Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Low bass - small room
Discuss Low bass - small room in the Manufactured Speakers and Subwoofers forum; Low bass - small room This may seem like a stupid question but here goes… I am wondering about frequency and room size and if ...
Views: 1340 - Replies: 6
Old 01-15-08, 02:37 PM   #1
Alias: Wayde
Wayde's Avatar
Loc: Waterloo ON, Canada
User: #943
Since: Jun 2006
  Wayde is offline
I am wondering about frequency and room size and if there is any correlation when it comes to low bass.
Let’s say you’ve got a small room, is there a chance that small room’s ability to facilitate very low frequencies will be compromised?
For instance, low frequencies have very long wavelengths. Is there any truth to the idea that a wavelength might be too long to fully cycle inside a small room? If that’s the case, what happens?
In a small room you have a 20Hz signal being played back at an audible SPL. Do you just not hear it? Do you hear it as a higher frequency because the room is incapable of 20Hz? Does it distort somehow? Or… do you hear all the low bass just fine and I’m just barking up the wrong tree asking a silly question.
Thanks for any help.
Wayde
Wayde
Old 01-15-08, 03:15 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Re: Low bass - small room
Even in a small room with wavelengths as long as they are the walls will reflect and vibrate causing you to still hear or feel the sound. Vibration of objects is all part of how sound is heard particularly the low frequencies. Some explination is shown here
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 01-15-08, 03:19 PM   #3
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is online now
Even tho a low frequency wave has a long wavelength, 1/4, 1/2 and similar divisions of the wavelength will allow the wave to propogate. I have a SVS PB12-Plus/2 (2 12" subwoofers) in a 11 X 15 room. I don't have any loss of bass because of the smaller room size. The problem is too big a room size, then more is needed to move large amounts of air. Hope this helps, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 01-15-08, 03:22 PM   #4
Shack Moderator
Alias: Dr Doan
User: #2314
Since: Aug 2006
The biggest problem, I find, is the resonant frequency of the room itself. At that freq, the room will greatly amplify the bass. It is sometimes hard to tame that freq and at the same time balance the other, usually lower, frequencies to the proper lever. Dennis
L Dennis Doan, DC
IT'S THE NERVE!
www.drdoan.com
Direct TV DVR HD
Old 01-15-08, 03:34 PM   #5
Alias: Wayde
Wayde's Avatar
User: #943
Since: Jun 2006
  Wayde is offline
Thanks for the responses guys. I am reading this article on the diffraction of sound.
What I'm getting is that the room won't actually limit the wavelength in any way. If you have a good sub capable of 20Hz at decent SPL it doesn't matter how small the room is, you'll still hear it unless other factors apply, such as the soundwaves resonance with other objects in the room, but not the room size itself.
Wayde
Old 01-16-08, 10:40 AM   #6
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is online now
Any rooms will give you peaks and nulls. Maybe you room/sub position/seating position is causing a null in the range of bass frequencies that you're looking for.
Old 01-16-08, 11:49 AM   #7
MikeDuke
Inactive
Alias:
User: #
Posts: n/a
My room is very small. Just about 1000cf. I have a Seaton Sound SubMersive1. We measured output down to 8hz in my room. I get all of the good low bass stuff from the movie favorites that are out there. Now, I will tell you that having such a small room is not optimal, but what can you do. I have no problem registering the low stuff from WOTW.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332
