| Home Audio Subwoofers Subwoofer Tests - Fall 2007Discuss Subwoofer Tests - Fall 2007 in the Manufactured Speakers and Subwoofers forum; Subwoofer Tests - Fall 2007 SteveCallas wrote:
Did a search and found it was actually Bob, not Brian.
Yeah, I remember that. That's obviously a ... |
| | #126 (Link) | ||||
| Re: Subwoofer Tests - Fall 2007 Quote:
I have yet to seen a picture of a thermally damaged VC on these forums. Every single one has been a mechanical failure. | ||||
| | #128 (Link) | |||||
![]() Quote:
| | #129 (Link) | ||||
| | #130 (Link) | ||||
If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | ||||
| | #131 (Link) | ||||
![]() So for me a subjective good criteria, is not noticing the speakers or the subwoofer. If I crank up the sub level above calibration -- then I notice the sub. | ||||
| | #132 (Link) | ||||
![]() Honestly I may go the re-cone route, since theres already so much objective information about the SDX-15 at this point. Thanks again Ilkka ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | ||||
| | #133 (Link) | ||||
A fried VC is hard to see unless you remove the damaged parts. I'm leaving the the Cadence speaker as is while I decide whether or not to have it reconed. The Cadence voice coil of course had bottomed out and then blew the dust cap off just before the VC separated from the cone and tore off almost all of the suspension spider. The VC remains attached to the wire leads and the surround was not torn from the basket or damaged. I checked the VC for electrical continuity and of course there was none. | ||||
| | #134 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 I would strongly recommend against using Robot underground for reconing your Tumult. I've met Patrick before and he seems like a nice guy and everything. However, he's using the wrong coil design. XBL^2 design are sensitivity to using the right coil length and he's not even close. This totally screws up the BL curve (creating a huge BL peak in the center 5 mm or so of travel). I'd definitely talk to Scott at www.ficaraudio.com (or in his forum here). I believe that he still stocks that coil. If not, he could use the REXXX aluminum coil (but with a single soft spider). | |||
| | #135 (Link) | ||||
I'll wait to hear back from Fi. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | ||||
| | #137 (Link) | ||||
Your test are highly respected and others including myself are very interested in how it objectively test out. Especially in the distortion area. | ||||
| | #140 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 The lists below now contain these new entries: SVS PB12-NSD new SVS PB13-Ultra 10 Hz SVS PB13-Ultra 15 Hz SVS PB13-Ultra 20 Hz SVS PB13-Ultra sealed I believe Ultra's four tuning frequencies/settings go without saying. The "PB12-NSD new" is the latest revision of this model. Performance of the new PB13-Ultra in all settings, but especially in 20 Hz and 15 Hz, is very convincing. From all the subwoofers I have tested thus far (using the CEA-2010 test), in addition to the JL Audio Fathom f113, the new Ultra is the only commercial subwoofer that can even slightly tremble the "top 10" ruled by the all mighty DIY subwoofers. Pictures from today (starting from #93) Yes, I was able to blow the internal main fuse of the PB13-Ultra - twice. It didn't seem to like my 30 second long sine sweeps at extreme levels (I was expecting this based on AV Talk's measurements though). More dynamic signals like the CEA-2010 bursts didn't cause any troubles, even at extreme levels. It shouldn't be possible to blow the fuse using regular program material. This "problem" doesn't have anything to do with the other PB13-Ultra amp problem (shut-down due to bad batch of components combined with sagging 110 V voltage). There are no reports of shutting down 230 V versions of the new Ultra. Alphabetical list: ![]() "Low-bass Avg. 40 Hz - 63 Hz" list: ![]() "Ultra low-bass Avg. 20 Hz - 31.5 Hz" list: ![]() "Avg. 20 Hz - 80 Hz" list (operating range of a normal/good subwoofer): ![]() | |||
| | #141 (Link) | |||
| Re: Subwoofer Tests - Fall 2007 I would like to see how the css sdx15 stacks up in a 200L vented. tuned to about 18hz. Maybe I'll have to send you one(Fw 15.1) the singe tc2000 ported seems to outdo the dual tc2000 sealed. SDX 15 would do the same? | |||
| | #143 (Link) | |||||
![]() Quote:
Also the single TC-2000 90L had an off-spec driver, so its performance either doesn't represent a "proper" TC-2000 in a 90L sealed enclosure. Hopefully I will be able to test these again some day. | |||||
| | #145 (Link) | ||||
![]() It's corrected now. Although I haven't yet checked the real measured tuning frequencies. I will promise to do that soon. | ||||
| | #146 (Link) | ||||
Yah I tried to keep it on the smaller side without loosing too much 200L seemed to be reasonable. I may offer a larger one with a little lower tuneing later on. | ||||
