Paradigm Ultracube 10 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Paradigm Ultracube 10 in the Manufactured Speakers and Subwoofers forum; Paradigm Ultracube 10 Hello everyone. I'm looking for a pair of active compact subwoofers that'll rock the room (approx 11' x 25') for ...
Old 08-28-07, 09:09 AM   #1 (Link)
New Member
Alias: Harrier Systems
Loc: Singapore
User: #7470
Since: Mar 2007
harrier is offline
Hello everyone.
I'm looking for a pair of active compact subwoofers that'll rock the room (approx 11' x 25') for home theatre application.
Someone suggested the Paradigm Ultracube 10 but I'm not too convinced.
Does anyone has experience with these subs?
Is there any other good alternative? Price in the US$500-$800 each & not bigger than 18" overall size.
Thanks.
Old 08-28-07, 09:28 AM   #2 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Re: Paradigm Ultracube 10
welcome Harrier, I would recommend any of the SVS or HSU subs, but, I don't know if they are feasible in singapore (availibility, and shipping costs). If you can find a local dealer with more than one brand of sub, maybe you could get them to let you try 2 or 3 in your room. I have had Paradigm subs in the past and have been pleased with them, but, they are a bit pricey. Others can give better advice, so stay tuned! Have fun, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 08-28-07, 09:52 AM   #3 (Link)
New Member
Loc: Singapore
User: #7470
Since: Mar 2007
harrier is offline
SVS & HSU looks really good but they're a little too big for my applications.
Any other suggestions?
Old 08-28-07, 09:39 PM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Did you check into the SVS SB12-Plus?
Old 08-29-07, 05:33 AM   #5 (Link)
New Member
Loc: Singapore
User: #7470
Since: Mar 2007
harrier is offline
Thanks for all your help.
The SVS agent here charges too much for the product.
I went for a pair of Velodyne CHT-12R instead.
Hope this is the right decision.
Old 08-29-07, 11:25 PM   #6 (Link)
Alias: Sam
Loc: Adelaide
User: #11091
Since: Aug 2007
a1161979 is offline
Good choice, i had heard the roll of bellow the -3db point of the powercuberwas very steep and its measured -3db was 24hz! I think that you made the right decision
Right choice
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
Paradigm Speakers; Cables?? seamaster32 Home Audio Speakers 3 07-03-07 10:02 PM
Paradigm lcaillo Manufacturer and Vendor Reference Information 0 05-06-07 08:04 PM
First project: Paradigm-like Surrounds Owen Bartley DIY Speakers 29 11-16-06 08:04 AM
Paradigm to DIY transition Owen Bartley DIY Speakers 6 10-19-06 05:32 PM
B&W or Paradigm choice mike c Home Audio Speakers 32 08-04-06 02:29 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
