BFD... And bass traps. All if that has helped some! I know the boominess is probably primarily due to the room size/shape itself.
At any rate, it looks like the HSU can be had for $600. Which is a decent coin!
Can someone who owns the HSU (or familiar with it) describe to me - specifically - what I'd gain by buying the HSU? If someone told me every bass note would be tighter --- punchier --- exactly precise... I might be sold. But I'm worried that my $600 will only buy me something that will have the ability to go louder... Not bring exponentially better clarity and jaw dropping precision.
Thanks guys (and gals!)
27
Todd Anderson is offline
post #2 of 16 Old 06-19-12, 09:26 AM
wgmontgomery's Avatar
Gary
Re: Thinking about a HSU VTF-2 MK4, but would like some input...
I owned a couple of Energy subs in the past; I had them on the side and surround channels (M&Ks for LFE and center). They worked well, but I think that the Hsu would be an excellent choice. It's 12 inch driver is ~34^2 inches larger than a 10 inch (area of the driver figured as a circle not a cone) and can hit 18 Hz!
wgmontgomery is offline
post #3 of 16 Old 06-19-12, 09:39 AM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
I guess bigger is always better!
The main driver for me are some of the the factors I touched on... Quality of the sound. Do subs ( specifically something like my energy and the hSu) differ that greatly I their ability to cleanly (more precise, less loose, tighter... Whatever descriptors someone could come up with) reproduce LFE? Or will will the difference really be more about loudness?
post #4 of 16 Old 06-19-12, 10:54 AM
Gary
IMHO-clean tight bass is much more important than loud bass; quality over quantity, so to speak. Some subs are "all boom, no tune," but I would NOT put the Hsu in this category. All things being equal, I think that you will find the Hsu to be cleaner, tighter AND louder.
post #5 of 16 Old 06-19-12, 01:27 PM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
Called-up and talked to the HSU staff... very friendly. I appreciated their interest in my questions and taking the time to answer!
I went ahead and ordered the VTF-2 M4.
I'm in the middle of a major HT renovation... so it will be a few weeks before everything is installed and ready to rip. That being said, I'm excited to move up another level on the ole' subwoofer chain.
post #6 of 16 Old 06-19-12, 02:40 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
wgmontgomery wrote: View Post
Amen to that. I will always take articulation over volume. I too want detail, not noise.
-Jim
theJman is online now
post #7 of 16 Old 06-19-12, 04:34 PM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
Well... hopefully this sub will deliver just that! Because I'm in agreement with both of you!
post #8 of 16 Old 06-19-12, 05:55 PM
Inactive
Ty
I own a pair of the VTF2 Mk3s. Put simply, I think you would gain everything that the Energy lacks, and you would gain them in spades.
That having been said I also want to mention that control plays a large part in your sub's performance, and a larger part than you may think. As an example I recently upgraded to a Sherwood R-972 AVR and a completely unexpected benefit of that upgrade was not just improved bass control but vastly improved bass control. Audyssey MultEQ in my former AVR was simply no match for what I get now from the Hsu. Ive also calibrated the Hsu with Audyssey MultEQ XT and I dont think it compared to what I get now from my sub, though admittedly that was some time ago. So I guess the moral of the story is the sub itself is only part of the equation but certainly upgrading to a Hsu over your energy will result in a tighter and stronger impact, as well as a more refined sound.
TypeA is offline
post #9 of 16 Old 06-19-12, 06:06 PM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
^^^. Thanks for the input. I'm really excited to get this bad boy and fire it up! My home theater is only 1800 cubic feet... The tech at HSU said this sub will be plenty!
As for the AVR... I use an Elite receiver... And I have a feedback destroyer which I successfully used in conjunction with REW to help tame the Energy. So, I'm hoping I can have some success getting the most from the HSU.
post #10 of 16 Old 06-19-12, 07:52 PM
ambesolman's Avatar
I have a vtf3mk3 and LOVE IT. It's setup upside down firing into my side of the sofa. It'd be right side up but "someone" didn't want it on her side. Hsu said it can even be setup 90deg from normal if need be. This sub rocks with music and movies and plays everything very clearly and has never sounded boomy at all. Only regret is that I couldn't afford the rosenut finish at the time, although the satin black is very nice as well. You bought a great sub and should enjoy it for years to come. Congrats.
ambesolman is offline
hsu , input , mk4 , thinking , vtf2
