Rythmik LV12R Subwoofer Discussion Thread - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 8Likes
post #11 of 208 Old 05-15-13, 10:19 AM
monomer
Re: Rythmik LV12R Subwoofer Discussion Thread
A really nice review. I like the style you chose to present in... less geeky and more down to earth description based. After all anyone can go to the website if they wish to see more graphs and specs.
Okay so let me testify:
Yes, the Rythmik's Direct Servo application really does clean up the bass. I've had two F12s for just about 4 years now. They ooze quality in every way... both in build and sound and Brian's service to the customer, both before and after the sale, is legendary. He even helped me... encouraged me... to perform an optional mod a while back (sent me the resistors with instructions etc)... he is an EE. He's a honest business man and a knowledgeable guy who stands behind his product... seems to be fewer and fewer of those type around these days. Back when I purchased my first F12, I thought I was taking a gamble by not having heard a Rythmik before but from reading all the reviews I could find at the time I noticed no one had anything bad to say about Rythmiks so... I took the plunge. When I got it set up and properly integrated into my system, I took the time to carefully listen to music I was quite familiar with and I was simply amazed... so much so I turned around and ordered a second F12 the same day. I'd never heard bass so clean before... I'm not an SPL kinda guy, I'm a SQ-oriented guy that likes everything to sound as real as possible. However I will say that I find the strength of this Direct Servo application to be found mainly in the range below 60Hz and I believe Brian would also agree with me. Above 80Hz its contribution is not really noticeable over the non-servo competition. Eventually after trying a number of set-up iterations in my theater, I've settled on using the F12s as ULF units and I now use dedicated mid-bass units. For awhile now I've been a proponent of splitting up the traditional subwoofer bass frequency range in two to be delivered by units dedicated to each range... that's just me and with the ultra-clean sound of the Direct Servo in the lower freqs the Rythmiks are the natural choice.
The F12 is a sealed design but from what I've read about all of Brian's ported models, they appear to not differ in SQ from the sealed models. The only change I would make if I had it to do over again is I would have purchased the 15" instead. Brian had suggested from the outset that I wait for the F15s to arrive but at the time the wait was 3-4 months out and I simply couldn't have waited that long. I didn't know if a single 12" 300-watter could cut it in a 2100 cu-ft basement but I was willing to give it a try... as I've said, I'm not really an SPL kinda guy. We generally watch movies about 10dB below reference which is plenty loud really... I just really need to have everything sounding as authentic/accurate as possible. The single F12 was actually enough to pressurize my basement theater without compressing at the bottom end but I know from past experience that my room's acoustics really demanded two subs for better freq smoothing in the 80-30Hz range so that was really why I got the second one.
Usually whenever I hear some one knocking the Rythimk, its either an SPL guy (you know the kind that thinks a home subwoofer is supposed to sound like the one in his "boom-boom" ride... all SPL and no quality or depth) or someone who's never actually heard a Rythmik. You'll wanna take comments from those type guys with a grain of salt.
monomer is offline
post #12 of 208 Old 05-16-13, 09:55 AM Thread Starter
HTS Moderator
Reviewer
theJman's Avatar
Jim
monomer wrote: View Post
Thank you. I'm glad you found the review beneficial. From the very beginning I wanted to write in a manner that differed from what most others were doing, and that meant conversational as opposed to technical. I do try and present a balance, but I lean more towards descriptive accounts than objective ones. Thus far it has served me well, and the vast majority of comments have been positive, so I don't envision changing my style going forward.
-Jim
theJman is offline
post #13 of 208 Old 05-24-13, 05:53 PM
steve nn's Avatar
steve
Nice job Jim.. I would really enjoy trying LV12R out. Seems to be a great sub at a nice price.
steve nn is offline
post #14 of 208 Old 07-07-13, 10:37 AM
afterlife2's Avatar
Joe
Fantastic review J. Love the way you write your reviews and really explain everything where an amateur can understand, like myself. By the way TEN is my fav Pearl Jam CD as well. Maybe one day I can get a LV, but right now the OSD is a rockin'! Keep up the great great great work.
afterlife2 is offline
post #15 of 208 Old 07-07-13, 11:34 AM Thread Starter
HTS Moderator
Reviewer
theJman's Avatar
Jim
Re: Rythmik LV12R Subwoofer Discussion Threada
afterlife2 wrote: View Post
Thanks Joe - I'm glad you enjoyed the review. And I'm happy the little OSD sub is still working good for you!
-Jim
theJman is offline
post #16 of 208 Old 07-07-13, 12:01 PM
Bjski's Avatar
BJ
Hi,are there any companies making cabinets for subwoofers other than Parts Express. I am not very good at wood working but I can put a speaker together and stain it if need be. I see that Rythmic offers several subwoofer kit's but nothing about cabinet's. I wouldn't mind assembling 2 kit's or should I just keep saving my pennies and buy the finished rythmic product?
Bjski is offline
post #17 of 208 Old 07-07-13, 01:10 PM
afterlife2's Avatar
Joe
Bjski wrote: View Post
Here Is one. You will need to make a hole for the amp though: http://www.sonicelectronix.com/item_...va-MDFS12.html
post #18 of 208 Old 07-07-13, 02:33 PM Thread Starter
HTS Moderator
Reviewer
theJman's Avatar
Jim
There are several, but it would be better to start a new thread in the DIY section specifically to address your needs. This one is intended for all things directly associated to the LV12R .
-Jim
theJman is offline
post #19 of 208 Old 07-07-13, 04:00 PM
THESE would also work with the Rythmik kits. The 2 cu.ft. for the 12" and the 3 or 4 cu. ft. for the 15". The 3 cu.ft. would model the Rythmik E15 while the 4 cu.ft. would model the F15/F15HP.
You can contact Erich directly about the dimensions for the cutouts - he's a fantastic person - and I believe the Rythmik drivers have very similar if not identical dimensions to the Dayton Titanic series. I would still double check though.
Edit: Sorry for clogging up your LV12 review thread Jim.
TheLaw612 is offline
post #20 of 208 Old 07-07-13, 06:30 PM
Bjski's Avatar
BJ
Thanks afterlife2 and TheLaw612 for quick response. Sorry theJman for clogging your thread. I'm thinking of a Rythmik 12 inch kit so thought it might be a good place to ask seeing you reviewed a 12 inch Rythmik. My apology.
Bjski is offline
discussion , lv12r , rythmik , subwoofer , thread
