| Home Audio Subwoofers Running more than one sub on an Onkyo 805Discuss Running more than one sub on an Onkyo 805 in the Manufactured Speakers and Subwoofers forum; Running more than one sub on an Onkyo 805 How does one go about hooking up more than one sub to a receiver that only has one output? Can ... |
| | #1 (Link) | |||
| Running more than one sub on an Onkyo 805 How does one go about hooking up more than one sub to a receiver that only has one output? Can a person just Y the signal? Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #2 (Link) | |||
| Re: Running more than one sub on an Onkyo 805 Using a Y adapter is perfectly okay. The only possible "problem" that could occur is that less voltage from the receiver is being sent to each sub so you might have to turn the gain on the subs up slightly. You will see if this is needed when calibrating your system. | |||
| | #3 (Link) | |||
| Re: Running more than one sub on an Onkyo 805 Thanks that was what I thought. I just didn't want to damage anything on the receiver by drawing more power. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #4 (Link) | ||||
| Re: Running more than one sub on an Onkyo 805 Quote:
. It will just split the power between the two.Great receiver BTW. I am thinking about getting one to use as a pre-amp. | ||||
| | #6 (Link) | |||
| Re: Running more than one sub on an Onkyo 805 As far as I understand there is a certain amount of power "loss" or rather split. Since the receiver cannot tell that there is a Y adapter plugged into it so if it only sends out X amount of power to a single sub it will send the same amount to a pair of subs connected through a Y adapter. This means that the power is split when sent over a Y adapter so it can reach both subs. I never said this was really a problem (hence the quotes) as there are a few easy fixes such as turning up the gain on the sub or simply going to the receiver's option for speaker loudness level and turning up the subs. Either way a larger signal will be sent to the split path allowing for no actual loss. The real key is make sure you level match your speakers after using a Y adapter and adding a new sub and you will be fine either way and in reality you should do that any if you are adding a sub anyways. | |||
| | #7 (Link) | |||
| Re: Running more than one sub on an Onkyo 805 I'm using "Y's" to split the signal to my two subs and buttkickers ... and I don't have any problems ![]() ... My receiver is an old Sony STR-DE897 and I'm sure your 805 has better specifications than mine .... | |||
| | #8 (Link) | |||
| Re: Running more than one sub on an Onkyo 805 Yup, splitting the signal is perfectly valid. You may have to change the gain (you just have to recalibrate anyway). What I would do. Use a sound meter. Use a fix output gain on your LFE setting. Calibrate each sub's onboard level control to achieve the same SPL using the test tones. They add the Y splitter, and hook up both subs, and recalibrate again but this time adjust the receiver's gain setting for the sub (don't touch the sub knob) | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Onkyo 805 hmdi to Mitsubishi WD65734 Problem | docsavage | System Setup and Connection | 3 | 11-23-07 12:18 AM |
| Onkyo 805 or equivalent Denon? | tonyvdb | Home Theater Components | 4 | 11-08-07 11:35 PM |
| running speaker wires | bonj87 | Home Theater Design and Construction | 3 | 10-23-07 10:04 AM |
| Anyone use REW to measure Onkyo 805? | lovingdvd | Home Theater Components | 12 | 10-18-07 01:17 AM |
| Up and running.... | garymck | DIY Subwoofers | 4 | 07-26-06 10:44 AM |
