Sony SA-W3800 Performance Line 15" 200-Watt Subwoofer - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers
Discuss Sony SA-W3800 Performance Line 15" 200-Watt Subwoofer in the Manufactured Speakers and Subwoofers forum; Sony SA-W3800 Performance Line 15" 200-Watt Subwoofer Hey everybody, first post here and I'm pretty noob at home audio so excuse me if I sound like a ...
Old 03-12-08, 07:06 PM   #1 (Link)
New Member
Alias: crazyloof
User: #18101
Since: Mar 2008
crazyloof is offline
Hey everybody, first post here and I'm pretty noob at home audio so excuse me if I sound like a complete moron . I was on a pretty tight budget and did a lot of research (at the beginning I was considering hooking car audio up in my room, shows how completely noob I am .). In the end I ordered this subwoofer because it got good reviews at amazon and I heard the smaller 12 inch version in best buy and it sounded pretty good. My question to all of you is, does anyone have this sub already and can give me a detailed review of it, pro's and con's. It's going to be in a pretty small room, 11.4 feet by 10.8 feet. I love bass even if it's boomy and not as tight as most people like. I will mostly be using it for music but I do watch movies also. Here's the link to where I bought it, Amazon.com: Sony SA-W3800 Performance Line 15"...Amazon.com: Sony SA-W3800 Performance Line 15"... . Also if I was to buy another sub at a price range of 200$ max, what would anyone suggest? Thanks all .
Old 03-12-08, 10:46 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Sony SA-W3800 Performance Line 15" 200-Watt Subwoofer
Here's 21 reviews of it and it is rated 4.5/5.0 stars, which is pretty good. I think it would do you a fine job for what you are looking to do. If you want to make sure you are listening to accurate bass after you get it, download REW and take some measurements. Your goal should be to listen to the music as it was intended to sound... REW will help you see what needs to be done, if anything, to get closer to accuracy.
Sonnie
Old 03-13-08, 05:50 AM   #3 (Link)
New Member
Alias: crazyloof
User: #18101
Since: Mar 2008
Sonnie wrote: View Post
Those are the same exact reviews at amazon. Thanks for the help though .
Old 03-13-08, 07:25 PM   #4 (Link)
Alias: SheepStar
Loc: British Columbia, Canada
Sheep's Avatar
User: #16927
Since: Feb 2008
Sheep is offline
If you're going to double up a sub, it's best to do it with the same sub you already have. There is another thread going on about this topic.
SheepStar
AH: Where the inmates run the prison.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Home Audio Subwoofers »
Similar Threads
8" Dayton sub w/ 70 watt amp spresser DIY Subwoofers 4 01-03-08 07:00 PM
Transmission Line Subwoofer spresser DIY Subwoofers 19 12-23-07 05:02 PM
Is a 1250 watt sub a little "overkill" Huck HiFi Audio Components 13 08-19-07 09:40 PM
8" Transmissio Line Sub BoomieMCT DIY Subwoofers 19 06-18-07 06:49 PM
New CEA 2010 method for measuring true subwoofer performance Tom Vodhanel SVSound 8 02-17-07 07:34 AM
Mach 5 Audio
