| Home Audio Subwoofers Should I add a 2nd sub?Discuss Should I add a 2nd sub? in the Manufactured Speakers and Subwoofers forum; Should I add a 2nd sub? I’m thinking of adding a 2nd sub for use with both music and HT. I’d like to get some suggestions ... |
| | #1 (Link) | |||
| Should I add a 2nd sub? I’m thinking of adding a 2nd sub for use with both music and HT. I’d like to get some suggestions on what to go with. I currently have an HSU VTF3 MKII with Turbo. I know that there are pros and cons to having more that one sub. Pros being that you get more bass and could possibly smooth out your frequency response. Cons being cost (not really a factor for me) and complexity of integrating more than one sub. The latter point is something I’m willing to work with. I haven’t gotten a BFD yet but I will (also considering the SMS-1). I’ll likely take Sonnie’s advice (mentioned in another thread) and run the two subs using only one cable (and a y-splitter) and EQ them together rather than separately and having to combine the results. I should note that I’m very happy with the extension of the VTF3 MKII with turbo as I can go to approx 16 Hz. (it seems to be deep and loud enough). What sparked this upgrade is the fact that most people seem to be running at least 2 subs to even out the sound of the bass in their rooms. It’s not that I feel I need more bass. I just want the system to sound balanced. My room is 15x20 with 9 foot ceiling (approx 2700 sq. feet). My system consists of JBL S310II (floorstanding mains – rated down to 35 Hz), JBL S-Center II, and JBL S36II surrounds, Arcam AVR300 receiver, Shanling T-80 tube CD player…. Should I get? 1.) Another of the exact same sub - I guess this will just give me more bass, in general 2.) One that goes even deeper (eg. SVS PB13 Ultra). - not sure if this will cause problems as one will go deeper than the other 3.) An HSU MBM-12 (mid –bass module). See link here (http://www.hsuresearch.com/products/mbm-12.html). - HSU recommends this option. Supposedly this option will add to my mid bass punch. I know that brucek (mentioned in a different thread) is not sold on this concept of splitting the sub frequency but I’d like his thoughts on why he feels it’s not necessary or not a good idea to go this route. Thanks for any advice. | |||
| | #3 (Link) | |||
| | Re: Should I add a 2nd sub? ![]() I'll have to admit I don't remember the specifics, but I'm sure that's the right answer -- not that it's exactly the same, but you wouldn't mix your mains would you? And I'm pretty against the mid-bass module -- just seems to me that it introduces another crossover into the equation making it even more difficult to get it right. So, like Sheep said, get another one exactly the same and play around with placement. JCD | |||
| | #4 (Link) | ||||
| Re: Should I add a 2nd sub? Quote:
Audioholics has an article on placing subwoofers and dual subwoofers. They show some setups that have a remarkably flat responses. The easiest to facilitate is opposing corners, and I think mid side wall on each side was another good one. SheepStar AH: Where the inmates run the prison. | ||||
| | #6 (Link) | |||
| Re: Should I add a 2nd sub? Do you know someone you could borrow a sub from to try it out? You may not really need to add one as your room is not huge. Maybe a better placement of your current sub could give you a flatter more even response. I know of a number of people running 2 or more subs in rooms not much larger than yours and they said it made a difference but were not sure if it was the price of another sub better. I know of a few others with much larger rooms and they are running 3 subs and love the extra response, so it is up to you. I believe it is easier to calibrate multiple subs of the same make but it is not necessary and remember when calibrating, the extra sub will add about 3db to the overall SPL so you can set both of them back a few db to even them to the mains. | |||
| | #7 (Link) | ||||
| | #8 (Link) | |||
| Re: Should I add a 2nd sub? My room has a fair bit of acoustic treatment done to it (e.g. panels at all reflection points and bass traps in all four corners). I'll try running the 2nd sub and see how much of a difference that makes. Thanks so much for the responses. One other question. I'm getting a custom sub cable designed to split the sub signal going to the two subs. I'll run it out of the BFD but one sub is approx 8 feet from the BFD and the other (when I get it) will be approx 24 feet from the BFD. For signal integrity and signal arrival times to each sub, should I keep them the same length (i.e., 24 feet to each from the BFD) or does it not matter (ie. 8 feet to one and 24 feet to the other)? | |||
| | #9 (Link) | |||
| Re: Should I add a 2nd sub? Matching the first sub makes terrific sense, especially with that Hsu - it's a beast. You will benefit by having smoother bass, a little more headroom and possibly a bit more extension. In fact, you might do well to get the other Hsu without the turbo and eliminate the turbo you have. Your problem will be finding/eliminating the nulls, but once past that point, it's all pure enjoyment. | |||
| | #10 (Link) | |||
| Re: Should I add a 2nd sub? As others have stated, you should ideally use multiples of the same sub-woofer. Combining different model subwoofers can add more (unwanted) variables - such as if the subwoofers have a substantially different phase rotation point around roll-off - there by causing unexpected cancellation(s) due to mutual interaction - in addition to the complex room acoustics. For the processor - a Behringer DCX2496 would be ideal - not only can it individually process up to six different outputs - it is also a superb crossover to run both the mains and subs through to gain ideal integration between the two. -Chris | |||
| | #11 (Link) | ||||
| | #12 (Link) | |||
| Re: Should I add a 2nd sub? Are there any advantages of the DCX2496 over the BFD 1124P. From reading online, I thought that the 1124P was preferred because it has more presets (which I'll need - 1 for music - flat, 1 for movies, house curves for both etc.). The DCX2496 only has one preset...correct? | |||
| | #13 (Link) | |||
| Re: Should I add a 2nd sub? everything that I've read on dual sub setups says "use identical subs" the reason is this. you don't want your good sub trying to compensate for the lesser sub. with both subs being equal, you don't have that problem. and yes, that means if you intend on keeping the Turbo, get a second. also check out the THX website, they show some basic sub positioning, I have my 2 subs in my front left and right corners, approximately 1 ft. from the back and side walls, I'm actually using them as stands for my front left and right channels. good luck | |||
| | #14 (Link) | ||||
-Chris | ||||
| | #15 (Link) | |||
| Re: Should I add a 2nd sub? I just added a second sub to my setup and I've been extremely happy with the results so far. I was originally running a single SVS CS-Ultra at the 16Hz tune off of one side of a Crown XLS-602 amp. Just a couple weeks ago I found a guy locally selling a used CS-Ultra and nabbed it for less than half the original MSRP. Anyways, more to the point, I have a pretty large room at just under 7000 cu. ft. One sub is in the front right corner and the other is about 10 ft. to the left of it about midway down the long front wall shared between my living and dining rooms. The graph with REW isn't really any more or less flat than it used to be, I still have huge peaks in the 40-45 area and a huge null around 72. The null that always annoyed me at 18Hz got a little better but not much. Placement didn't seem to be much of a factor in this case. What did change was a measured increase in SPL of 5dB across the board, so I decided to plug an extra port on each and go for the 12 Hz tuning. Unfortunately I have another big null at 12 Hz which is frustrating, but overall the subs in tandem play both louder and lower than the single sub used to, and listening closely during loud passages I haven't heard any signs of bottoming. I may do some further experimentation with placement in the future but my options are very limited due to aesthetics. In the end, I think a second sub can be a great addition as long as you're using something like a BFD to keep things under control. | |||
| | #16 (Link) | ||||
I have the same configuration: 2 subs under L and R speaker. I plan to add 2 more subs for LS and RS. I love the sound with 2 subs, you can extend the good bass to more listening positions. JP | ||||
| | #17 (Link) | |||
| Re: Should I add a 2nd sub? I have no idea of your age, but let me give you an analogy. Getting and having 2 subs is kinda like the first time you got a TV with a remote control (I unfortunately am old enough to remember when this was extremely uncommon)...once you had it there was no going back. Same result with 2 MATCHING subs. The difference is far more than subtle and you'll never look back. ![]() Cheers, Konky. I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns. | |||
| | #20 (Link) | |||
| Re: Should I add a 2nd sub? Don't listen to those who say that the MBM-12 doesn't do any good. The MBM is proven addition to any main sub and can help with room anomilies. I'm running two MBM-12's, one with each main and two 3.3's, one Turbo & one without. Get a MBM-12 to go with your 3.3 Turbo and you will enjoy the best in bass! Bill VSX-94THX, Bue Jeans cables, JBL - E90 mains w/M2200 200 watt Mono Blocks JBL - EC35 center w/M2200 200 watt Mono Block, INFINITY - Beta ES250 surrounds JBL - E50 rear surrounds, Anti Mode 8033B, (2) HSU - VTF-3 MK3 Turbo, & (2) HSU - MBM-12 Toshibia HD DVD AX2 (HDDVD), Panasonic DMP-BD30 (BluRay) Last edited by bsoko2; 04-20-08 at 09:16 PM. | |||
| | #21 (Link) | |||
| Re: Should I add a 2nd sub? ThomasW from HTguide posted this link http://www.harman.com/wp/pdf/multsubs.pdf The conclusion was that two subs placed in front and in back showed very good results. Matt ![]() | |||
| | #22 (Link) | |||
| Re: Should I add a 2nd sub? I haven't had a chance to try the dual configuration as yet since I'm in the process of moving. Probably won't be able to for about another month. I'll report back when I do. Thanks again everyone for your input and suggestions. | |||
| | #23 (Link) | |||||
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||||
| | #24 (Link) | ||||
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector sel |
