Small room sub help.... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Small room sub help.... in the Manufactured Speakers and Subwoofers forum; Small room sub help.... I've updated my audio end all but sub. IMO, it's the weakest link in my chain. I have a Sony ...
Old 01-03-08, 08:20 PM   #1 (Link)
Alias: pHill
Loc: Birmingham, AL
rumonkey2's Avatar
User: #1719
rumonkey2 is offline
I have a Sony SA-WM40 that's 7-8 years old. Got it for $79, so I've got my money's worth. It doesn't do a terrible job - decent rumble actually. It's just that I tend to push it more now that it's in a "dedicated" room. (Moved sysytem from family room to small bedroom to be off adjoining neighbor wall in TH complex.) SPL gets outta hand in here quick, but even when moderate levels, I notice the chuffing more & bottoming out. Now, I just recently did the poly fill mod (can't believe I didn't try this before)
and it mad a noticeable improvement. Actually pretty satisfactory in here. Plus, I''m in the process of doing some traps. But, well, I just know I can do better. And wanna move the sub to the bedroom the old system is in. Looking to spend $300 TOPS so, considering X-ls XPlossive (when it comes online) or Acoustech H100.
Any suggestions????
HK AVR240, 3 XLS across the front, JBL Balcony rears....
"All my friends are junkies....are you monkey too?" Mick & the boys
Old 01-04-08, 01:56 PM   #2 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Re: Small room sub help....
Until the Xplosive comes out, you're dealing with an unknown, so it's really a toss up. If you want to buy soon, the BIC is certainly not a bad choice. However, if you can wait, you'll know for sure which one would be the better choice.
Old 01-04-08, 07:33 PM   #3 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
My room is 9 x 18 x 8 and I have two subs ... Velodyne VRP1000 (VRP 1200 is $270 here at the shack electronic store); you can see the specifications here http://velodyne.com/products/specs/vrp.html paired with Infinity TSS750 ($330 at the shack store) .... and I'm happy with them.
I can use either and get good bass, but because I'm becoming a bass addict .. I use one in the front and the other inside the riser ... and to top thing off I added a buttkicker to each row of seats
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
Small room need help! subloverman Home Theater Design and Construction 6 08-12-07 09:25 AM
Large or Small ? sonata31 Home Audio Speakers 18 02-15-07 09:58 PM
Is my room too small? jpok1000 Home Audio Speakers 13 02-03-07 03:41 PM
Small HT room design.... rumonkey2 Home Theater Design and Construction 11 01-24-07 01:47 PM
Building a Small Control & Live Room Bryan Nemecek Home Theater Design and Construction 16 11-11-06 08:22 PM
Mach 5 Audio
