| Home Audio Subwoofers Lengthening interconnecting cables for a Philips Soundbar 8100 Home Theater SubDiscuss Lengthening interconnecting cables for a Philips Soundbar 8100 Home Theater Sub in the Manufactured Speakers and Subwoofers forum; Lengthening interconnecting cables for a Philips Soundbar 8100 Home Theater Sub I'm new to the forum and I hope someone can give me some guidance. I recently purchased a Philips 8100 ... |
| | #1 (Link) | |||
| Lengthening interconnecting cables for a Philips Soundbar 8100 Home Theater Sub I'm new to the forum and I hope someone can give me some guidance. I recently purchased a Philips 8100 Soundbar system. I live in a an old restored firehouse and basically the 13-foot cable that came with the system is not long enough to stretch from the main Soundbar unit under my flat panel to the corner of the room where I want to place the sub. The sub powers the main wall unit and the connections to the main unit are undoubtedly proprietary--one is about 8 or 9 male pins and the other is female and has maybe 24 connector holes. I called Philips and they don't have a set of connector cables that would allow me to connect and thus lengthen the main cable (I probably need 25 feet total in order to get the sub into the corner where it sounds the best). Is there a solution? Or am I stuck with the original 13 feet of cables and a less than desireable sub placement? Can anyone build me a specialized connector cable for this type of sub? Thanks! | |||
| | #2 (Link) | |||
| Re: Lengthening interconnecting cables for a Philips Soundbar 8100 Home Theater Sub Welcome, K. Sorry, but, aside from buiding your own cabel, I don't have an answer, but, glad you could join. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) Denon AVR-2807 Receiver w/AudysseyXT LG DVD Recorder w/HDMI Direct TV DVR HD Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | |||
| | #3 (Link) | |||
| Re: Lengthening interconnecting cables for a Philips Soundbar 8100 Home Theater Sub Thanks for the info! For a novice like me (I teach history for a living, and building subwoofer cable is about as alien to me as flying a 747 would be), where is the best place to obtain the right materials to build my own cable that would connect into the proprietary connections of the Philips Soundbar? Thanks again for replying. | |||
| | #4 (Link) | |||
| | Re: Lengthening interconnecting cables for a Philips Soundbar 8100 Home Theater Sub You have two options. Cut and lengthen each wire to make the cable long enough or find mating male and female ends to create an extension cable. The second option would require you to take the cable to an electronics supply store or computer supply store to match up the ends. The diagram of the cable ends in the manual isn't to clear, but it may be a type of Molex connector. Proper identification of the cable ends would be the first step. We're all in this together! | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Episode 19 - The Real Home Theater Podcast: $1mil cables, Low Cost HD-DVD, Microsoft | eugovector | Real HT Info Podcast | 8 | 12-07-07 12:59 AM |
| Where can I find cables for 5.1 analog inputs or SACD cables......cheap? | tdamocles | Remotes | Cables | Accessories | 3 | 09-03-07 10:00 AM |
| My little Home Theater | JRace | Home Theater Equipment | 2 | 06-06-07 04:42 PM |
| ssabripo's DIY Interconnect cables Tutorial: $200 cables for 1/10 th the cost! | ssabripo | Remotes | Cables | Accessories | 1 | 11-03-06 12:53 PM |
| Home Theater vs Movie Theater | Roger | Home Theater, Audio and Video News | 0 | 05-09-06 07:45 PM |
