| Home Audio Subwoofers Older sub-woofer connection to an a/v receiverDiscuss Older sub-woofer connection to an a/v receiver in the Manufactured Speakers and Subwoofers forum; Older sub-woofer connection to an a/v receiver All, years ago I ran the Kinergetics/BSC subwoofer, SW-100, as part of a 2-channel system. The subwoofer 'package' consists of ... |
| | #1 (Link) | |||
| Older sub-woofer connection to an a/v receiver All, years ago I ran the Kinergetics/BSC subwoofer, SW-100, as part of a 2-channel system. The subwoofer 'package' consists of the subwoofer and an external amplifier. Life went on, and I no longer used the subwoofer: put into storage. Cut to 2008, and I have the Cambridge Audio 540R (version 2) a/v receiver. So, I am wondering if I can use the Kinergetics package with the 540R? If I can use it, how do I connect it? I am uncertain of the signal path. Clearly I cannot use the modern method: sub-woofer line-out on the Cambridge into the subwoofer amp. The sub-woofer amp has its own "Right" Out and In, and "Left" Out and In connections. Unfortunately I do not have the specs on the SW-100 amp. Google search does not get me very far. As well, is sorting out all of this worth it? Or do I bite the bullet and buy a modern sub? I remember the BSC/Kinergetics sub as being of high quality, so I would like to use it if possible. But I don't want to introduce uncessary complications. All input, advice, suggestions gratefully received! Thanks. | |||
| | #2 (Link) | |||
| Re: Older sub-woofer connection to an a/v receiver Jason, welcome to the Shack. With the info you have provided, it sounds like you could hook up the sub-out (LFE out) from the Cambridge using a "y" connector to the right and left inputs of the sub amp. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) Denon AVR-2807 Receiver w/AudysseyXT LG DVD Recorder w/HDMI Direct TV DVR HD Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | |||
| | #3 (Link) | ||||
| Re: Older sub-woofer connection to an a/v receiver Quote:
Using a Y connector should allow the receiver to do all the work: cross-over point, etc. I'll try it. The only thing the amp has on it is a gain control: a dial which goes from 0 to 18dB. | ||||
| | #4 (Link) | ||||
| | #5 (Link) | |||
| Re: Older sub-woofer connection to an a/v receiver Thanks! Just a question on why the Y connector is needed? Will just a single RCA cable from the sub-out on the receiver into, say, Left-In on the sub amp do the same job? | |||
| | #6 (Link) | |||
| Re: Older sub-woofer connection to an a/v receiver Yes, just one connector input to the amp should work. Just that depending on how the amp is connected you may be able to use both channels of the amp's input to drive the subwoofer. You might get a voltage add to require less LFE drive from your receiver. Likely it will not really make any difference -- since you have an amp gain control anyway which controls the voltage to the final current output stage. | |||
| | #7 (Link) | |||
| Re: Older sub-woofer connection to an a/v receiver Thanks, obgpsr. My first day at the Shack and such informative to-the-point replies to my first post! I'm glad I joined, and hope to return the favour to someone else who has posted a question. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| new drivers for older sub | dieselpower1966 | DIY Subwoofers - Sealed and Ported | 8 | 02-17-08 07:58 AM |
| Samsung Bd-up5000 And Older Denon Reciever | ewarren | High Definition | HD DVD | Blu-ray | 1 | 12-28-07 05:30 PM |
| Replacement Driver for older ported Sub | dtb300 | DIY Subwoofers | 23 | 12-18-07 12:56 PM |
| Can blue ray or HD dvd players older old DVDs | Scuba Diver | High Definition | HD DVD | Blu-ray | 4 | 10-27-07 06:24 PM |
| Outboard processors for older receivers w/ 5.1 input? | gopheralex | Home Theater Components | 3 | 08-27-07 03:21 PM |
