| Home Audio Subwoofers No place for a boxDiscuss No place for a box in the Manufactured Speakers and Subwoofers forum; No place for a box Hi all,
I am trying to put a 7.1 system in the family room. Not the ideal HT setting, with ... |
| | #1 (Link) | |||
| No place for a box Hi all, I am trying to put a 7.1 system in the family room. Not the ideal HT setting, with a ~4,000+ cubic ft. room. My problem is that the TV is in a cabinet with the center speaker below, also in the cabinet. The R and L mains will either be in cabinet or possible towers to the sides (WAF). I have NO place to put a subwoofer box. Here are my thoughts:
As far as budget goes, I don't want to miss out on hearing a good idea, so let's just say it is not an issue. That said, I am hoping to keep the overall speaker costs in the $1000 - $2000 range. If necessary it can be higher. Thanks for your help. | |||
| | #2 (Link) | |||
| | Re: No place for a box Sounds like you are really strapped here. Definitive Technology has powered subs in some of their speakers that I've heard good things about, but I don't think there are any that are going to do what a good sub will do. I would not attempt IB until measuring the response at that location, which would require a sub in the listening position, plus REW or some method of measuring. IB might be your only option, but if the response there is problematic... no room gain... tapered low end response, you'll be no better off than with powered subs in your mains. This may sound a little unusual, but what about smaller sub boxes with good bookshelf/monitors placed on top of the subs? Also, have you looked at any of the cylinder subs yet? The WAF is sometimes better with those and then sometimes worse... ![]() Can you take a snapshot of your front stage where your speakers are going and post it? | |||
| | #3 (Link) | |||
| Re: No place for a box Good comments from Sonnie! I like the idea of placing bookshelf speakers on top of small subs. Can you do IB in the floor rather than the wall or ceiling? That's where mine is, and it hangs into the crawl space. -- Otto | |||
| | #4 (Link) | |||
| Re: No place for a box Is DIY an option? I'm thinking first about building subs as "speaker stands" for the recommended bookshelf speakers above. Since aesthetics appear to be a primary requirement in this project, the end result would probably look better than plopping your speakers on the typical cubic shaped subwoofer. Depending on the room and furnishings, DIY might open up other options as well that can't be met by commercial solutions. -Brent | |||
| | #5 (Link) | |||
| Re: No place for a box Here is an example of a pair of Custom speakers I built some time ago. They have built in subwoofers. They use a sub driver nearly identical to the SVS12.2 These with built in 500wrms amps for the subs would be $2500, If you are interested in going that way, you can contact me with some size constrants and finish choices, and I can tell you what we can do for your price range. Or if you are interested in a pair of subs to put your mains on top of, check out the FW10.1, on sale right now for boxing day. Sorry the picture isn't very good. | |||
| Thread Tools | |
Similar Threads | ||||
| Ib in an old Fire Place | jdc61 | DIY Subwoofers - Infinite Baffle | 7 | 01-09-08 06:57 PM |
| Moderno in-wall 10" - To Box or Not To Box | billmd | Home Audio Speakers | 1 | 12-02-07 09:10 PM |
| Found a good resting place | alan monro | Chat Box | 1 | 07-21-07 09:07 PM |
| what's best place for sub? | PhilB35 | REW Forum | 8 | 02-17-07 12:36 PM |
| Not sure how I missed this place | Owen Bartley | Welcome | Member Introduction | 8 | 10-19-06 09:26 PM |
