Help With Subwoofer Choice For Large Room - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Help With Subwoofer Choice For Large Room in the Manufactured Speakers and Subwoofers forum; Help With Subwoofer Choice For Large Room Hello All- I am currently looking/researching for a sub or subs which will be the final piece (at least for ...
Old 08-24-06, 02:46 PM   #1 (Link)
Alias: Mark
Loc: Swansboro, NC
User: #2187
Since: Aug 2006
Mark64 is offline
Hello All-
I am currently looking/researching for a sub or subs which will be the final piece (at least for now ) of my audio/video system in my greatroom. I've been reading and soaking up info here and decided to post to draw from what is obviously a great base of knowledge here.
My room is 28'Lx20'Wx20'H which is 560 sq feet but more importantly 11,200 cu feet. The floors are hardwood with an area rug which covers 2/3 of the floor area, some upholstered furniture as well as some fabric window treatments. There is an opening at the right rear corner of the long wall which opens to kitchen/breakfast nook, another one at the left rear corner of other long wall which is a hallway to front door, then another above that at 2nd floor level which is an open diagonal balcony serving the 2nd floor.
I currently have a Harmon/Kardon AVR325 receiver, Definitive Tech Mythos One towers, Mythos Three center, Mythos Gem surrounds, and another Gem for the back surround.
We enjoy action/adventure type movies and musical tastes range from contemporary jazz to Natalie Merchant/ Sarah McLachlan to country to Nickelback/Creed/ Metallica depending on the mood and the day. We probably use the system about 75% TV and movie watching and 25% music. But with that being said I really want to start with music and get it right and I sort of feel that the HT will fall into place. I am hoping for tight, accurate, tuneful bass which is not boomy or sloppy. I don't mind being knocked off the couch by special effects, I just hope it doesn't have to be at the expense of the musical reproduction.
The following subwoofers have my interest as possibilities either alone or in some cases in tandem: (not a hard and fast list but rather a work in progress)
ACI- Force XL, Titan XL, or Maestro XL
Def Tech- Supercube I or Reference (local dealer where I purchased my speakers has these)
SVS- PB12/+2 (Eric at SVS recommended this)
M&K- VX-1250SFX THX (currently $599 for refurb at the M&K website)
Paradigm- Servo 15 v.2 ( have seen on Audiogon used for $800-$1200)
James- EMB-1000, 1200, or 1500 ( Closest James dealer 2 Hour drive)
Monitor Audio- RS-W12
HSU- VTF-3 MK 2
My budget is about $1300-$1600, but if, due to my large room, it will take more, then I'll just save a little longer. I would like to make the purchase in the next 3 months or so. I realize I do not have an "audiophile" system and due to the size of the room, I probably cannot afford to get reference level type bass. That being said, I just want to do the best I can do within my budget and get decent bass response for music and movies, and to feel some of the movie bass if possible. I am open to any and all comments on my situation and especially hope that owners of some of these models listed will chime in as well as someone with a large room like mine. I have undoubtedly left out some good subs to consider so please expand my list if you've got something for me. Should I be looking at only sealed subs for tightness/accuracy or would some of the better ported subs also have this quality? Thanks ahead of time to all, and if any additional info is needed just ask. I did post all my equipment on my profile but only listed here what I felt was relevant to sub choice.
Mark
Old 08-24-06, 06:08 PM   #2 (Link)
Alias: Bob
Loc: Pittsburgh, PA
khellandros66's Avatar
User: #962
Since: Jun 2006
khellandros66 is offline
Re: Help With Subwoofer Choice For Large Room
If It were me, I would go with two SuperCube Reference or SVS PB12-Plus/2
~Bob
Old 08-24-06, 08:54 PM   #3 (Link)
Alias: Phil
Phil M's Avatar
User: #20
Phil M is offline
I dropped a room sketch to SVS and let them come up with a proposal/recommendation - it worked OK for me, and mention your dual needs.
Old 08-24-06, 10:43 PM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
I have dual Plus/2's in my 1800 cubic foot HT room... over kill yes, but awesome! You got a lot more cubic feeties so I'm thinkin' a pair, but that get's outside your budget. I don't know for certain, but I'd sure be suspect of only one of any sub in that big of a room... that's just me though. Of course you do get two subs in the Plus/2 and one might do the trick.
Old 08-25-06, 03:20 PM   #5 (Link)
RSH
Ultimate Rep
Alias: Roman
Loc: NJ
User: #1787
RSH is offline
I owe to yourself to listen to the James Loudspeker EMB subwoofers - the most musical, fast and accurate subs I have ever heard.
Roman
www.rtheaters.com
sales@rtheaters.com
732.617.2348
Old 08-25-06, 03:37 PM   #6 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Sonnie wrote: View Post
If you don't want to do DIY or IB then I agree with Sonnie for your size room and movie playback desires. Get two dual driver ported subs. SVS gives a lot of bang for the buck.
Bob
Old 08-25-06, 09:52 PM   #7 (Link)
Alias: Bob
Loc: Pittsburgh, PA
User: #962
Since: Jun 2006
If it falls in your budget two SVS PB12-Plus/2 is $2400+shipping and each are prolly 85-90% of the PB12-Ultra/2 performance.
~Bob
Old 08-27-06, 07:03 PM   #8 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Welcome to the Forum Mark!
Hmm – bad news. Basically it’s all space the sub has to fill with bass, so it all has to be counted. When the openings are small, like a doorway, it isn’t as bad, but that second floor thing sounds like a big hole in the side of the ship, as it were. Not good.
Since you’re primarily interested in TV, that might be your salvation. Assuming we’re talking about regular programming and not 5.1 PPV fare, TV bass is much less demanding than DVD movie bass or even music bass. One of the better SVS subs should have no problem getting response down to 25 Hz, even in a space that big, and can probably make a good presentation even with DVDs.
What you’re probably going to be lacking is bass dynamics – i.e., impact – in movies: Scenes like the ring drop in the first chapter of the first Lord of the Rings movie, or the depth charges in U-571. The dynamics require lots of headroom, both from the driver and the amplifier. That’s a pretty tough order in a huge space. I’d be surprised if there is a single sub on the market up to the task, and certainly not in your price range. Indeed, it most likely will require at least a couple of highly capable subs a room this big, maybe even more.
I think what you’ll find with most of the subs these days using BASH digital amps is that their output is limited to protect the driver. If the sub is marginal for the room, you can see the effect in a demanding DVD passage – i.e., one where it seems the bass could be stronger. You crank the sub up higher and play the scene again, and you notice you don’t get any more than you had before.
Since you’re primarily interested in TV, it probably isn’t worth the expense and the visual blight to achieve high-impact performance. The SVS guys have a good reputation for making recommendations in matching a sub to the room. If you find the one they recommend isn’t quite up your needs, you could always add a second one later.
Old 08-28-06, 08:24 AM   #9 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
This sounds like a job for... Acoupower!
http://www.acoupower.com/
Old 09-02-06, 10:07 AM   #10 (Link)
Alias: Mark
Loc: Swansboro, NC
User: #2187
Since: Aug 2006
Mark64 is offline
Thanks to all who have posted. I have missed a few days of following my thread due to my wife's mom being hospitalized.
I had the opportunity to demo a James EMB-1200 in my home yesterday. I had contacted the closest James dealer (2.5 hours away) about a month ago with some questions, and once he found out where I live, informed me that he comes down to the beach not far from here some weekends and would be glad to come by the house and demo the sub for me. We hooked up the EMB-1200 to my H/K AVR325's sub out and set the channel adjust on the 325 to first +5 then later +7. Before he arrived I ran the receiver through the EZ set calibration which balances all speakers except the sub. We adjusted the gain during the session, ending up on about 3/4, and the phase sounded right on zero. He had no spl meter with him so it was just a very basic set up. I wanted to listen to music first so the night before I had burned a custom CD containing songs with either acoustic bass or clean electric bass. Artists consisted of Sade, Natalie Merchant, Norah Jones, Jack Johnson, Creed and 12 Stones. Movies chosen were Saving Private Ryan, Blackhawk Down, Master and Commander, And LOTR #1. We experimented with a few different positions on the sub and while it sounded good, I could tell we had not yet found the optimium location. He then called James Loudspeakers with questions about the placement in my room, and next thing you know, he is talking with Jeffrey James Coombs (founder of James Loudspeakers). Coombs asked him many questions about the room and system, and suggested placement options, one of which we had tried. When we tried the other, the bass was much fuller and seemed to encompass the whole room better. I was very impressed that an installer/dealer could call a company and get that kind of tech support/help from the man at the top. He told me that was typical of James since he had started carrying them. Once the sub was placed at the good spot, we listened to the songs and movie passages again. Music bass was deep, full, and not boomy, it would hit then be ready for the next note. The movie passages sounded awesome especially SPR and M&C, during the latter's cannon battle it sounded as if the cannons were in my living room. This is not the end of this process, only the beginning, as this was the first sub I have heard in my room. I believe if I were to choose a James sub I would opt for the larger EMB-1500 for my room to get more output and slightly deeper extension. That being said, the EMB-1200 is a fine unit with incredible build quality. Music sounded like I was hoping and movies were also very convincing. It did not pound the chest, I think I'd need more power or 2 subs to approach that kind of performance (or maybe one +2).
Old 09-02-06, 10:22 AM   #11 (Link)
RSH
Ultimate Rep
Alias: Roman
Loc: NJ
User: #1787
RSH is offline
Mark64,
Yes, The James Loudspeaker support is second to none. I always talk to Jay, and he is a really nice guy. I love their speakers. IMHO they make one of the best subwoofers for the money, and their in-walls are top notch - one of the best in the industry.
Regarding your room and subwoofer choice: if you mostly watch the movies, than the EMB 1500 will give you a lower and deeper output, but if you often listen to the music, a pair of the EMB 1200s would be a better solution due to a smaller and hence FASTER driver. Having two subwoofers also make it easier to get a flatter bass response, because you have a better option finding an optimal subwoofer placement.
Roman
www.rtheaters.com
sales@rtheaters.com
732.617.2348
Old 09-02-06, 10:27 AM   #12 (Link)
Alias: Mark
Loc: Swansboro, NC
User: #2187
Since: Aug 2006
Mark64 is offline
Wayne-
Thanks for your post and observations on my situation. I wanted to clear up an apparent misunderstanding when you read my initial post. I am not primarily interested in TV watching, in fact if that was the case I would probably not get a subwoofer. This passage from my initial post sums it up:
"We probably use the system about 75% TV and movie watching and 25% music. But with that being said I really want to start with music and get it right and I sort of feel that the HT will fall into place. I am hoping for tight, accurate, tuneful bass which is not boomy or sloppy. I don't mind being knocked off the couch by special effects, I just hope it doesn't have to be at the expense of the musical reproduction."
I was just being honest about how the system is used with the percentage reference, so I'm not looking to improve my wife's watching of Grey's Anatomy or Desperate Housewives . I want to nail the music and hopefully get HT as close to right as possible without taking away from the music. My thoughts now are whether to go with a sealed sub for accuracy, or a ported sub (such as the +2, which apparently is not bad on music) . Thanks for taking the time to post, if you have any additional thoughts, please send them my way.
Mark
Old 09-02-06, 11:05 AM   #13 (Link)
Alias: Mark
Loc: Swansboro, NC
User: #2187
Since: Aug 2006
Mark64 is offline
Roman- Thanks for your posts and help. I sent you a PM with some questions.
Mark
Old 09-02-06, 11:22 AM   #14 (Link)
RSH
Ultimate Rep
Alias: Roman
Loc: NJ
User: #1787
RSH is offline
Mark,
You are welcome - check your mail box for my response
Roman
www.rtheaters.com
sales@rtheaters.com
732.617.2348
Old 09-02-06, 12:33 PM   #15 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Mark64 wrote: View Post
Wayne-
Yeah, that blew right by me, didn’t it? Sorry about that. Too bad, though – it’s only going to cost you more money!
No problem there. Any good music sub sounds good with home theater – just add another one!
I’ve typically been a sealed kind of guy, but I’ve found recently that a good ported design can do a great job with music. For instance, once I tamed its extreme ultra-low frequency output, I found the SVS PB10-ISD had amazing detail. Right now I’m evaluating a 12” pair of SVS subs, one ported, one sealed, and I honestly can’t tell a difference with the detail. Neither seem to be quite as good in that respect as the PB10 was, but I’ve moved since then, and our new place is more “live” since it has wood floors. So I’d be hesitant to write it off to the smaller driver being “faster.”
Do yourself a favor and pick up a copy of Basia’s The Sweetest Illusion CD. I think it’s out of production, but you should have no problem finding it on ebay. On the first track “Drunk On Love,” the bass has a ”growl” or texture to it (that’s the best way I can describe it). It’s a great track to show if a sub is fast and detailed (I usually turn off the mains to hear the sub by itself).
Even more of a challenge is another of her CDs, London, Warsaw, New York. The opening track “Crusin’ for Bruisin,” also has a “texture” in the bass, but it’s very subtle. If the sub you’re demoing can pick up on that, you have a winner! Again, play it with the main speakers off, to make sure the “texture” you’re hearing is not from them.
I’ve found that it’s important to make sure the sub’s response is flat below about 30 Hz to get the most out of a musical sub. If there are peaks below that point, the detail will be obscured. The flattened response will work fine for movies, too – those action flicks have such extreme levels of bass, they’ll generate the peaking below 30 Hz despite the flattened response.
Old 09-03-06, 10:06 AM   #16 (Link)
SVSound
Alias: Ron
User: #1254
Since: Jun 2006
Ron Stimpson is offline
Mark64,
What Wayne, said. Though we rarely even use the word "fast", since in our view it's a bit of a misnomer. "Accurate" is what we tend to emphasize, since it's easily measured (there are many ways) and tends to take the more inclusive approach to quantifying subjective thoughts.
If all you have to rely on is subjective thoughts (as many brands do, fearing objective testing like a vampire shunning sunlight) then subwoofers and speakers become little different than wine, where you have only the opinions of others to fall back on.
Opinion is fine, opinion backed by hard evaluation and instrumented testing is much, much better. Personal bias is largely removed by a battery of revealing (if not exhaustive) test parameters. There certainly is at least some objective data on a couple of those subs in your list, though only stuff done by the same guy can be lined up against another review from him (unless you really know how the numbers were derived). This is the reason we seek out tough evaluators who will put the screws to our products and aren't afraid to point out what's right and what's less than perfect. No product is perfect.
Having said all that, please drop us a line if you have any questions about something like our Plus/2 subs and want our viewpoint. It's arguably the best value we offer in the over $1,000 price class. There are at least a couple of very good subs up there (based on our own study of the products or reliable test data from others about them).
Look at Wayne's own testing on the early PB10-ISD (replaced by the PB10-NSD) for how we stack up against some big names. Any review by Ed Mullen is going to be gold too. He doesn't do everything as we would, but there's no more thorough or accurate subwoofer reviewer in print or cyber today.
He's tested a couple SVS prouducts, and recently did this one of a Canton. Jump back to the Secrets page and read everything he's done there and you start to get an idea of who's doing what in subwoofer land, and who just talks a good line.
http://www.hometheaterhifi.com/volum...06-part-1.html
It's always good to take in anyones personal "props" for a product, we certainly benefit from this ourselves, but if an OEM goes after this sort of tough objective exposure from a review that's easily duplicated and validated (as any science is)... or by the same token does NOT go after this sort of exposure... we think that says a good bit about an OEM's confidence in the product. Bloated, purely subjective puff pieces about subwoofers are a dime a dozen, and while not worthless, far more limited in their value.
Again, stuff like Mullen's (put into context with careful reading of a given reviewers' other work) is simply gold by comparison. He's only done a portion of the reviews on this page:
http://www.hometheaterhifi.com/maste...ubwoofers.html
Still, all the ones he has done are directly comparable to each other. If he's on the masthead, read it. Nothing gets by him.
Good luck on your research, it's pretty clear what product we'd recommend if you end up giving SVS a try.
Ron Stimpson
SVS
rons@svsound.com
RonS
SVSound
Old 09-04-06, 08:07 PM   #17 (Link)
Alias: martin
Loc: Louisiana
kramskoi's Avatar
User: #1511
kramskoi is offline
you see... it's starting already, the escalating bass fetish...lol
On a serious note, in a room your size, you'll most likely need "at least" 2 subs working in tandem, and forget 10" drivers...i can give you one good piece of advice and i'm sure Tom or Ron at SVS will echo my sentiments, "headroom is your friend" so get "more" than you think you need. I can't stress this enough... you want dynamics to stay sharp, distortion to stay low and drivers working well within their limits of operation...this will affect the soundstage and overall presentation...the Paradigm Servo15 and the ACI Maestro are fantastic units for sealed and the Ultra/2 is the cutting edge vented sub in SVS's stable...stupendously capable...VERY robust driver architecture on all these...don't get caught up in the woofer size/speed myth ...high-end drivers have the motor strength to meet the demands of their respective applications... In the end, demo as many of your selections as possible and A-B if the situation allows, your ears will make the final choice, there is no wrong or right answer, no magic bullet...it's all listening preference...good luck with your selection
MBoutte
south Louisiana
2x15" TC Sounds .45Q sealed
M. Boutte HT
3x15" @ 10 Hz
"...peace? love?...illusions Mr. Anderson...vagaries of perception..."
Old 09-05-06, 05:28 PM   #18 (Link)
Alias: Mark
Loc: Swansboro, NC
User: #2187
Since: Aug 2006
Mark64 is offline
Ron-
I appreciate your insight and knowledge on the issue of subwoofer selection. I believe this part has been more difficult than picking my receiver and speakers. I have noticed some of what you mentioned about reviews (the good and the not so good). I live in an area which does not have many good hi-fi or stereo shops from which to listen and judge, therefore, I read and devour everything I can about subwoofers, be it product reviews, set up and calibration, etc. I definitely see your point about how a review without quantitative measurement or analysis is not as valuable as one which does, and can tend to be very subjective and sometimes opinionated. I try to take all reviews with a grain of salt, but at the same time, I feel someone knowledgeable enough to be published probably has more experience than me. This is not to say my ears don't work as well as the reviewer's, and often for me a review is just a starting point. I have read many of the reviews by Ed Mullen and have been impressed with his thoroughness and attention to detail. I do have several questions for you which I will send in an e-mail.
Thank you for your help.
Mark
Old 09-05-06, 09:39 PM   #19 (Link)
Alias: Bob
Loc: Pittsburgh, PA
User: #962
Since: Jun 2006
Mark after reading some recent posts it seems you want extremely clean and accurate bass. I will say the Triad InRoom Platinum, Paradigm Servo-15a, and SVS PB12-Ultra/2 will give it to you.
~Bob
Old 09-06-06, 07:00 PM   #20 (
