| Home Audio Subwoofers Subwoofer Tests - Fall 2007Discuss Subwoofer Tests - Fall 2007 in the Manufactured Speakers and Subwoofers forum; Subwoofer Tests - Fall 2007 Ilkka wrote:
I don't see it like that. Performance at higher frequencies is usually even more important, and there the ... |
| | #51 (Link) | ||||
| Re: Subwoofer Tests - Fall 2007 Quote:
| | #52 (Link) | ||||
| | #53 (Link) | ||||
![]() Do I see a dual LMS-5400 18" sealed 200L (with two CE4000s) in the future? That would be pretty close to my ideal subwoofer. Talk about some crazy output in relatively small package. And the total should still stay below ~$3500. | ||||
| | #54 (Link) | ||||
| | #57 (Link) | ||||
| | #58 (Link) | ||||
Tough the spreadsheet is already pretty wide, so I made a separate one. And I averaged the values from 20 Hz to 80 Hz. I had to estimate the 20 Hz and 25 Hz values for the HSU MBM-12 and the Gradient Evidence MK2. I subtracted 9 dB from the 31.5 Hz and 18 dB from the 25 Hz values.![]() | ||||
| | #59 (Link) | ||||
Ilkka, What was the limitating factor for the LMS PR system? | ||||
| | #60 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 It depends of the frequency. Around the tuning frequency it was the PR excursion, above that the active driver excursion/power handling. The CE4000 still had some (not much) juice in the tank but the driver distortion was already hitting the CEA-2010 limits. The distortion threshold is pretty tight for higher harmonics, for example only 1% for 8th and higher. That's where the suspension (mainly the tall profile surround) starts to make bad noises (it wrinkles) at high excursion. Traditional half-roll surround (like the one in f113 or SDX15) is quieter because it doesn't wrinkle. IMO that's the soft spot of the LMS drivers (and any other drivers using the tall profile surround). | |||
| | #61 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 Ilkka, stop being such a wimp ! Get that Ultra out there and measure it.btw, I've been trying to get an Epik Conquest or Tower shipped to you, but still nothing concrete. But if you are done for the fall/winter testing, then we have time work on Chad to get you something out there later on ![]() | |||
| | #62 (Link) | ||||
When I was talking to Mike at Tc he said the were working on a new rubber for the tall surouds specificaly for the Audiopulse LMS ultra that dosn't cavitate(wrinkle) nearly as much. Would be nice to see measurements of the LMS Ultra to compare. Too bad they are $2999 and anyone who sells them can only sell them in there local area, I know because I am going to be selling them, localy only of course. ![]() | ||||
| | #63 (Link) | ||||
![]() From the CEA-2010 guidelines: "Testing shall be conducted at an ambient temperature of 22C -/+5C and relative humidity of 30% to 80%." | ||||
| | #64 (Link) | ||||
| | #65 (Link) | ||||
| | #66 (Link) | ||||
Around 20 C would of course be optimal but I accept ~10 C or higher. The difference will still be pretty minimal. Colder weather means slightly better results. | ||||
| | #67 (Link) | ||||
bad_weather.jpg brucek | ||||
| | #68 (Link) | ||||
| | #69 (Link) | ||||
When I said that lower temperature means slightly better results, I meant regular long sine sweep tests. They put a lot of heat into VC and ambient temperature plays some role on how the VC dissipates this heat. But the short burst of the CEA-2010 is vastly different. Because it's only 6.5 cycles long, it doesn't create much heat at all. Therefore ambient temperature doesn't matter that much. 10 C or 20 C will give very close to identical results. That is one more reason why I started to use it: accuracy and especially consistency. And in any case, the ambient temperature for rounds 4 and 5 was within 2-3 C. | ||||
| | #70 (Link) | ||||
| | #71 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 We're well aware of that higher order harmonic in the surround, its a trade off of excursion. We're working in a few different FEA programs and designing a new tall surround which will probably be made out of a new material too to shave mass and not not cavitate.,We should be able to attenuate that distortion substantially, in fact we already have a working miniature prototype in a 5.25" model. We wont have our new surrounds done for a long while, but its already in the works. I want to give a big thanks to Ilkka for making all these measurements. Simply posting data without any relative comparisons is not nearly as meaning full. Its interesting to see how different products stack up again ts one another. I'm curious to see this new SVS, I know they did a great job on the driver and that big under hung motor should be very linear. | |||
