| Home Audio Subwoofers Advice needed: Down or sidefire sub for odd room layout?Discuss Advice needed: Down or sidefire sub for odd room layout? in the Manufactured Speakers and Subwoofers forum; Advice needed: Down or sidefire sub for odd room layout? Hi all. I have a slightly odd room layout where my TV and electronics are mounted roughly at a 45 ... |
| | #1 (Link) | |||
| Advice needed: Down or sidefire sub for odd room layout? Hi all. I have a slightly odd room layout where my TV and electronics are mounted roughly at a 45 degree angle in the corner of the room. (see attached sketch) The nice thing about this layout is that it gives me an obvious corner location for a subwoofer as part of a 7.1 setup without upsetting the wife. However, I'm a little concerned about putting a sub behind my entertainment center, and am wondering if there's any real difference in this setup if I use a downfiring or sidefiring sub. I'm thinking of an SVS cylinder, maybe a used PC-Ultra if I can find one, or a Hsu VTF-3, as my two probable choices. The floor is a floating laminate (pergo-style). I'm not worried about interferance, just whether I'll tend to shake my audio/video equipment too much if I go side-firing as compared to down-firing. Or will it make any difference at all? Any thoughts are appreciated! Tony | |||
| | #2 (Link) | |||
| Re: Advice needed: Down or sidefire sub for odd room layout? A sidefiring won't shake you equipment much more, so I think it will be fine either way. I think a cylinder would be very nice, though. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #3 (Link) | |||
| Re: Advice needed: Down or sidefire sub for odd room layout? First of all .... Welcome ![]() ![]() ![]() I think you will be fine with either ![]() ... if you use a down firing it will shake your floor (and probably you will feel it more at your seat, specially with a floating floor); and if you use a side firing, is most likely to shake your walls ![]() ![]() If you want an extra experience, get a pair of buttkickers (http://www.guitammer.com/home_theater/index.htm) to feel effects of crashes, explosions, thunder, etc. ... you'll be ![]() ![]() ![]() | |||
| | #4 (Link) | |||
| Re: Advice needed: Down or sidefire sub for odd room layout? Take a look here http://www.hometheatershack.com/foru...something.html | |||
| | #5 (Link) | |||
| Re: Advice needed: Down or sidefire sub for odd room layout? Thanks for the welcome and responses. I know the lower frequencies are more or less nondirectional, but I have a hard time imagining that the orientation of the driver (at the kind of SPLs that these can put out) not having an effect on equipment located in the path. Especially my old turntable, but even with a CD/DVD or anything else mechanical. The link I checked out said that, yes, there might well be an increase in floor vibrations with a down-firing setup, which implies to me that side-firing 'into' the AV equipment may well vibrate it more than down-firing would. I guess that's assuming that having a vibrating floor wouldn't be harder on the equipment though, which may not be true. And of course there's the potential for 'spurious excitations' from vibrating the floor itself; might be fun for the feet but less desirable for the ears. I don't really understand sound propagation at these frequencies though. I found a used VTF-3 nearby that is reasonable in price, if I could find a nice used PC Ultra I could put them side by side and see for myself. And then I could post for a good divorce lawyer - we're still having a 'discussion' about the placement of the surrounds.. lol | |||
| | #6 (Link) | ||||
| Re: Advice needed: Down or sidefire sub for odd room layout? [ Quote:
If you list what you have will also helps ... there is a lot of people that can give you ideas or suggestions with your set up ![]() ![]() | ||||
| | #7 (Link) | ||||
| Re: Advice needed: Down or sidefire sub for odd room layout? Quote:
![]() No, the issue with the surrounds is now something no one can help me with - what angle to place the entertainment center/TV at. She wants the TV at a perfect 45 degrees so it 'looks nice', while I want it at more like 35/55degrees. My placement will allow the LR surrounds to be equi-distant from the ends of the viewing positions for, of course, better sound. (There is a beam not shown on my drawing that messes up the layout.) I don't think anyone here will be able to help with that conversation! ![]() I am planning an odd mod with the iC3's I'm going to put in which will mount them at a 30degree from vertical angle, rather than just have them point straight down. I can post that plan somewhere to see what people think, but I'm pretty sure it's never been done quite this way before.. | ||||
| | #8 (Link) | ||||
I recommend to isolate the sub as much as you can from the floor. Of course you're best path is to try for yourself both configurations. Some people dislike boundary reinforcement because tends to make bass less controlled. And maybe there are some other factors also in your layout (like room nodes etc.) which are not taken into account... | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| HT room layout advice? | sns | Home Theater Design and Construction | 24 | 02-11-08 06:11 PM |
| Advice Needed For A Used 5.1 Preamp | buggers | Home Theater Components | 9 | 10-15-07 03:32 PM |
| Cable adapter advice needed | Laneman | Remotes | Cables | Accessories | 1 | 10-08-07 09:10 AM |
| Calculating Room Modes - Odd Shaped Room | Bob in St. Louis | Home Theater Design and Construction | 25 | 02-20-07 12:15 PM |
| In need of a little acoustical advice. Room layout included. | George | Home Audio Acoustics | 33 | 02-19-07 02:18 PM |
