| Home Audio Subwoofers Subwoofer Tests - Fall 2007Discuss Subwoofer Tests - Fall 2007 in the Manufactured Speakers and Subwoofers forum; Subwoofer Tests - Fall 2007 chengbin wrote:
Does the Gotham have EQ boost? It has the same FR as the f113.
Pretty much any sealed ... |
| | #227 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 Linkwitz showed a long time ago that any sealed system has an FR that drops at a predictable 6db rate. Using an EQ to flatten or even GAIN spL as the frequency drops is an easy electronic fix. What's wrong with EQing a system to gain lower end, the distortion remains low even below 20Hz with the LMS. If it's OK to use the BFD to adjust (EQ) for room anomolies or an active crossover or a Zobel, it should be good enough to EQ a subs lower end. It's the future for subs. Subs should be getting smaller not bigger. | |||
| | #228 (Link) | ||||
| Re: Subwoofer Tests - Fall 2007 Quote: ![]() ps I hope your day after drunk is not too bad and hope you'll be feeling better soon. ![]() | ||||
| | #230 (Link) | ||||
Neil If you're Canadian, please join us at SoundGround.ca! Audio Junkies - Editor | ||||
| | #231 (Link) | ||||
| | #232 (Link) | ||||
Maybe some day I will test the car version of the 13W7 in a ported box. So many woofers, so little time. ![]() | ||||
| | #233 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 It definitely has. No way it could have such flat and well extended frequency response without some serious low frequency boost(s). Oh wait, you haven't seen the FR yet. ![]() Well I can tell you that the -6 dB frequency is ~18 Hz. It doesn't have a natural 12 dB/oct. slope though. | |||
| | #235 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 I noticed that I haven't posted any teasers yet. ![]() Well here we go. A few frequency responses that I really like (for small/mid-sized rooms). Can you guess which ones they are (they contain a very subtle hint)? Neither of them has any 'external' EQ.![]() ![]() | |||
| | #239 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 Oh, now I have to look at the DIYs. No, I haven't found that sub with that FR graph like that. The closest one I found is DIY Chorus XP3 clone. BTW to sonnie, if you haven't read the AVTalk's GP FR graph, I'll tell you right now SVS PB13 20Hz tune will stay rule flat till 19 to 20Hz. 15Hz tune is not as flat down low, but it's definitely not a -6dB @ 20Hz. The sealed tune looks more like the second graph, because the sealed PB13's -3dB point is 22Hz. Last edited by chengbin; 10-22-07 at 08:32 PM. | |||
| | #246 (Link) | ||||
That should narrow them down pretty well, if you have done your homework. | ||||
| | #248 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 Gradient Evidence MKII DIY: DIY CSS SDX15 sealed 100L If I'm not right, here's some hint for the rest of you guessing. Is it not the JL, or the Velodyne, or the Yamaha for sure. They are not flat enough or does not have flat upper bass capabilities. If memory serves, JL's upper limit is 111Hz, and Velodyne's FR graph wasn't flat, and Yamaha, I doubt it. I'm not too sure of other subs. DIY it has to be the SDX15 sealed. The other ones are too powerful. | |||
| | #250 ( |
