Subwoofer Tests - Fall 2007 - Page 9 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Subwoofer Tests - Fall 2007 in the Manufactured Speakers and Subwoofers forum; Subwoofer Tests - Fall 2007 SteveCallas wrote: Lastly, I'll never be a fan of the concept of reducing port area to achieve a lower tune ...
Old 10-20-07, 09:09 AM   #201 (Link)
Alias: mojomike
Loc: South Florida
User: #6557
mojomike is offline
Re: Subwoofer Tests - Fall 2007
SteveCallas wrote: View Post
Lastly, I'll never be a fan of the concept of reducing port area to achieve a lower tune - that's about as backwards as you can get. The low end numbers look nice in the lower tuning modes, but the onset of audible chuffing becomes that much more of a reality.
Steve, the port limitations don't seem to be a problem at the 15hz tune. You'll notice that there is very little loss of efficiency in this tune compared with the 20 hz tune. I haven't seen any port chuffing in either 20 or 15hz tuning. As for the 10hz mode, I doubt a single 3.5" port could be sufficient. There is a marked loss of efficiency in this mode and I'm sure it's underported here. Chuffing here could be a problem, but it should only show up with very low frequencies.
Old 10-20-07, 04:13 PM   #202 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Peter Marcks wrote: View Post
The Conquest must be tuned somewhere in the 15Hz area (give or take 1-2Hz).
Sorry but I don't agree. When looking at the external measurements, the internal net volume can't be much more than around 240 liters (1" walls, 2" baffle, bracing, driver, ports). That means 15 Hz tuning would require around 2 meter long ports!
I'm guessing that the Conquest is tuned much higher, maybe around 20-22 Hz.
Exocer wrote: View Post
wow, just wow. Can't wait for Ilkka to get his hand one one...
I will test them as soon as Chad gets some 230V amps.
Just out of curiosity, ~ what tuning point could one achieve from plugging one of the Conquest's ports?
If assuming native is ~22 Hz, then single port would be ~15 Hz.
Old 10-20-07, 04:21 PM   #203 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
WillyD wrote: View Post
And what the PB13 can do for its enclosure size/porting solution doesn't impress me. It is a pretty big sub as far as commercial subs are concerned. Around 200gross liters, right?
The net internal volume of the PB13-Ultra is around 120 liters. So it's more than twice smaller than the 270L LLT.
The qusi-LLT isn't that much larger than the PB13. About 3ft^3 larger, eh?
I've seen them both in reality. Believe me, the 270L LLT is MUCH larger (footprint of course is pretty similar).
When I saw the PB13-Ultra for the first time (and still), I actually thought it looked really small. It's much smaller (height) than, say, the older PB12-Plus/2.
Old 10-20-07, 08:26 PM   #204 (Link)
Alias: chengbin
User: #12625
Since: Oct 2007
chengbin is offline
IIkka, do you mind putting the f113 driver in a large enclosure such as the size of a PB13U and test it? Thanks. I'm sure the result will be very interesting.
Old 10-21-07, 02:42 AM   #205 (Link)
DLS
New Member
Alias: DLS
User: #11675
Since: Sep 2007
DLS is offline
chengbin wrote: View Post
I was just thinking about the same idea 13w7 driver in PB13's type of design.
Having working with the 13w7 car audio driver (I would guess this one in fathoms is similar), maybe big LLT won't work well in terms of SQ. But something like 130-150L tuned to 20 or below Hz may be a pleasant surprise
Old 10-21-07, 12:51 PM   #206 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is online now
If a driver is designed to work best in a small sealed enclosure, that typically means it has a very low Qts, which means it won't work well in a large ported design, as the low end will be way too peaky. If you make the enclosure just the right size for a low frequency tuning, you end up with not enough volume to use proper porting.
Old 10-21-07, 02:05 PM   #207 (Link)
DLS
New Member
Alias: DLS
User: #11675
Since: Sep 2007
DLS is offline
Actually, if my analogy with the car version of W7's is right, then Qts isn't that small at all - 0,448. I could guess its a little over 100L VAS is no good for ''real'' LLT, but simulations shows pretty good results in let's say 150L. In this case Fb could be 20 or even less Hz and the graphs looks good, no peakyness. The port area I think would be almost enough while keeping the first port resonance high enough not to be a concern.
The only thing I have doubts about is the acceptable level of GD.
I'll do some modeling to check again if the old calculations I've done for this driver confirm my thoughs above.
Old 10-21-07, 02:40 PM   #208 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Thats what I thought as well.
Wow, I had no idea that it was only ~120liters net. Kind of hard to believe!
Old 10-21-07, 03:42 PM   #209 (Link)
Alias: chengbin
User: #12625
Since: Oct 2007
chengbin is offline
That's not true. if JL wanted to, they could of build a enclosure that allows the driver to extend flat to 5Hz!! But they didn't because it would be inappropriate. http://home.jlaudio.com/pdfs/AbsoluteSound.pdf. Read the last page. I think if some DIYers wanted to, they should be able to get it to extend flat to 10Hz easily. Then measure it, the results will be very interesting.
Old 10-21-07, 04:12 PM   #210 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Sorry guys, I'm too excited (and drunk ) because of Kimi's World Championship (Formula 1 to all of you Americans ) that I can not answer to your questions right now. I'll tackle them tomorrow.
Forza Kimi!! Forza Ferrari!!
Old 10-21-07, 05:43 PM   #211 (Link)
Alias: PHIL
Loc: SHERMAN, TX
ISLAND1000's Avatar
User: #8655
Since: May 2007
ISLAND1000 is offline
Listen to him . . . . . "he's too drunk" !! Our test man . . . . too drunk!! What's this world coming too . . . . and who's this KIM person . . . . . have WE given her an OK?
I dunno Ilkka . . . . . we might be looking for your replacement soon . . . . . craigsub, you still out there???? LOL
Old 10-21-07, 06:03 PM   #212 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
ISLAND1000 wrote: View Post
http://www.formula1.com/
http://www.ferrariworld.com/FWorld/fw/index.jsp
Her???
Old 10-21-07, 07:03 PM   #213 (Link)
Alias: Steve
User: #263
Yeah, ok If they piled on enough EQ to get their sub flat to 5hz, max headroom while staying flat to 5hz would be well under 90db - what's the point in that?
20hz tuning and a 4" port is not a LLT, far from it. And maybe I'm out of the loop, but I don't believe JL has ever released the TS parameters of the driver used in the sub in question.
Old 10-21-07, 07:11 PM   #214 (Link)
Alias: chengbin
User: #12625
Since: Oct 2007
chengbin is offline
I'm very sure they mean without EQ boosts, but like incredibly large enclosures with multiple ports tuned really low, or other ways to boost bass without EQ.
Old 10-21-07, 07:40 PM   #215 (Link)
Alias: Neil Middlemiss
User: #11689
Since: Sep 2007
DevilDriver is offline
From what I have been told, the driver used in the Fathom and the Gotham employs a similar motor to the W7 with more BL, more excursion, and more power handling (probably via a larger coil). If that's the case (without too much mass), that would push the Q down a bit and make it more suitable for a small, sealed enclosure.
But no, I've never seen any measured parameters. Maybe someone should take theirs out and test the driver itself, thoroughly.
Neil
If you're Canadian, please join us at SoundGround.ca!
Audio Junkies - Editor
Old 10-21-07, 08:03 PM   #216 (Link)
Alias: Steve
User: #263
That's not gonna happen. I'm using a 7' tall, 650 liter enclosure with an 18" driver, and there's no way even that could be tuned and stay flat to 5hz. The port length would be far too long, and no driver can displace enough air to naturally stay flat that low.
You'd need multiples of drivers in a SLLT as wel as some potent room gain. Or even more drivers in an IB and plenty of EQ.
Old 10-21-07, 08:16 PM   #217 (Link)
Alias: chengbin
User: #12625
Since: Oct 2007
chengbin is offline
Is there any EQ boost on the F113? I don't think so, but I'm not 100% sure.
BTW, that's a HUGE sub you're using. WOW. The PB13, with "only" 120 liter enclosure, is very big to me. 600 liters, my...
Old 10-21-07, 08:28 PM   #218 (Link)
Alias: chengbin
User: #12625
Since: Oct 2007
chengbin is offline
How do you calculate the length and width of a port for a certain frequency?
Old 10-21-07, 08:47 PM   #219 (Link)
Alias: mojomike
Loc: South Florida
User: #6557
mojomike is offline
You can bet that the f113 has built-in EQ boost. Woofers in relatively small sealed boxes will have a natural roll starting fairly high up. For the f113 to have a flat response to below 20hz, it must have EQ. It is part of why it need such a powerful amp.
Old 10-22-07, 01:29 AM   #220 (Link)
DLS
New Member
Alias: DLS
User: #11675
Since: Sep 2007
DLS is offline
150L, 16Hz Fb, 5" port - that's what I had come with some time ago. F3 is 26Hz, FR looks good and smooth .
And again I'm asuming the car and home versions of W7 being identical.
Actually, Steve, maybe that's not a "real" LLT, but doing such designs I'd never happen to run into your theory (exellent work btw ) since recently.
Old 10-22-07, 01:44 AM   #221 (Link)
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
noah katz is offline
"If a driver is designed to work best in a small sealed enclosure, that typically means it has a very low Qts, which means it won't work well in a large ported design, as the low end will be way too peaky."
A driver optimized for sealed has a higher Q for two reasons:
1) High Mms (which raises Q) will be needed to get a reasonably low Fc
2) Being a single-mass system, it will be overdamped with low Q; vented systems need extra damping to control the second mass (port air/PR)
Old 10-22-07, 04:13 AM   #222 (Link)
Alias: chengbin
User: #12625
Since: Oct 2007
chengbin is offline
I thought so too. Does the Gotham have EQ boost? It has the same FR as the f113. Is the gotham just 2 W7 13 drivers in an enclosure? If it is, then why is it 3 times the price of a f113?
Old 10-22-07, 05:27 AM   #223 (Link)
Alias: Egil
User: #7267
Since: Mar 2007
Egil is offline
If I remember correctly, the Gotham has different drivers.
EQ boost? Yes.
Old 10-22-07, 05:42 AM   #224 (
