Does anyone use these Behringer products to enhance their subs - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Does anyone use these Behringer products to enhance their subs in the Manufactured Speakers and Subwoofers forum; Does anyone use these Behringer products to enhance their subs Hi i wonder if anyone uses the Behringer ultimizer pro or the ultrabass pro or any kind of line driver ...
Old 01-10-08, 09:58 AM   #1 (Link)
Alias: Robin Hood
Loc: Sherwood Forest
User: #11451
Since: Sep 2007
stephenb1 is offline
Hi i wonder if anyone uses the Behringer ultimizer pro or the ultrabass pro or any kind of line driver to increase the subs (volt) pre-output to enhance the S/N ratio as they sometimes do in car audio.
The reason i ask is because the cx-3400 crossover i use seems to decrease the pre-output a little rather than increase it, unless turned up alot which just does n't sound very good.
So would like to increase it properly a little again, and improve the drive to the subs.
Any help appreciated
Old 01-10-08, 10:50 AM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
Re: Does anyone use these Behringer products to enhance their subs
I use an ART Cleanbox to bring the consumer line level subwoofer output of my AVR up to pro audio levels to drive my Mackie pro amp -- which drives my DIY sub.
Old 01-10-08, 10:53 AM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
But the CX3400 has both input and output gain controls for each band..... you should revisit your levels into and out of the device. I don't see an advantage to adding another device (that will also add its own noise floor) to the mix.
Old 01-10-08, 01:24 PM   #4 (Link)
Alias: Robin Hood
User: #11451
Since: Sep 2007
Hi thanks for your replys.
I think it could be mostly down to phase issues and too much gain muddying the sound, i think less gain maybe more ? although also it could be the slight limited bandwidth of the cx-3400 as well.
I used a Pheonix gold pro line driver in a few past systems, home and in the car and it always helped as they are very clean sounding, may give another a try and a clean box and maybe a Behringer dcx2496.
Any other ideas welcomed.
Old 01-10-08, 04:47 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
The only real reason to boost the signal is if you have the sub amp’s gain all the way up, but you still don’t have enough signal to drive the amp to its maximum output. Is this what you’re experiencing? If so, how do you know you aren’t able to drive the amp to max?
Old 01-10-08, 05:55 PM   #6 (Link)
Alias: Robin Hood
User: #11451
Since: Sep 2007
Hi,
I don't turn the sub level up much at all, only around half on the left and a around a quarter on the right sub , there is a problem with the left as its getting quieter ( i think a component is failing ) although i have bought another on e-bay which should arrive next week.
The subs are the not so well loved ps1000 's , but i have always liked them.
This is only really about getting the timing pretty spot on for music,
movies seem to play very well, probably too much bass for the neighbours ?
I did some experimenting earlier as my amp has 3 sub outs, one left, one right and one mono. The mono reads twice as much on a test meter and higher though the bfd than left or right.
So using the mono for left ( for now ) and right normal, i listened to it again and the bass sounds much more whole, rounder and louder, even through the dodgy left sub.
So thinking if i increase the output to both subs with a pro line driver as i have on some 4 x 12" PA speakers and in the car, as it worked very well in the past it hopefully will give the same effect, as mentioned.
Which is why i was wondering if any of the behringer products may increase the volt output to the subs ?
Old 01-10-08, 06:14 PM   #7 (Link)
Alias: brucek
User: #6
brucek is offline
As I referenced in my post above.... the CX3400 offers +12dB gain on the input and +6dB gain on the output. Why do you require more than that? It's voltage gain.....
Old 01-10-08, 06:34 PM   #8 (Link)
Alias: Robin Hood
User: #11451
Since: Sep 2007
Hi,
The cx-3400 does n't seem like a very clean 12db it seems to make the sound muddy and stodgy when turned up even a little , if that makes sense so was wanting a nice clean boost.
I did manage to make things slightly better earlier by leaving the input slightly up and output normal or a little less than 0db, but the phase seems to keep changing ? when trying different discs its very strange.
I have a dcx2496 on order and have spotted a phoenix gold pld for sale cheap so will give them both ago, just wondered if anyone had tried anything similar.
I will post the results just in case anyone else is interested ?
Thanks for the replies
Its the best forum on the net ( much better than some i won't mention !! )
Regards Steve
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
Structured Cable Products lcaillo Manufacturer and Vendor Reference Information 0 05-04-07 08:26 PM
First real measurement subs, subs+main, subs+main large frockc REW Forum 13 03-17-07 11:42 AM
Pictures of SVS products Manic Miner SVSound 1 02-11-07 08:45 AM
New EQ products coming January 18? RonLF REW Forum 0 01-05-07 02:40 AM
New Products, your input needed! Brian Bunge DIY Speakers 14 10-31-06 02:59 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
