Can a sub goes to low? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Can a sub goes to low? in the Manufactured Speakers and Subwoofers forum; Can a sub goes to low? I know there's different schools regarding subwoofer. Some say "go as low as you can". Other argues that if it ...
Old 01-15-08, 11:38 AM   #1 (Link)
Alias: daniel
Loc: Varennes, Québec
User: #5208
Since: Dec 2006
daniel is offline
Other argues that if it reproduce a to low frequency, it will overload the room and muddy the sound.
But that last few hz are very tempting!
What is your personal experience.
Old 01-15-08, 11:44 AM   #2 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Re: Can a sub goes to low?
LOW, LOUD, CLEAN, the only way to go. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 01-15-08, 11:47 AM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
Your going to find it tough to find a sub that will go below 15Hz at any decent db's but theoretically the lower the better there are lots of things in the real world that can produce frequencies even lower, Thunder for example or a sonic boom from a jet can defiantly hit frequencies in the single digits.
The so called muddy frequencies are usually in the higher octaves between 200 and 40Hz. this can be corrected by proper acoustics and bass trapping.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 01-15-08, 02:52 PM   #4 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
Tough to buy a single hi output @ 15 Hz sub. Not so hard to build -- ala Steve Callas LLT.
Multiple sealed 18" subs with eq will also do it. Or those nice multiple 18" driver Infinite Baffle DIY installations.
If you have the space.
Old 01-15-08, 03:56 PM   #5 (Link)
Gold Supporter
Alias: Jean-Pierre
Loc: Beaumont, Quebec, CANADA
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
The question : Is that frequency range (5 to 15 hz) present in the source you are listening to ?
Some movies use verry low frequency but I think that is not the case with many CD.
Am I right, please correct me.
Old 01-15-08, 04:31 PM   #6 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Not in most CD's but I know of a few one in particular by Telarc that was recorded at least 15 years ago that has a warning on the front saying to turn down your system and test first as there were digital cannons that had frequencies in the subsonic range that would cause damage to speakers if played to loud.
Telarc is well known for there dynamic digital recordings that will tax any system.
ALot of newer recordings done in a studio will have tracks that have a wide dynamic range including stuff in the 15hz and above range. GRP records also does some really good recordings on CD.
Nintendo Wii
Old 01-15-08, 08:31 PM   #7 (Link)
Tech'y Shackster
Alias: Bob
User: #25
imbeaujp wrote: View Post
Some movies use very low frequency but I think that is not the case with many CD.
I have a DVD-A of Saint-Saëns, the Symphony No. 3 "Organ", that pushes some über low floor vibrating notes. For the deep notes, wait for after the overall 27 minute mark, during Part II (~8 minutes into it).
Of course pipe organ music can be an entirely different scenario for music lovers and the need for subwoofers that can reach down really deep.
Old 01-16-08, 10:21 PM   #8 (Link)
Alias: PHIL
Loc: SHERMAN, TX
ISLAND1000's Avatar
User: #8655
Since: May 2007
ISLAND1000 is offline
"Can a sub goes to low" ? No, let the sub play as low as it can without the cone falling off.
Old 01-18-08, 02:43 PM   #9 (Link)
Alias: Mazer
Loc: Melbourne, Florida
mazersteven's Avatar
User: #8008
Since: Apr 2007
mazersteven is offline
daniel wrote: View Post
I want a sub that it Tight, Accurate, and goes Sub-Sonic without distortion or sounding boomy. I also want it to have enough headroom for it's environment.
Old 01-20-08, 11:50 PM   #10 (Link)
Alias: SQBubble
Loc: MTL, QC, CA
User: #13347
Since: Nov 2007
SQBubble is offline
the lower you go, the more air you have to move, multiple driver or a/some high excursion subs are needed to have the best result.
Also, just want to add, theres a big percussion construction machinery that produce some very, very incredible low-frequency sound at loud volume. Was literally shaking the road and had to speak louder than usual to have a conversation. I was really surprised!
Old 01-21-08, 06:17 AM   #11 (Link)
Gold Supporter
Alias: Jean-Pierre
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
Everybody knows that 2 way or 3 way speakers are a good concept because each drivers performs on a specific range. In the sub woofer domain, is this concept apply ? Would it be more efficient to have a specific sub to address the 5 to 30 hz range and another for the 30-100 ?
JP
Old 01-21-08, 08:23 AM   #12 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Just likely would quite expensive and it is rarely done. The 30 Hz crossover should be done, IMHO, at line level with power amplifiers afterwards. You would have to do that crossover yourself since AVR/Pre-Pro's do not -- although some can be adjusted to do the sub crossover as low as 40 Hz.
Better (more practical) to use (set to LARGE) big 3-way L/R full range mains that have 12" woofers that are rated to -3 dB @ 30 Hz (full power) and use the extra low range sub crossed at 40 Hz.
The problem with that is that the LFE channel is supposed to supply sound from the lowest freqs (5 Hz?) to a normal high end freq of 120 Hz.
Old 01-21-08, 02:37 PM   #13 (Link)
Alias: Konky
Loc: Canton, GA USA
conchyjoe7's Avatar
User: #11137
Since: Aug 2007
conchyjoe7 is offline
I have heard that "Telarc" disc and the warning is valid. It has been a very long time, but if I remember correctly, it has the "1812 Overture" on it and the cannon blasts are what the warning is about.
Cheers,
Konky.
I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
How low can we go? PeteD REW Forum 9 01-11-08 02:01 PM
How low can the step up be jgraceoma Home Theater Design and Construction 6 08-05-07 01:01 AM
BFD as a low-pass? niget2002 BFD Forum 2 08-02-07 10:56 AM
low input bobmills REW Forum 41 07-07-07 04:36 PM
Very low budget sub. mgboy DIY Subwoofers - Sealed and Ported 53 02-05-07 09:48 PM
Mach 5 Audio
