| Home Audio Subwoofers Passive radiatorDiscuss Passive radiator in the Manufactured Speakers and Subwoofers forum; Passive radiator Hi Guys,
I have a sub consisting of a 12" peerless driver and a matching passive.
As it stands at ... |
| | #1 (Link) | |||
| Passive radiator Hi Guys, I have a sub consisting of a 12" peerless driver and a matching passive. As it stands at the moment, the passive faces down to the floor and the driver faces into the room, If I was to swap the Two around, would that make a difference in the performance. Peter ![]() | |||
| | #3 (Link) | |||
| Re: Passive radiator Not a performance issue but I understand from John J of AE Speakers that you should never mount a PR face down or up. The suspension of a PR can not handle the sag. IIRC there is a formula that you can use, given a driver's parameters, that can tell you if it is ok to mount a driver face down or up. Is your sub a DIY design? Bob | |||
| | #4 (Link) | |||
| Re: Passive radiator Hi Guys, Firstly let me say thanks for replying to my question, This sub was a kit from a local retailer, I did some mods to it to make the box a lot more rigid, and replaced some of the power amps wiring to something a bit more substantial, So place the drive underneath facing down and the PR facing into the room, Ok I had a feeling that how it goes but you guys confirmed it, Ok first thing in the morning , the soldering iron comes out. Thanks again guys....................Looking forward to getting my BFD 1124P Peter | |||
| | #5 (Link) | |||
| Re: Passive radiator Hmmm....VMPS have been mounting their passive radiators horizontally for years. http://www.vmpsaudio.com/technical.htm#07bassys | |||
| | #7 (Link) | |||
| | Re: Passive radiator Yes... very low moving mass on the VMPS PR's. They further use dough to weigh them... which can be pinched. I don't rightly understand all of it and I've pinched mine according to the instructions, but can't tell a difference. It still seems like I'm missing some of that mid-bass. Maybe the replacements will be different. | |||
| | #8 (Link) | |||
| Re: Passive radiator I would take that "very low moving mass" stuff as marketing talk. I had a VMPS Smaller Subwoofer (now known as a Dedicated Subwoofer) and its PR was a normal pulp cone with a spider and a foam surround (which eventually failed). Where do you reduce moving mass on a PR? Cone, surround, spider or dust cap? That's all there is. I would think that a PR has as much need for a stiff cone as an actvive woofer but, relatively speaking, all PRs have "very low moving mass" when compared to a comparable actve driver. VMPS's whole approach is to add moving mass to tune the subwoofer so I gotta question this orientation info. Also, I do not recall anything in Peerless's information regarding orientation of their PRs. | |||
| | #9 (Link) | ||||
| Re: Passive radiator Quote:
![]() Close mike'd the driver to find out its tune: the TrueRTA freq response with normal 1/24th octave and also 1/6 octave smoothed (shifted up by 10 dB) Note that the SPL levels are not calibrated in the plot above. Just doing a relative freq response measurement there. Got up to 110 dB in room SPL before my circuit breaker popped. Mackie M1400 pro amp driving sub at 30 Hz sine in a 7000 ft^3 room. Finally measured harmonic distortion at 2% @ 13 Hz 102 dB SPL using a LinearX M31 calibration mike. Bob | ||||
| | #10 (Link) | ||||
| | #11 (Link) | |||
| Re: Passive radiator Hi Guys, Later today I will swap the drivers around............ I think my next step in this "Hobby" is to get a calibrated mike to use with my software, That should help to realy tune my sub. BTW. Thanks to all for posting replies to my questions.........for some one like me ( not quite up to speed ) it is a huge help. Peter ![]() | |||
| | #12 (Link) | |||
| Re: Passive radiator This design may be similar to what you have: http://www.vikash.info/audio/xls10/ The Peerless PRs have exactly the same moving components as their comparable active drivers with mass added to acheive desired tuning: http://www.speakercity.com/Merchant2...ct_Code=830548 Application notes from the Peerless site: http://www.tymphany.com/papers/appxls12b.htm Lots of information available about these drivers by Googling “Peerless passive radiator” but can not see anything about PR orientation. Let us know if swaping makes a difference. | |||
| | #13 (Link) | ||||
