| Home Audio Subwoofers New SubDiscuss New Sub in the Manufactured Speakers and Subwoofers forum; New Sub Sub.
Hello I just purchase a sub for my home speakers, how is the best way to connect?
Thanks..... |
| | #2 (Link) | |||
| Re: New Sub Hi there, Most people connect directly to the "sub out" of their receiver. Do you know if your receiver has a "sub out?" If not, you may need to connect using speaker level signal, or perhaps a line-level preamp output from the L/R. Are you planning to use for home theater use, or just music? -- Otto | |||
| | #3 (Link) | ||||
| Re: New Sub Quote:
Is this true? Plan to use for HT, movies. | ||||
| | #4 (Link) | |||
| Re: New Sub You definitely want to connect to the sub out, then. First, it will allow you to use the bass managment of your receiver. Second, it will allow you to effectively obtain the LFE channel of the DVDs you may be watching. Start by setting your crossover point to 80 Hz. Set your levels with an SPL meter if you have one. Once you have that up and running, let us know if you have questions or problems. As to connecting a sub with a speaker-level signal, I wouldn't necessarily think it would be better or worse (assuming everything is implemented properly). One downside to it is that you are amplifying things twice, and thereby creating more noise in the signal. Still, in a sub, that could be considered negligible. -- Otto | |||
| | #5 (Link) | |||
| Re: New Sub Otto, Thanks for all this info. The sub out is the way I will go. I'm anxious to get it up and running. Now a trip to RS for the cable I need. Any suggestions on which cables works best? | |||
| | #9 (Link) | ||||
| Re: New Sub Quote:
As far as a RCA cable just get a decent $20 cable (the thicker kind) that has good connectors. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | ||||
| | #14 (Link) | ||||
| Re: New Sub Quote:
