Older sub-woofer connection to an a/v receiver - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Older sub-woofer connection to an a/v receiver in the Manufactured Speakers and Subwoofers forum; Older sub-woofer connection to an a/v receiver All, years ago I ran the Kinergetics/BSC subwoofer, SW-100, as part of a 2-channel system. The subwoofer 'package' consists of ...
Old 02-27-08, 12:43 PM   #1 (Link)
New Member
Alias: Jay
User: #17409
Since: Feb 2008
zane9 is offline
All, years ago I ran the Kinergetics/BSC subwoofer, SW-100, as part of a 2-channel system. The subwoofer 'package' consists of the subwoofer and an external amplifier.
Life went on, and I no longer used the subwoofer: put into storage. Cut to 2008, and I have the Cambridge Audio 540R (version 2) a/v receiver. So, I am wondering if I can use the Kinergetics package with the 540R?
If I can use it, how do I connect it? I am uncertain of the signal path.
Clearly I cannot use the modern method: sub-woofer line-out on the Cambridge into the subwoofer amp. The sub-woofer amp has its own "Right" Out and In, and "Left" Out and In connections. Unfortunately I do not have the specs on the SW-100 amp. Google search does not get me very far.
As well, is sorting out all of this worth it? Or do I bite the bullet and buy a modern sub? I remember the BSC/Kinergetics sub as being of high quality, so I would like to use it if possible. But I don't want to introduce uncessary complications.
All input, advice, suggestions gratefully received! Thanks.
Old 02-27-08, 12:48 PM   #2 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Re: Older sub-woofer connection to an a/v receiver
Jason, welcome to the Shack. With the info you have provided, it sounds like you could hook up the sub-out (LFE out) from the Cambridge using a "y" connector to the right and left inputs of the sub amp. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 02-27-08, 01:12 PM   #3 (Link)
New Member
Alias: Jay
User: #17409
Since: Feb 2008
zane9 is offline
drdoan wrote: View Post
Thanks for the welcome and your ideas, Dennis! Your approach makes the issue seem much less complicated than I thought. I think I have provided the correct information. In researching the topic, there was so much information on line-level and speaker-level connections for subs that my eyes glazed over.
Using a Y connector should allow the receiver to do all the work: cross-over point, etc. I'll try it.
The only thing the amp has on it is a gain control: a dial which goes from 0 to 18dB.
Old 02-27-08, 07:38 PM   #4 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
zane9 wrote: View Post
That with the Y connector should be all you need -- until you are ready to insert a BFD inline between the amp and receiver LFE output.
Old 02-27-08, 08:26 PM   #5 (Link)
New Member
Alias: Jay
User: #17409
Since: Feb 2008
zane9 is offline
bobgpsr wrote: View Post
That with the Y connector should be all you need ..:
Thanks! Just a question on why the Y connector is needed? Will just a single RCA cable from the sub-out on the receiver into, say, Left-In on the sub amp do the same job?
Old 02-27-08, 08:38 PM   #6 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Yes, just one connector input to the amp should work. Just that depending on how the amp is connected you may be able to use both channels of the amp's input to drive the subwoofer. You might get a voltage add to require less LFE drive from your receiver. Likely it will not really make any difference -- since you have an amp gain control anyway which controls the voltage to the final current output stage.
Old 02-27-08, 09:00 PM   #7 (Link)
New Member
Alias: Jay
User: #17409
Since: Feb 2008
zane9 is offline
Thanks, obgpsr. My first day at the Shack and such informative to-the-point replies to my first post! I'm glad I joined, and hope to return the favour to someone else who has posted a question.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
new drivers for older sub dieselpower1966 DIY Subwoofers - Sealed and Ported 8 02-17-08 07:58 AM
Samsung Bd-up5000 And Older Denon Reciever ewarren High Definition | HD-DVD | Blu-ray 1 12-28-07 05:30 PM
Replacement Driver for older ported Sub dtb300 DIY Subwoofers 23 12-18-07 12:56 PM
Can blue ray or HD dvd players older old DVDs Scuba Diver High Definition | HD-DVD | Blu-ray 4 10-27-07 06:24 PM
Outboard processors for older receivers w/ 5.1 input? gopheralex Home Theater Components 3 08-27-07 03:21 PM
Mach 5 Audio
