Dual sub wiring and amplification - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Dual sub wiring and amplification in the Manufactured Speakers and Subwoofers forum; Dual sub wiring and amplification I just bought 2 older Snell 750Thx passive subs and need to Know the best way to wire and power ...
Old 11-11-07, 09:02 PM   #1 (Link)
Alias: pwest
Loc: umbarger texas
User: #2976
Since: Oct 2006
pwest is offline
Question Dual sub wiring and amplification
I just bought 2 older Snell 750Thx passive subs and need to Know the best way to wire and power them.The subs are rated at 200 watts @ 8 ohms. I have a Yamaha P2201 pro amp that is rated 230 per ch. @ 8 ohms,But Crown recommends 1.6 to 2.5 the power for the speaker rating, So shouild I get a higher power amp and bridge it? Then what is the best way to wire them? in series or parallel? and do I keep my Velodyne CT-120 in the system or retire it? I will be feeding the subs from the sub pre out of my receiver
Old 11-12-07, 12:34 AM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Re: Dual sub wiring and amplification
Hey there pwest,
If I understand everything correctly, I'd probably start by running each of the two Snell subs on each channel of the Yamaha amp. See how that goes.
I always like to have more power than necessary, but I'm thinking you should be OK with that amp. If you find that it's running out of steam, you might consider a pro amp such as a Crown, QSC, Behringer, etc.
You'll have to see about the Velodyne. Will you need it? Not sure. Get the Snells going, do some room measurements with REW and then see what's up.
Anyway, there are some ideas off the top of my head.
Good luck!
-- Otto
Old 11-12-07, 04:37 AM   #3 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Just to clarify, the Yamaha P2201 is rated 200 watts per ch. @ 8 ohms, not 230 watts.
http://www.yamaha.com/yamahavgn/CDA/...5253DY,00.html
Just be careful not to clip the amp.
Old 11-12-07, 07:57 AM   #4 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Pwest, you should probably wire them is series unless your amp can handle larger current loads. The load in series would be @16 ohms where as in parallel, depending on the reactive characteristics of the subs, could go below 8 ohms and possibly damage your amps. The more power you can use, the more headroom available for your bass. With both subs hooked up, you will not exceed their power rating. Hope this helps. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 11-12-07, 08:09 AM   #5 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
drdoan wrote: View Post
But he's got a stereo amp (that claims to deliver 350 WPC into 4 ohms) and stereo subs. If that's the case, don't you think he should just use the Left Channel to drive one sub, and the Right Channel to drive the other?
-- Otto
Old 11-12-07, 08:45 AM   #6 (Link)
Shack Moderator
Alias: Dr Doan
User: #2314
Since: Aug 2006
drdoan is offline
Right, I missread his post. If using a stereo amp, then just hook up one sub per channer. Thanks for pointing that out. Of course, he doesn't have to worry about the amp power being higher than the rated speaker wattage as long as he doesn't over drive the subs. Dennis
L Dennis Doan, DC
IT'S THE NERVE!
www.drdoan.com
Direct TV DVR HD
Old 11-12-07, 08:40 PM   #7 (Link)
Alias: pwest
Loc: umbarger texas
User: #2976
Since: Oct 2006
pwest is offline
Thanks for the responses. The receiver is a HTR-5890 Yamaha 7.1 THX. I thougt the simple way to do this was run a y conector from the sub pre-out to the left and right inputs on the amp and hook up a sub to each channel. The owners manual states power on the amp is 200 watts at 20 to 20KHZ or 230 at 1KHZ. both channels driven. This amp is temporary because I will be using it for the front channels after I buy 2 more yamaha amps for surround and surround back channels. I am thinking Crown for the subs .
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
CAT5 wiring toecheese Home Theater Design and Construction 24 10-05-07 02:22 PM
Need some thoughts on a large dual 15", dual ported design. erikhtb SoundSplinter 43 05-24-07 05:56 PM
Need input on a dual RL-p15, dual port design erikhtb SoundSplinter 0 05-15-07 01:42 PM
Newbie wiring help. mgboy DIY Subwoofers 11 03-13-07 09:24 PM
I Need wiring help!! Fred225 Remotes | Cables | Accessories 2 12-12-06 01:05 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
