LFE question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
LFE question
Discuss LFE question in the Manufactured Speakers and Subwoofers forum; LFE question If I connect multiple subs to my lfe out of my Pioneer Elite will it cause impedance problems. I have ...
Old 01-16-08, 05:36 AM   #1 (Link)
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is online now
LFE question
If I connect multiple subs to my lfe out of my Pioneer Elite will it cause impedance problems. I have two connected now but I was thinking of splitting it one more time for my buttkickers. If this is a problem is there a fix. Thanks......
Old 01-16-08, 07:46 AM   #2 (Link)
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
Re: LFE question
No, it shouldn't be a problem. Your receiver LFE output is not driving your sub speakers directly, it's connected to the sub amps (LFE output is not a speaker output, it's more like a preamp output).
Use splitter cables or daisy chain your subwoofers, whatever is easier in your setup. Remember to switch OFF the filter on the first sub if you're going to daisy chain them, otherwise you could have some problems adjusting the phases during calibration. Read your user guides for more info on this
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Sony PS3 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
Old 01-16-08, 09:30 AM   #3 (Link)
Alias: TC
User: #9814
Since: Jun 2007
Re: LFE question
Thanks, I have been getting mixed answers on this question from different people ranging from the impedance problem to a problem with mid bass frequency's. I was told also that I would need to run an audio signal amp to avoid any problems. I wont be daisy chaining the subs as I run a splitter out of the reciever and then dedicated cables to each sub. What I was thinking of doing is after the split at the reciever split one of those cables again and run the extra line to my buttkicker amp. Thanks for your response I really appreciate it.
Old 01-16-08, 09:45 AM   #4 (Link)
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
Re: LFE question
You're welcome !
I know some people who have split their LFE signal 4 or 5 times. The only problem is that the signal level is divided by two every time you split it. This means that the signal/noise ratio gets worse but I don't think that it is a real problem in practice.
Remember to recalibrate your system (receiver and subwoofers) after adding your second split. Then you're ready for some shaking experiences
Old 01-16-08, 12:00 PM   #5 (Link)
Alias: TC
User: #9814
Since: Jun 2007
Re: LFE question
Great, I put up some acoustic panels and so when I am done putting it all back together I will re-cal. Thanks again,............
Old 01-16-08, 02:10 PM   #6 (Link)
Alias: brucek
User: #6
  brucek is online now
Re: LFE question
Not so, since the split signals are in parallel, they remain the same voltage, and since the current is extremely low as a result of the rather large impedance mismatch between the preamp output (typically 100 ohms) and the subs' power amp input (typically 20K to 50K), you may split the signal multiple times without a noticeable change in volume.
This is known as a voltage bridge connection where the preamp is acting as a voltage source and very little current is drawn. A perfect voltage source would have an output impedance of zero ohms at all frequencies. This would result in all the output voltage from the preamp being dropped across its load(s) with no voltage being lost to the output impedance of the pre amplifier. Two loads will divide the load impedance by two, but there is still a large mismatch, such that the voltage divider can still be ignored. You can split many times before it becomes significant. Anyway, there's an old rule of thumb that says, the input vs output impedance of a voltage bridge interface should be a minimum of 10:1
Old 01-16-08, 03:03 PM   #7 (Link)
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: LFE question
tcarcio wrote: View Post
Don't worry!!! ... you won't have any problem with this set up
I have two subs (Infinity and Velodyne) and also a buttkicker amp running two LFE's ... and guess what: NO PROBLEMS!!! ... I used a "Y" to split the signal at the receiver, and another "Y" to split the signal again for one sub and the LFE amp ...
On a side note: you may have a ground loop after connecting the buttkicker amp, in that case just get a ground isolator (http://www.radioshack.com/search/ind...round+isolator ) to solve the problem (that's what I did)
Old 01-16-08, 04:02 PM   #8 (Link)
Alias: TC
User: #9814
Since: Jun 2007
Re: LFE question
I did get the ground loop problem but I did exactly what you suggested. I think what I have decided to do is leave the splitter coming out of my reciever as is and run another cable from the lfe out on my A5-350 to the buttkicker amp and I should be good to go.
Old 01-16-08, 04:32 PM   #9 (Link)
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: LFE question
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
